![]() Join Date: Jan 2025
Re: I feel like I messed up bad - new to me truck issues after purchase
II feel like and idiot like I have said before but I didn't feel like getting hit along the highway after dark either.
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
Final update in OP
First, Congrats on what looks like a real cool truck
![]() I read through the posts real quick, as someone else mentioned, ...fuel filter sock (on the sending unit pickup). You mentioned sputtering, fuel starving, smell of gas, plugged up carb filter, etc. ...(sadly) been there done that. Absolutely 100%, if you haven't replaced the fuel sock, do it now. Long story short, when I got my truck (68 C20 Utility, in signature) I went through it, rebuilt carb, pertronix, etc, etc. It ran fine...for a week or so. Gas all over the carb, so I sent it back to the rebuilder (In CA). Get it back a 2nd time, truck was running fine. Second trip to gas station, spitting and sputtering. It turned out the fuel sock was totally disintigrated and (no surprise) were clogging the filter, clogging up the carb, etc. When I did pull the sending unit, I decided to clean the tank too. The tank (still in cab, along with it being an Arizona truck) was spotless inside, BUT ...fragments of the fuel sock all over sitting at the bottom. Once that was done, I have not had an issue since.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
Good looking. Truck. Driving a classic that just putted around town, or garage run for years, is always a experience. Your just shaking loose what was ready to service. Nothing U mentioned is out or ordinary, your just on a steep analog learning curve. Enjoy..
| Bookmarks |
