#51 |
![]() Join Date: Jan 2025
Re: To Sniper or not to Sniper...?
I looked at that but it appears to be the sniper 1 edition.
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
#52 | |
![]() Join Date: Feb 2022
#53 |
How about an insulated case for an external pump to help with noise? I thought of a case like this, and installing a low-voltage PC fan in it for air flow. Maybe even just removing the lid and having the case as a pump surround
On a separate question, are the external pumps better mounted tightly to something, or better to use rubber standoff isolators to mount it for noise
#54 |
Rubber isolation. I found a location on the frame that had 3 good holes in a location that was workable. Took a scrap piece of steel and matched up the holes. Then match the location of mounts on pump. Drilled the plate. Tapped the 4 holes for rubber mounts. Bolted plate to frame. Installed rubber mounts on plate and then pump to mounts. Rock solid. No welding or drilling of frame.
Edit: Oh put a bead of rtv at edge of plate attempting to avoid moisture between the two metal parts. |
| Bookmarks |
