Thread Tools
Display Modes
#51 |
Re: Leaking Fuel Pump Diaphragm?
If it hasn't been mentioned, GM vehicles used steel lines from the mechanical pumps to carbs. Rubber lines on the pressure side bad.
#52 |
I picture all the Holley duel feed setups with rubber lines running to them.
#53 |
For that matter my Carter P4070 fuel pump came with brass fuel line nipples on both sides.
ETA: I'm not really too worried about a low pressure fuel pump bursting a short section of rubber fuel line but I do like the idea of flaring the tubing for a little more resistance. ETA II: Hey I kinda like this edit to add stuff, I don't have to keep bringing this thread to the top. ![]() To put things in perspective, my cooling system is running at least twice or maybe more pressure than my low pressure fuel system and that arrangement is nothing but rubber hoses and band clamps. Last edited by BRL; 03-13-2025 at 07:23 AM. |
#54 |
It’s not about burst pressure.
Coolant does not catch fire ![]() |
#55 |
Nor does gasoline as long as it doesn't leak from a ruptured mechanical pump diaphragm or something.
Hey I drive around all day with 20 gallons of fuel behind my seat, I'm a risk taker. ![]() |
#56 |
#57 | |
Or maybe accumulate on your garage floor for days because you neglected to check in on your poor C-10's while you buzzed around town in your Telsas...you seething lowlife's! ![]() Any advice is welcomed. ![]() Last edited by BRL; 03-13-2025 at 03:14 PM. |
#58 | |
![]() Join Date: Mar 2019
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
#59 |
![]() I ran the pump to look for leaks and there were 3, both 5/16" brass fittings on the pump that I immediately replaced with the original 3/8" fittings and the before carb. bronze element filter that I screwed in wrong. I'm replacing that with a one piece metal filter, but other than that there were no leaks and no fuel dribbling down the carburetor venturies either. 🙂 And geezer#99 was right, it sounds like I bolted a Hamilton Beach blender to my frame but I can easily compensate for that with my killer stereo volume control. ![]() |
#60 | |
Still plays with trucks
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#61 |
My cousin had a fuel pump diaphragm leak into his engine while it was running and fill up his crank case. It worked just enough that the engine still ran but still leaked fuel into the engine. It diluted the oil down so much that it trashed the bearings in no time flat. We ended up having to put a different crank and cam into it because the journals and lobes were so torn up. This happened in one days commute to work on the highway about 30 miles round trip.
#62 | |
It was but I quickly discovered that I need to fabricate a tin heat shield because of the close proximity of the exhaust pipe. Other than that it ran great and fired right up after sitting for so long. ![]() Last edited by BRL; Yesterday at 11:18 PM. |
#63 |
#64 |
Fuel pump function check.
This counts as an early Sideways Saturday shot. ![]() |
#65 |
Looking good, nice rig!
1968 C10 327, 3 speed manual, LWB stock height daily driver. 1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon. |
#66 |
Thank you, I always appreciate compliments from fellow 67-72 Chevy truck forum members.
![]() I could barely perceive a slight humming sound from the pump when I was stopped at a stop sign with the truck in gear, (yes I do stop for those things) and that was with the stereo off. (a rare occurrence) Very pleased with the installation and twisting around under the truck for days has limbered up my joints to the point of patting myself on the back has become much easier now. ![]() |
