Old 10-06-2021, 04:15 PM   #51
Johnl48
Re: Rust on ring and pinion
This came available down the road from me. Wrong gear ratio (3.83) but I can change that. Only thing it's out of a 95..c3500
Short of changing spring and shock mounts would it fit ?
Old 10-06-2021, 07:48 PM   #52
Caddylackn
Caddylackn's Avatar
Measure the backing plate to backing plate dimension and the outside rim to outside rim dimension. If the wheel offset is the same or close to yours, it looks like it would work for width.
Compare the rear end yokes where the U-joint bolts on. Make sure the overall width is close, some one tons use a larger diameter driveshaft and larger U-joints which would make bolting your stock driveshaft and U-joint to that rear end yoke more challenging. They do make conversion parts and custom driveshaft modifications. I was able to use my stock Dana 60 yoke installed onto my Dana 70U to match up to my stock driveshaft and u-joint size.
In your case if your driveshaft won't bolt on to that rear end, you might be able to make a custom driveshaft using the stock front part of driveshaft grafted on to the rear driveshaft end of the donor vehicle.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 10-06-2021, 08:21 PM   #53
Johnl48
Originally Posted by 71meangreenc10 View Post
Dually got split, has 4.57 ratio 32ring/7pinion on it. Ring and Pinion actually look good, few ring teeth with pitting but, nothing like yours.
I do have another axle, but it will be a while before I take it out from the motorhome if you are not in a hurry.
If you want anything from it let me know.
Smitty
Oh well. We tried. Let me know when you take the other one out. Thank you
Old 10-07-2021, 11:31 AM   #54
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
No problem.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
