Old 09-22-2020, 07:05 PM   #51
stomper
Junior Member
stomper's Avatar
Re: Should I cut this truck ?
My initial opinion is YES! ABSOLUTELY! BUT.... now that I see the tool box and leaf rear, that changes my mind. Leave it. A shortened truck should be on bags or at least a static drop and on a leaf rear, bags are just not possible. Also, shortening the bedsides gets sketch with the tool box.
LEAVE IT.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 09-22-2020, 07:49 PM   #52
lolife99
67-72 parts collector,…
lolife99's Avatar
metaloxfab on Instagram is one of the best at shortening bedsides.
Even the ones with tool box doors,...
Keith
Convert to disc brakes.
Old 09-22-2020, 07:51 PM   #53
stomper
Junior Member
stomper's Avatar
OK now that's pretty cool.
Old 09-22-2020, 07:56 PM   #54
lolife99
lolife99's Avatar
And no seams in the shortened door,...
Keith
Old 09-22-2020, 08:45 PM   #55
Killer Bee
Killer Bee's Avatar
Originally Posted by Chevyland View Post
if you have to ask.....
Old 09-22-2020, 08:48 PM   #56
jocko
jocko's Avatar
You can't shorten it, your SPID would then be incorrect!
Do what you'd like Eric, that's the only real answer - and you can't go wrong. And I do understand the draw - but you already know which side of the fence I fall on
Old 09-22-2020, 09:52 PM   #57
best view
I would make a k20 out of it add some cab lights and call it done
best view is online now   Reply With Quote
Old 09-22-2020, 10:06 PM   #58
Joesjunk
Joesjunk's Avatar
Leave it as it is!
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 09-22-2020, 10:23 PM   #59
57taskforce
All about them K’s
57taskforce's Avatar
That’s definitely nice work shortening those bed sides. I don’t think I’d have the balls to cut up an extremely hard to find rust free tool box door like that. Mine is rust free as well and I haven’t seen another one in similar condition over the last several years. That said it is pretty cool that they were able to keep the tool box on it. Doesn’t change my opinion though. I still wouldn’t shorten Chevylands black super.
Tyler
57taskforce is offline   Reply With Quote
Old 09-23-2020, 07:58 AM   #60
I don't see the tool & stowage compartment as a factor. Pull the bed and put on a shortbed, used or new from parts. I'd be fine with leaving it long, but I opened my mind to him shortening once I saw the frame has already been altered with a c-notch. And as far as lowering goes, it's axle flip ready for that. You all have to remember, this man has variety already, and it looks like he's considering expanding to have a ride to fit in with his truck buddies he hangs with. Considering all the elements I can see where this contemplation is coming from. Remember, this is a "like 'em stock" guy. Nothing wrong with expanding that to "like 'em all" or "one of each".
Old 09-23-2020, 11:40 AM   #61
KQQL IT
At the body shop.
KQQL IT's Avatar
Cut it.
A cut down longbed is more desirable than a longbed.
A purist may disagree.
But the market says otherwise.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 09-23-2020, 01:46 PM   #62
sick472
sick472's Avatar
A short bed catches my eye when I see them. They are more rare because they could not be worked as much and farmers and such wanted trucks to haul things...BUT I can not condone cutting that one down! Frame damage ,as mentioned, no bed or rotted out bed, a bunch of franken parts...make a short bed, but don't take a long bed's life. At least go find a short box and sell the long one.
It's your truck, honestly, do what pleases you!
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 09-23-2020, 01:53 PM   #63
CG
BlahBlahBlah
Its your truck do what you want. I would have zero trouble cutting it if I wanted a short bed and thats what I had to work with. Like you said the stigma of selling a cut down long bed seems to have waned when it comes to someone buying one. Maybe not some of these guys on the board, but generally =)
Old 09-23-2020, 02:55 PM   #64
Grumpy old man
Grumpy old man's Avatar
Chop it , And by doing that it makes the "REAL" short beds worth more . It's only made it almost 50 years without someone hacking away at it . You may as well drop it on the ground with air bags and raise the bed floor and throw an LS in it at the same time with a few computers to make it run and don't forget to add all the high $ stereo equipment into the newly chopped dash . Don't forget at least 4 cup holders and enough Led lights that it can be seen from the space shuttle and after all that $ dumped into it leave the "patina paint"
It's your truck do whatever makes you happy with it .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 09-23-2020, 03:00 PM   #65
Killer Bee
Killer Bee's Avatar
I don't always agree with Grumpy - but when I do, it's posts like that!
Old 09-23-2020, 03:48 PM   #66
Boog
laying low
Boog's Avatar
With it's C notch it's already been "hacked" so it was well on it's way to being lowered and what ever else anyway. It was violated!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-23-2020, 05:37 PM   #67
BLT-NT-BOT
Originally Posted by KQQL IT View Post
Cut it.
Who's ever stretched one?
I have!
BLT-NT-BOT is offline   Reply With Quote
Old 09-23-2020, 05:45 PM   #68
Boog
laying low
Boog's Avatar
Thumbs up Re: Should I cut this truck ?
Nice.
Boog
primer is finer
Old 09-23-2020, 06:00 PM   #69
KQQL IT
At the body shop.
KQQL IT's Avatar
Originally Posted by BLT-NT-BOT View Post
I have!
My dad did too. Always think its a unicorn
Old 09-23-2020, 06:40 PM   #70
72c20customcamper
72c20customcamper's Avatar
Cut it.
Friend of mine has and put a Duromax in it
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 09-23-2020, 07:31 PM   #71
Bones72Super
Bones72Super's Avatar
Cut it.
This guy did !
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 09-23-2020, 10:56 PM   #72
cornerstone
cornerstone's Avatar
It seems to me like it would be a great candidate for a new No Limit or Roadster Shop chassis, either long or short! Get it down in the weeds and do it right if the $$$ is not a concern.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 09-24-2020, 08:07 AM   #73
Originally Posted by Grumpy old man View Post
Chop it , And by doing that it makes the "REAL" short beds worth more ...
...It's only made it almost 50 years without someone hacking away at it . You may as well drop it on the ground with air bags and raise the bed floor and throw an LS in it at the same time with a few computers to make it run and don't forget to add all the high $ stereo equipment in...
I know you were being funny, but your first statement is not necessarily true. In fact, it can be proven wrong. Many cut down trucks have sold for more than many originals. It seems as time goes by, original means less and less to more and more. Not me, and I don't care anyway. I buy trucks to spend money, not make money. For those who care about the value of their trucks, cutting a longbed down doesn't increase the value of an original shortbed any more than leaving the truck as a longbed.
As far as all that other jabber... You feelin' alright?
Old 09-25-2020, 05:21 PM   #74
Sim6
Sim6's Avatar
Cut it.
true story!!!
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies
53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793
http://67-72chevytrucks.com/vboard/s...d.php?t=771679
Sim6 is offline   Reply With Quote
Old 09-25-2020, 08:21 PM   #75
chewychevy67
I wonder how he shortened the fiberglass insert? That's the stump I'm having with mine
chewychevy67 is offline   Reply With Quote
