#51 |
![]() Join Date: May 2011
Re: 72 C10 Build
We had a nickel-sized rust hole in the bed floor that I mentioned earlier. I missed getting a before pic but, here are a couple of the first repair passes. Wasn’t 100% sure how far we'd go with the right inner door shell repair. I only used a small part of that large inner patch panel to repair the rusted-out area. With the skin removed it gave us good access to both sides of the patch. Also, allowing the straightening of the lower and rear door shell areas. If you recall that rear area was pretty wavy from the earlier accident.
Brett ![]() 66 El Camino: BBC, 4sd. Waiting for its turn. 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
#52 |
Re: 72 C10 Build
Here are a few after welding up the rust repair.
#53 |
Re: 72 C10 Build
I have lots of similar rust locations. Keep chugging along
My 1970 C10 ChassisFab LWB to SWB Build Thread |
#54 |
Re: 72 C10 Build
Thanks, will do. My boys and I are having a good time on this one.
![]() Right inner rocker fitment and a quick check of the lower fender mount spec I took earlier (7.5” ish). That green stuff is Eastwood Internal Frame Coating, I sprayed up in the roof and both A & B pillars. I figured it couldn’t hurt and may slow the rust.
#55 |
![]() Join Date: Oct 2012
Re: 72 C10 Build
Sub'd to follow along with the rest of the build. Nice progress so far on the rust repairs. I just went through all the same issues last year.
Scott 1970 C10 Restomod|454/700R4|LWB-->SWB Build Thread 2014 2500HD DirtyMax|Daily Driver|Stock 2003 Tahoe Stock 1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed |
#56 |
Re: 72 C10 Build
Thanks, I appreciate it. Ha, more to come. We tore right into it.
After fitting the right front cab support, we started welding up the inner rocker on that side.
#57 |
Re: 72 C10 Build
Welding up the right front cab support. HF copper spoon just fits in the support channel.
#58 |
![]() Join Date: Jun 2002
Re: 72 C10 Build
Metal work is going great! It's a frustrating but satisfying process.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#59 |
Re: 72 C10 Build
Thanks Roger, it's cool to see it start coming back together.
Left inner rocker fitment and opening the floor up for better access to the rear support on this side. Before and after getting a small patch ready for the toe board.
#60 |
Re: 72 C10 Build
Here’s some right inner rocker and kick panel welding. Followed by lower a-pillar fitment. It’s moving right along…..
#61 |
Re: 72 C10 Build
Back to the left side, the inner rocker is going in to help hold the rear cab support in place for the final fit and weld. The kick panel, toe patch, and support have all gone in on this side.
![]() Even started working the right cab corner a little more by fitting the lower b-pillar/door jamb.
#62 |
Re: 72 C10 Build
Here are the backside shots of these patches. Final fitment of the left rear cab support prior to weld, I’m pleased with how this is turning out.
The lower right a-pillar is done, and our right floor pan patch is ready to go!
#63 |
![]() Join Date: Jun 2019
Re: 72 C10 Build
Great work
#64 |
Re: 72 C10 Build
Thank you, I appreciate it!
Lower left a & b-pillar fitment, some toe kick weld as well as some more work on the LR cab support area. We're getting there.
#65 |
Re: 72 C10 Build
More welding and chasing pin holes.
#66 |
Re: 72 C10 Build
Awesome work. I think on my next build I'll just buy the whole damn floor replacement lol
#67 |
Re: 72 C10 Build
Thanks nicklear36!
Let the scar tissue continue!!!
#68 |
Re: 72 C10 Build
Getting close to a done stamp on the floor!
#69 |
Re: 72 C10 Build
Nice work, That's a lot of patches!
#70 |
Re: 72 C10 Build
Thanks, it’s gotten a few!
![]() Some more Eastwood green slime (aka internal frame coating).
#71 |
Re: 72 C10 Build
The kick panel is welded and dressed. The driver's floor pan is still ready; we need to get that welded up. Made some progress on the B-pillar, though. Heavy Chevy, Booyah!
#72 |
Re: 72 C10 Build
With the left floor pan welded (no pics) it was back on the right side, just a few more pin holes to fill.
#73 |
Re: 72 C10 Build
My goal was and is to hide all the repairs, especially from underneath the truck. Next up, we put the cab on its back to dress all the welds. Here’s what the left side looks like.
#74 |
Re: 72 C10 Build
And the right side. Last shot is the whole enchilada.
![]() Now's a good time to bring up our time line. We’ve got 2 years on the clock, putting in a few hours here and there. We’ve been sidetracked renovating my wife’s childhood home, wiring the garage and of course messing around with other vehicles.
#75 |
Re: 72 C10 Build
It's looking good! How did you roll the cab? I will need to do the same pretty soon.
| Bookmarks |
| Tags |
| 72 c10, accuair, big block, cheyenne super, ridetech |
