#51 |
![]() Join Date: Jul 2015
Re: Windsheild Install OOHH my!!!
#52 |
I have paid to have mine installed twice by a "professional glass man" and still don't have a well seated windshield/trim.
#53 |
When I bought my '71, the PO had put fresh glass in front and back, after reading this, I'm glad he did! What he did not do, however, was put the trim around the windshield before installing it. Is it possible to get the trim snapped into place with the windshield already in? Thanks!
#54 |
It is not possible to put the trim in the gasket after it is installed in the truck. In fact, if the trim pops out of the groove as you are putting the windshield in, you have to pull it all out again and start from scratch.
#55 |
Suddenly, that trim doesn't seem so important.
#56 |
Post 19 has PDF file that shows a cross section of the gasket, glass and trim installed. The trim locks in behind the glass.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
#57 |
I have heard every which way to do this. I had done mine rope from the top down, making sure to get the upper corners correct.
Still leaks even with both Butyl Sealant, and Some other gooey rubbery sticky crap. The trim went in on the 2nd attempt, popped back out. I bought another no trim gasket to attempt maybe again. Life goes on leaks or no leaks. ![]() |
#58 | |
#59 |
Well I went and got the '67-70 trim this week. So the trim and gasket are now matched up. I put the gasket on the glass to get it to relax some. Also got some good news from my son inlaw. He found someone to install the glass for me. Good thing the guy asked all the right questions that showed he had installed some before.
#60 |
I dont blame you. Hope it all works out. I have been reading this thread since the beginning, and it has been both entertaining and educational. I'm not a hundred percent sure that some of the installs have some measure of luck involved. A young man could pick this lost art up and make some serious side money.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
#61 |
![]() Join Date: Dec 1999
Not really that hard with the right tools and some knowledge that is available. The right tools and patience are key. If you have mechanical ability, it can be done. If you need a YouTube video with instructions to tell you which way to turn a nut you should not try this. Dealing with aftermarket trim makes the process much harder, if not impossible.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#62 |
![]() Join Date: Sep 2013
Fifth time lucky!
#63 |
Looks good. Persistence is the key. There was no way I was giving up on mine.
#64 |
![]() Join Date: Aug 2019
After reading about all of the trouble with installing the windshield and getting it to seal I got out my service manual and read the install the windshield section. The book says to place the rope with a big loop at the top of the windshield in the middle and both ends at the bottom in the middle. With a helper pushing in on the windshield you pull first one of the rope ends till you are 2 inches from the top corner. Then you pull the other end of the rope till it is 2 inches from the top corner. Then pull one side of the loop at the top to 2 inches of the top corner and repeat with the other side of the loop till it is 2 inches from the top corner. The next step is to pull both the lower end of the rope and the top end of the rope ( you are at the top corner ) at the same time. Slowly pulling the gasket into the corner. Repeat with the other top corner. It says to use a popsicle stick to help with the placement of the gasket. Seal the corners 6 inches along the top and 6 inches down the sides from the top corners.
#65 |
I wonder if I could effectively go back & do this now? ... and use what, urethane?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
#66 |
I think you could add the urethane after, tape off the pillar and the rubber, use some 3/16 cord where you want to seal, fresh tube with small outlet. Work the nose in under the cord , pull the cord slowly out while you caulk.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
#67 |
![]() Join Date: Dec 2013
Use CRL sealant
https://www.crlaurence.com/crlapps/s...&ModelID=19965 With the pump https://www.crlaurence.com/crlapps/s...&ModelID=19352 It's expensive but you'll only buy it once and it lasts for years . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#68 |
Well the factory method is an interesting read BigBird. I would like to see if this method works better than the standard method everyone uses.
#69 |
![]() ![]() Join Date: Sep 2008
I'm with Grumpy in Post #67. That's the way I have always done it
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#70 |
Grumpy,
I take it the little loop getting in between the pinch well and gasket and you have tip trailing in the direction of travel. Correct?
#71 | |
1) The CRL sealant isn't used until the windshield is fully installed and only if you have a leak . 2) Assemble your windshield and seal /trim a week before you intend to install , When your stretching the glass seal onto the windshield it becomes "alive" and wants to shrink back to it's original size ( This makes it harder to install in the trim and Install the windshield in your truck ) Think about it when these trucks were built on the line they weren't stretching seals onto the glass as the truck rolled up to them ,They were already done ,seal and trim already installed on the glass picked up by one of the guys on the line ,Dropped into the opening and centered by another guy on the other side of the truck while a third guy pulled the rope from inside the truck and was totally installed in minutes .if not faster . 3) butyl tape ( Like the type referenced below from NAPA) should be applied to the outside of the windshield pinch weld on each top corner about 8-9" across the top from the corner and down the side about the same distance NO other sealant should be used until it's needed after your done . 4) Never use Urethane / silicone / marine sealant or really anything else to seal your windshield before during or after installing your new glass . 5) The only lube that should be used to aide the install is glass cleaner or mild dish soap/water in a spray bottle . 6 I see lots of pictures of fresh painted trucks without the 4 body seams around the windshield without the seams sealed before paint and then they wonder why it leaks ? Always seal those 4 seams BEFORE you paint it or it's going to leak like crazy , ![]() https://www.napaonline.com/en/p/MS_4...&gclsrc=aw.ds& https://www.amazon.com/XFasten-8-Inc...nFromLogin=1&#
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 02-12-2022 at 09:20 AM. |
#72 |
Thanks for the clarification Grumpy. Looks like I need to add the trim to the glass and let it set for awhile. Hopefully I can start on it tomorrow. I am ASSUMING that I should follow the glass curve when setting the trim and not worry about the pinchwell curve. Correct?
#73 | |
![]() Join Date: May 2007
OEM seal with an OEM windshield if possible is the best way to go. After market is a crap shoot.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#74 | |
#75 |
Well while I am waiting for my glasses guy to grace me with his presence, it's been two weeks, thought I would put the window trim on. I wanted to see how well it fit. The side pieces followed the control of the glass good and I had no issues there. The top trim was another matter. I ended up cutting three reliefs on each side to get it to lay flat.
I will be adding the little trim pieces after I rewatch the video.
