Old 09-29-2020, 10:59 AM   #51
SCOTI
SCOTI's Avatar
Re: Wizit's bagged 60 GMC build V2.0
Originally Posted by Wizit247 View Post
Im using some quirky circle track stuff on the back that is pretty soft.
On the front I will probably use Speedway Engineering stuff.
Speedway engineering sway bars have always been great to me in the offroad world and we sure tortured them. Kartek is a great company to buy them through and their custom service is top notch. Lots of length and stiffness options on the bars and quite a few arm options as well. :cheers:
Yes & yes. But the limits I see on the Speedway Engineering site indicate 1.250" OD solid bars when desiring a 32" bar width. They show larger bars for 'cup' cars but @ 37" widths which is too wide for me.
I also didn't want to be 1K into a front sway bar & haven't seen any pricing yet.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-29-2020, 11:41 AM   #52
Wizit247
Wizit247's Avatar
Take a look at Kartek's site. They have the Speedway Engineering bars in solid, 0.188, and 0.250 wall in lenghts from 32" up to 39.5 in one inch increments.
$150 for the bar is about as cheap as your going to get for a quality product. They have a fair selection of arms as well including some blank aluminum bars you could have machined with some detail if you desired.
Capture by Wyatt Lassiter, on Flickr
Over the top, billet infused, ground up 60 GMC build http://6772chevytrucks.com/vboard/showthread.php?t=809901
Wizit247 is offline   Reply With Quote
Old 09-29-2020, 01:37 PM   #53
vet57air
vet57air's Avatar
Nice work. I am envious of the machine work that you do. Nice to have those tools. Are the machine tools your using from work or you have them at home?
vet57air is offline   Reply With Quote
Old 09-29-2020, 02:06 PM   #54
SCOTI
SCOTI's Avatar
32" is my max width (outside edges of my rails). A 1.250" solid bar w/11" arms yields a rate of 609#. This leaves up/down adjustability (664 or 554# @ 1" increments @ the arm) for tuning. The same OD tubular bar would only yield a lower torsional rate.
For comparison, Ridetechs sway-bar used on their front C10 C/O app has a rating of 1020# (1.5" OD .250" wall construction).
I feel I need a larger bar as my starting spring rate is 750# or I would have to utilize shorter arms. Packaging wise, a larger bar would be better for my app. The only ones I see larger on the Speed Engineering site are the wider 'cup-car' spec bars (37" width).
I'll check out Kartek. Thanks for the lead.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-29-2020, 03:55 PM   #55
Wizit247
Wizit247's Avatar
The majority of the machine work you've seen has been done at my work but I also have a mill and lathe in my home shop. Things like the upper links had all of the cnc work done at my work and anything that can be done manually is done in my home shop.
Old 09-29-2020, 06:37 PM   #56
The Rocknrod
Moderator
The Rocknrod's Avatar
Pretty clean machine work. I thought those rear axle brackets were aluminum for a while. Had me all gerfunkled as how you would attached them.
Old 09-29-2020, 06:56 PM   #57
SCOTI
SCOTI's Avatar
They are that nice!
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-29-2020, 07:22 PM   #58
SCOTI
SCOTI's Avatar
I checked out the Kartek site. Unfortunately, the increase in OD significantly impacts price. $156 for the 1.250" solid bars but jumps to $700 for 1.5" solid @ 36" width w/no hollow option (for something possibly between the two choices). The 1.5" bars are also 35-spline requiring that spec arm which are also priced higher.
The search continues.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-30-2020, 01:06 PM   #59
Wizit247
Wizit247's Avatar
The 1.5 bars are 300m material. Thats whats driving the massive price increase. Those are typically used on trophy trucks to allow for the missive amount of twist it will see.
Whats the application that is causing the required high rate? If its not a very long travel I would think you could go down to a much shorter arm. Ive seen guys running 6" arms pretty easily if the geometry is correct. Good luck on the continued search!
Old 09-30-2020, 01:27 PM   #60
SCOTI
SCOTI's Avatar
It's an aftermarket front x-member w/bag or coil-over dropped application. The 'long arm' requirement is simply the distance between the bar C/L & the mounting spot @ the control arm. I'm investigating location possibilities now to see if I can move things closer which would allow for shorter arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-09-2020, 01:10 PM   #61
Wizit247
Wizit247's Avatar
I got the upper links last week and had to drill and tap them for the threaded bushings on my manual mill.
I did some cardboard template work and came up with diff side mounts. Cut them out and got it all tacked together. This rear 4 link has been a long time coming so it felt really good to see it all together!
Old 10-09-2020, 02:07 PM   #62
cwcarpenter98
cwcarpenter98's Avatar
This is one of those builds where you want to have a removable bed floor to see all the artwork underneath
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 350, Saginaw 4 speed
Old 10-12-2020, 12:46 PM   #63
Grizz1963
Grizz1963's Avatar
Well said.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 10-14-2020, 08:53 PM   #64
slammed57
just stumbled across this build... this is goin to be one mean truck...lookin forward to it
slammed57 is offline   Reply With Quote
Old 10-15-2020, 10:14 AM   #65
Wizit247
Wizit247's Avatar
Thanks! The current plan for the bed floor is to be partially covered with beadrolled aluminum panels. Some of the axle and link area will stay open and exposed. Similar to Tiffany c10 if you have ever seen that truck.
Thanks!
Old 10-15-2020, 10:39 AM   #66
Wizit247
Wizit247's Avatar
The swaybar components came in. I built the brackets and mocked everything in place. Im not completely happy with the look yet so it may change. I am going to leave it clamped in place for a bit and see if it grows on me.
I also started drawing up some billet upper arms for the front suspension. with all the billet on the rear it started to make me unhappy with the look of the front suspension.
Im looking at using the cross shaft of the Joes racing arms and bolting on the billet arms. They will utilize a standard c10 bolt in upper ball joint.
Old 11-09-2020, 12:10 PM   #67
Wizit247
Wizit247's Avatar
Finished up a few things on the chassis and set it on the ground so I can start figuring out cab mounts.
Old 11-09-2020, 12:23 PM   #68
Android04
Android04's Avatar
Beautiful
Android04 is offline   Reply With Quote
Old 11-09-2020, 12:28 PM   #69
SCOTI
SCOTI's Avatar
Clean. So clean....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-09-2020, 12:39 PM   #70
cwcarpenter98
Wow, that's super nice
Christian Carpenter
Old 11-10-2020, 04:25 PM   #71
88Stanger
88Stanger's Avatar
DAMN That is Beautiful!
88Stanger is offline   Reply With Quote
Old 11-10-2020, 05:31 PM   #72
The Rocknrod
Moderator
Yep that'll work. Great job.
Old 11-13-2020, 02:34 PM   #73
Wizit247
Wizit247's Avatar
Spent some time last night working on cab mount design. I ordered some cab mount bushings and as soon as I get those and verify thickness I will cut and build the cab mounts and trial fit the cab. That will allow me to start working on the cowl mounting.
Old 11-16-2020, 12:38 PM   #74
aggie91
I'm just glad to be here!
aggie91's Avatar
Truly Awesome!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 11-16-2020, 12:47 PM   #75
Wizit247
Wizit247's Avatar
Finished the cab mounts and set the cab on the chassis. Next step will be figuring out the grill mounts.
