#51 |
Re: new steering box
agree . The 93 shaft has a rag joint still on it and it doesn't have any plastic pins. It is designed from the factory to slide in and out with no damage being done. Between the rag joint and free movement I think I will be OK.
#52 |
supposedly the 02 vans have a ujoint shaft that fits right in. haven't looked yet to confirm it though.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#53 |
update> purchased a used 93 suburban steering shaft. The length is prefect. With the sliding rod it bolts right up. Of course this isn't the end of the story. Hooked it all up and the rag joint is junk. went to local parts houses they look at me like I am nuts asking for a rag joint. Oreilles says don't have it auto zioe sells me a Dorman that would work but by the time I buy the extra grade 8 bolts I think I am better off going on ebay and buying a new coupler complete. So that's my plan. I will update when I get it .
26 spline i am pretty sure. |
#54 | |
Hopefully that will do it.
#55 |
all back together and driven/ here is a recap.
Redhead box is quit a difference in feel from my local rebuilt box. It has more resistance and I like that . Would recommend a redhead over a local rebuild if you need a box. The 93 suburban two piece shaft fits perfectly. With the approx. 3 inch slide in of my steering column inward towards the dash. Installed new rag joint/coupler and it is tight. Great improvement. Now for the test drive. Compared to before there is an improvement (still has slop)and with the higher resistance on the new box the movement is a lot safer to adjust to going down the road. BUT the slop is less but still there, It is NOT coming from the box or rag joint for sure, It is coming from the connection between the two slip shafts on the suburban Shaft I bought . Not sure I can ever get this play out unless I find a NOS shaft, This almost looks like 30 year normal ware. Now if I assume that play is normal then it is in the column. Does anyone know if there is a way play can be found in a 93 suburban tilt column by something being worn out |
#56 |
Last update I hope. Just installed a brand new NOS steering shaft from a vendor that bought out these from GM Part #26033101. WOW what a difference. NO MORE SLOP??
There is something I learned that I would like to pass on. If you take one of these sliders apart the ones that are not plastic inserted make sure you put all the parts back in it. The used one I bought on ebay was missing a very important leaf spring looking tensioner that wedges between 2 indentions that then slides together in one piece. I think is why the slop was there. Thanks everyone now on to my AC |
#57 | |
![]() Join Date: May 2010
Great update. I'm glad you got it figured out.
It only has original paint once |
#58 | |
Moderator
![]() Join Date: Oct 2008
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#59 |
![]() Join Date: Apr 2018
Glad you got it squared away! And thanks for coming back and posting the final results in here... nothing worse than getting 3 pages into an epic steering slop novel only to be left hanging at the end
"Sweet Pea" 1975 Cheyenne 20 http://67-72chevytrucks.com/vboard/s...00#post8477900 "Bourbon" 1975 Suburban ScottsdaleSOLD https://67-72chevytrucks.com/vboard/...49#post8769049 ”Otis” 1970 C10 SWB -SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=762766 ”Chebby” 1962 Impala LS/TKO-500 http://www.pro-touring.com/threads/1...2-Impala-Build |
