#51 |
![]() Join Date: Jun 2005
Re: Do all old trucks leak or is there an acceptable amount?
If you are talking about the PermaDry gaskets, they have torque limiters built in so you cannot over-torque the bolts. I have the valve cover and oil pan gaskets. They are expensive, but worth it in my opinion. They are also reusable, which is nice.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#52 |
![]() Join Date: Jan 2025
I think I read somewhere to put a dab of rtv on the edges under the 4 bolt carrier when replacing the neoprene main seal.
1972 C10 Custom Deluxe Highlander 402 Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility. |
| Bookmarks |
