#51 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: My 68 anniversary arrived today
Nice find and a great looking truck. Thats a common spot for the trucks to rust as evidenced by mine.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#52 |
Just Did another compression test . 160 to a low one of 150 . So well within the 15% variation . Plugs are gas fouled so in assuming either the po tried to start it on the gas in the tank or the carb is bas . I'm going to rebuild the carb and tune it up
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 08-28-2020 at 09:26 AM. |
#53 |
I am going to address the bed but I'm leaving the rest of the body alone . Well except for cleaning it
#54 |
I knew I had a couple of these . Took it out of the box for the picture
#55 |
![]() Join Date: Mar 2019
What are you doing with the old wheels and caps?
67 C10 Fleetside SOLD 67 C10 SWB Fleetside 67 C20 Fleetside 68 C10 Fleetside 68 C20 Fleetside SOLD 72 k20 Pay Pal: Grant.Furneaux@gmail.com |
#56 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Is that a compressor?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#57 |
I drove thru that storm yesterday in Pine Bush . Well I had to pull into tractor supply couldn't see 10 feet in front of car . We'll definitely have to get together
#58 |
I'll put them in storage I never get rid of original stuff of a vehicle . Caps are pretty banged up .
Yup York compressor so at least I know if it's bad on the 68 I have one and an extra one for the Hawk . The electric clutch next to it is an early studebaker model 1962 or so . I also have a V style for my lark with a new under dash hang on unit .
#59 |
#60 |
#61 |
Took the carb off to get it rebuilt checked the numbers it's for a 68 for the 327 /350 part number 7028213 but from what I've researched it's for 4 speed applications
#62 |
![]() Join Date: Aug 2017
I will provide interesting information regarding this number if I'm back at home.
Best regards GerhardH! Members met: 68 short step, 68bowtie, 72c20customcamper, botmfedr1, C/10 King, Chevyland, cornerstore, dmjlambert, fun in dirt, GMan69, Ol Blue K20 1968 CHEVROLET C20 Custom Camper 50th Anniversary, Long bed (LB) 8', 327 V8, Air Condition (AC), Power Steering (PS), Power Brake (PB), Z62 Custom & Comfort Appearance, Turbo Hydramatic TH 400 http://67-72chevytrucks.com/vboard/s...d.php?t=760400 |
#63 |
The last digit supposedly designates if the trans is a stick or auto, even number indicates auto, odd number indicates stick. BUT, I've read in more than once, that this rule does not always apply...
#64 |
From a carburator specialist: (Anyway 7028213 und 12 are nearly the same.
The numbering rules for Rochester carburetors have a lot of exceptions. One common one is for trucks, where an odd number is often used for both standard and automatic. This is the case in 1968 where the number 7028213 is used for a 327 in a truck, regardless of transmission. However, in passenger cars in 1968, 7028213 was used for 327 standard transmissions and 7028212 was for automatics. It would be incorrect to have a 7028212 on an automatic equipped 327 truck since the Rochester manual from the period lists only 7028213 for trucks. See also my protect-o. plate C=CARTER and build sheet -8213 (327 mit TH400)
