Old 03-09-2022, 06:12 PM   #51
LT7A
Re: attaching lower door carpet panels
Originally Posted by 82c10gcl View Post
Thanks for the info S10Fan. It’s a good looking door panel. I’ll check out Red Door out of curiosity. I need to stay with original or replica panels due to my collector plates however so i’m just dying mine. Much appreciate the input anyway.
Glenn
Wow, it sounds very narrowly defined what you are allowed to license as a collector vehicle. Is it something that they monitor? Maybe you have yearly inspections or something?
Originally Posted by S10Fan View Post
Magnets were mentioned above, they are a very good choice. I used magnets to mount most all of the panels in the trunk of my 50 Chevrolet. The panel behind the seat hides my stereo gear, removing the panel is a simple no tools required process.
That's good info. Very clean installation.
Old 03-09-2022, 06:34 PM   #52
S10Fan
Old Heap Driver
Originally Posted by LT7A View Post
Wow, it sounds like the very narrowly defined what you are allowed to license as a collector vehicle. Is it something that they monitor? Maybe you have yearly inspections or something?
Thank You. Here's a link to the magnets I used, they're roughly 3/4 to 7/8 inch round. Mine are attached with screws, but I'm sure a really good epoxy would work. By the way, these magnets are great with a zip tie through the hole for a little extra umpff with car covers etc.
https://www.amazon.com/gp/product/B0...e?ie=UTF8&th=1
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-13-2022, 06:58 PM   #53
82c10gcl
Thanks for the info on the magnets LT7A. I visited their website and they look like a good answer.
Regarding the collector's plates, our insurance is government issued and they are pretty strict about what they will approve. Aftermarket radios and non- original speaker installations aren't allowed and catch a lot of people. Blemishes in the paint and chrome, rips, cracks or severe fading in the interior finishes, etc. also would be an issue. Under the hood basically needs to be stock or only have aftermarket upgrades that were available at the time. There were only two types of wheels that were acceptable for me to use other than the stock ones from the day (luckily, one of the options was American Racing Torque Thrust, which I wanted anyway). You aren't allowed to increase the size of wheels and tires by more than an inch from stock and lowering or raising the truck isn't permitted, although an inch or two up or down probably wouldn't be an issue. The originality of the vehicles appearance (either NOS or reproduction parts can be used) is key. For some parts (such as my refurbished 81 buckets) they will allow the replacement to be to factory specifications from one year each side of the vehicle's year. How they regulate the program I think is mostly by fear that if you make a change that deviates from the photos on the basis of which your collectors plates were approved, they could theoretically deny an insurance claim or pull your plates if you had an accident. Not likely for a minor deviation, but who wants to risk it? The savings in having the collector's plates makes it very worthwhile going through the hoops to get them.
82c10gcl is offline   Reply With Quote
Old 03-14-2022, 08:56 AM   #54
Rich84
Rich84's Avatar
"Government issued"..No thanks. That explains it.
Rich84 is offline   Reply With Quote
Old 03-18-2022, 09:54 PM   #55
LT7A
Oh my. That's a lot to bother with... both for you and the govt.
Magnet info credit goes to S10Fan.
Old 03-20-2022, 07:22 PM   #56
82c10gcl
Right regarding the magnet info. Thanks S10Fan
Old 03-20-2022, 08:50 PM   #57
calvin78612
calvin78612's Avatar
The magnets in the link are great, i used that style to hang 8' LED lights in the shop. For my door panels which are thin i used the small rectangular magnets from Hobby Lobby as they where very thin and hold very well. Any good epoxy will hold the magnets in place on the door panels no problem.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 03-21-2022, 11:26 AM   #58
S10Fan
Old Heap Driver
I'm still laughing at what their reaction would be to my 1927 Pontiac pickup that looks exactly like a 1931 Ford pickup.
You're thinking, "Pontiac never built a pickup", they did build a sedan though, and the sedan frame is now home to a pickup body. Registering the truck as a Pontiac was the simplest way since I had a title for the sedan.
Bryan
Old 03-21-2022, 11:33 AM   #59
S10Fan
Old Heap Driver
They are handy things that's for sure. I use them mostly holding plastic sheets over panels when I'm painting close by. Covering a windshield over night so I don't have to deal with heavy frost in the morning. I use a zip tie through the center hole to make them easier to remove.
Bryan
Old 08-27-2022, 01:06 AM   #60
82c10gcl
I've been making some progress on the interior finally. Got my new dash pad installed and the old door panels dyed to match (with new aluminum trim). Got new full kick panels dyed and the carpet on. Got the passenger's side installed. Seems to fit properly but the hole for the screw at the leading edge of the old half panel doesn't align with the hole in the new full panel. Is this typical or does the panel need to be repositioned somehow? Do I need drill new holes for this screw as well as for the one near the bottom of the panel? I bought some magnets to go that route but that means removing the panel again to install them so I may just get my drill out and go for it if that is what's required.
My next problem is trying to get the driver's side panel out without removing the e-brake pedal. I've moved the pedal up and down and it still seems to block the panel. Any suggestions or tips would be greatly appreciated.
Old 08-27-2022, 01:12 AM   #61
82c10gcl
Looks like it didn't post the pictures. Here they are.
Old 08-27-2022, 08:51 AM   #62
TKCR
TKCR's Avatar
Since the full kickpanels are slightly different than the partial, just drill a new hole.
The drivers side, it takes a little maneuvering of the kick panel and the ebrake. But it doesn’t have to come off. The parking brake handle does though, since it attaches thru the panel, into the metal panel.
Old 08-27-2022, 07:03 PM   #63
82c10gcl
Thanks TKCR. Not sure if it’s cheaper to pay the medical bills for the heart attack i’m about to have from trying to get this gd panel off or to buy you a plane ticket to have you come up here and do it for me. I just spent another 2 hrs wrestling with it and still can’t get the vent to clear the opening in the metal. I’m ready to give up and chop it up to get it out and get the new one assembled with the old vent flap. But then I still have to fight with getting the new full panel back in. Does it go back in easier than it comes out? I just had them dyed and I don’t want to be scuffing and scratching the finish wrestling with it. Make my day and tell me it goes in easily.
When you take them out, is there a sequence you use? Any additional tips you can give will be appreciated.
Glenn
Old 08-27-2022, 07:29 PM   #64
TKCR
TKCR's Avatar
Glenn
Sorry your having such a time with it. It’s been awhile since I had mine out, and then back in. And I have actually had it in & out several times for various reasons. Can’t say I remember the sequence. I Just know the only thing I did have to loosen from the side panel was the release handle. I think I just pressed the parking brake all the way forward, and that put it out of the way. Then once the new part is in, you can release the brake.
Old 08-27-2022, 07:37 PM   #65
82c10gcl
[QUOTE=TKCR;9117559]Sorry your having such a time with it. It’s been awhile since I had mine out, and then back in. And I have actually had it in & out several times for various reasons. Can’t say I remember the sequence. I Just know the only thing I did have to loosen from the side panel was the release handle. I think I just pressed the parking brake all the way forward, and that put it out of the way. Then once the new part is in, you can release the brake.[/QUOTE
OK. Thanks again. Tomorrow’s another day so i’ll try again. Maybe go to church first to get some extra help. I’ll let you know how I make out.
Old 08-27-2022, 07:49 PM   #66
TKCR
TKCR's Avatar
[quote=82c10gcl;9117562]
See if you can find a video online tonight. I know that was how I fiqured a lot of this stuff out, was watching videos. I didn’t know anything about these trucks when I first bought it and started doing work on it myself. The how to videos saved me several times.
Old 08-28-2022, 09:33 AM   #67
Axle
Axle's Avatar
Sounds like they made those rules to make sure that no one tries to use their collector car as a daily driver. Here in Ontario historic plates can be had once the vehicle hits a certain age regardless of condition with a handshake type agreement that you will only use that vehicle for parades, car shows, and only going for repairs. Technically no runs to the grocery store, no going to work with it, obviously not too many people adhere to those rules, on the other hand, if you need to have your vehicle in pristine condition to get collector/historic, you will be a lot more selective of where and when you drive it.
Axle is offline   Reply With Quote
Old 08-28-2022, 05:58 PM   #68
82c10gcl
I think you're right, Axel. They are counting on the collector car owner being much more careful than the average driver about where and how they drive it, thus justifying the much lower rates. You can't take your car to work and you need to show you have another vehicle that you use as a daily driver and the hours of operation are restricted but otherwise you can use it when you want for pleasure driving so it is a really good deal. Worth the headache of getting the collector plates.
Old 10-23-2022, 07:30 PM   #69
82c10gcl
waiting for the vent seals to arrive before I can install the drivers side quarter panel and it looks like I'm going to have to have the parking brake pedal loosened up to do so. I'll post how it turns out.
In the meantime, I got a set of the interior trim for around the windows to hold a new headliner on so I'm looking at how to attach them.I don't really want to drill hole so if magnets (as mentioned above) have been used for this application successfully by anyone and they can post pictures, it would be greatly appreciated. If it have to drill holes instead, are there any tips I should take into account. I've seen warnings about being careful the drill doesn't go through the outer skin of the roof. Anything else?
