#51 |
![]() ![]() Join Date: Jan 2005
Re: Reproduction Tach Dash Bezel Lens Text Not Lighting Up
Continued from previous post. More photos showing the tach installed
#52 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
interesting.... another thing to look at when I get mine pulled. Did you happen to reach out from where you got it from their thoughts on this? Seems like a silly thing to make wrong and easily done correctly.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#53 |
I haven't yet, but I will once I get it reinstalled in my truck and confirm the needle is lit up at night. I'm waiting for a replacement speedometer to arrive. Should be here today.
#54 |
![]() Join Date: Aug 2018
I need the tachometer template that you used to cut the hole in the rear tin...
#55 |
#56 |
Here's a template for cutting the rear tin for a tach.
#57 |
Here are two photos that show how the speedometer needle was not illuminated when using the reproduction tach rear tin, and how it is lit up nicely with the original tin.
#58 |
Mr. Cheyenne
wow
#59 |
![]() Join Date: Oct 2009
Thanks for documenting this, probably lots of folks do a resto and never notice until they are driving at night. Lotsa good info in here and with helpful pics too.
#60 |
One thing I should point out is that I posted a photo earlier in this thread that showed the speedometer needle lit up fairly well at night using the aftermarket tin. The difference was that I was missing the rubber pad that goes between the back of the speedometer and the tin. This caused the speedometer to be farther back, letting some light through to the needle.
#61 |
I contacted the place I bought my tach kit from. They informed me there is only one manufacturer making the tins. They sent a message to the manufacturer about the issue, although it seems highly unlikely that they will do anything about it since it would be expensive to remake the tooling.
#62 |
I just printed off the template, it looks to be the right scale and I will check the ruler to make sure it is. Thanks for taking the time to do this for everyone that may need it!
#63 |
Mr. Cheyenne
Well if there is only one making it, then that means mine will have the problem too (from GMCPaul's). I just cannot remember if I kept it and put it into my parts box at my brother's. I have to wait until I get my truck back to know, if not I'll be on the hunt for one
#64 |
#65 | |
#66 |
Mr. Cheyenne
just asked 70shortfleet for on. I have also asked GMCPauls if I can pre-pay for a new lens and get a refund when I return the bad one. I am convinced the green is painted on the wrong side.
I can hardly see any numbers or any of the labels. The Speedometer is the worst as I cannot even see the indicator peg!
#67 | |
#68 |
Old member
Haven't used the tins I bought about a year ago but here are some pictures I just took tonight. They are suppose to be NOS but I have my doubts they really are. They are in clear plastic bags with no markings. The guy had several of them a few years ago at a swap meet. I bought these 2.
The picture show they are the same depth as a factory dash though. ![]() Here are some pictures of a dash I put together for my Ramp truck using original dash and aftermarket lens with LED bulbs. No problem seeing the numbers at night for sure. The LED are suppose to be able to dim but when I try they dim slightly then just go out. Doesn't matter to me anyway I need all the light I can get at night. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#69 |
Mr. Cheyenne
nice looking inside lights! I have similar LEDs but they do in fact dim. I am on getting a new tin (70shortfleet) and now to see if GMCPauls will work with me getting a new lens. Their pan "A" was for me to send my bad one before getting a new one. I have requested that I pre-pay for a replacement and to get a refund when I return mine.
When fix all this, I really hope I don't need break apart the dash again - ever. It really sucks as when I did it the 1st time a few months back I was also installing my tilt column. btw, here is my LED spare - I used these in my dash cluster. Edit: I got them from http://www.whitegauges.net/ but I am not seeing them anymore. They only seem to have these, which are 6v~12v dimmable too.
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim Last edited by Rich72C10; 01-04-2021 at 11:46 PM. |
#70 | |
Old member
![]() Quote:
Do you have a link for those bulbs? I may try a set in the next cluster I build. Here is a video of one of my cluster's I did. ![]() https://www.youtube.com/watch?v=DPXrJSpJq5U
#71 |
Mr. Cheyenne
Edit: found them! WHITE High Power 194 Style LED Replacement Instrument Cluster Gauge Bulb
#72 |
Mr. Cheyenne
for the record, I would not call it a wide range of dimming. Also seeing I never used my truck at night before the swap I am not a good judge of how well these LEDs dim (or not).
Once I get my Tin/Lens replacements only then will I know if I like the lighting. Right now is awful. I can't see a thing with my speed. This Tach kit was not what I call a cheap upgrade or a fast one (not hard, just takes a lot of time). So I am somewhat disappointed in GMCPauls selling a subpart kit - IMO.
#73 | |
I had a nice speed-warning cluster for a '69 2+2. I was cleaning it up and lightly misted it with water, which was the end of it. I wiped the cloth across the face and took most of the number with it :-( It's weird because some you can scrub aggressively with Windex, but if they've been baked in the sun the paint goes dry and powdery... I spent a lot of time with my truck cluster on the bench in order to balance the lighting. I added reflective mylar tape in some areas to brighten, etc...
#74 | |
![]() Join Date: Feb 2002
#75 |
Mr. Cheyenne
Got my parts from GMC Paul's (lens) and 70shortfleet (tin for gauges) today and installed. I can now see stuff! Basically the difference between night and day ;-)
