Old 12-24-2020, 09:01 PM   #51
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Picked up a GM 14 bolt rear end for the 63 C20
Yup, and that little purple(?) spring is the return spring for the adjuster lever.
~Steven
Simi Valley, CA
Old 12-25-2020, 07:36 PM   #52
Asshat
Asshat's Avatar
Looks like the drums I have are too deep. Mine are 4.75” deep, from the face of the wheel mounting surface. And the rear end is 4.0”.
Anyone know what drums would be correct?
Guess I gotta figure out what vehicles had a GM 14-bolt 8-lug rear end.
1963 C20, small window, long bed
292, 4-speed
Asshat is offline   Reply With Quote
Old 12-26-2020, 06:23 PM   #53
Just call me Sean
Just call me Sean's Avatar
Yours looks different than mine, but I checked it. It's from my '93. I'm pretty sure there is a light duty/heavy duty brake option though.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 01-02-2021, 07:32 PM   #54
Asshat
Asshat's Avatar
Finally got it in. Found the correct drums too; 4-5/8” overall height.
And, the noise is gone! Drove it around the block and that horrific noise I had before is a thing of the past. However, I need to remove the trans, it’s leaking from the from someplace up front. Damn, thought it would be all good.
Feels a bit easier to drive too, not geared so low. It’s 4:10, but much better than the 4:56.
Had a difficult time bleeding the brakes again, got all the air out and didn’t have pedal pressure. After adjusting them, I got the pedal pressure back. However, it must be too tight, cause the truck doesn’t roll. If I get the truck to roll a little it just stops when I push the clutch in. I’m afraid if I ease up on the adjustment I will lose some of that pedal pressure.
Also need to re-adjust the axle position. Don’t have and adjustable pan hard bar, so I’m contemplating cutting the weld on the bracket and getting it into position. It’s off by about an inch; not sure if it’s worth buying the adjustable pan hard bar from Brothers. Are they the only outfit to offer an adjustable pan hard bar?
292, 4-speed
Old 01-02-2021, 11:29 PM   #55
SCOTI
SCOTI's Avatar
Brothers, POL, CPP, Porterbuilt, & you can always tweak on original bar to make it adjustable (look in the suspension FAQ area).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-02-2021, 11:55 PM   #56
Asshat
Asshat's Avatar
Tweak the original pan hard bar?? That thing is so friggin heavy! How the heck?
292, 4-speed
Old 01-03-2021, 12:01 AM   #57
Asshat
Asshat's Avatar
That one from POL needs a different bracket, I’m wondering if the one from Brothers just bolts right up to the stock mounts.
292, 4-speed
Old 01-03-2021, 12:35 AM   #58
Steeveedee
Who Changed This?
Steeveedee's Avatar
You only need to back the brakes off a couple of clicks on the adjusters to get the friction reduced to where the truck will roll without resistance but still have a nice firm pedal. Play with it.
~Steven
Simi Valley, CA
Old 01-03-2021, 01:02 AM   #59
Asshat
Asshat's Avatar
What about the trans leak? Do these early transmissions have a seal on the input shaft? Is this probably where it’s leaking from?
292, 4-speed
Old 01-03-2021, 01:03 AM   #60
Asshat
Asshat's Avatar
Yes - going to try this. Hope it works.
292, 4-speed
Old 01-03-2021, 09:26 PM   #61
Asshat
Asshat's Avatar
It’s up on jack stands now. I’m thinking it’s a trans leak, since the puddle on the ground was not hot and it was more heavy/sticky than regular oil. Hoping I can run it on jackstands and eventually see where the oil is leaking.
My initial inspection did not make me believe it is coming from the from shaft cover of the trans.
292, 4-speed
