Old 01-30-2004, 11:35 AM   #51
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
biglou55, in reality, the BOP big blocks would be pretty much the same as slapping a caddy engine in there. (and your engine parts would be cheaper too) The exception would be the location of the motor mount towers, and possably not being able to use the ones I used. (being that they are flat, I say it is a good starting point.) Just take a look thought my caddy engine swap page (In signiture) and see what's involved.
Use your 455's manifolds, don't even think about headers right now, that's another headache another day. THe motor mounts need to be of the engine's brand so they'll bolt up to the engine. You may need to run a fuel line to the other side, might need to move the tranny's cross member, ect.
On the tranny part though, i prefer installing the tranny in the propper location. Put the crossmember in the TH400 location, install the tranny supported with a bottle jack and block of wood, and then dangle the engine in the frame rails. Mark where you need to mark, take a few digi-pics (if able) so you can remember exactly wht part of the fire wall you may want top dimple, and then get the engine back out of there.
Having the eniter front clip off is pretty much a must. You can do it with the fenders and all on, but it'll make you hate the swap.
Old 01-30-2004, 11:36 AM   #52
Longhorn Man
Oh yeah, if you do it, take lots of pics and all...some one will want to know later on...a small geo-cities site is easy to do and will help you keep the steps taken in order for when some one asks you how to do it.
Old 01-30-2004, 01:15 PM   #53
biglou55
Thank,s longhorn man I am down to bare frame trying to decide which way to go. (455 buick 350 or 327 chevy) I have a 63 caddy that run,s well but i don,t know what size engine is in it. 390? maybe.
Certifiably crazy person
biglou55 is offline   Reply With Quote
Old 01-30-2004, 01:17 PM   #54
Longhorn Man
might be a 390. A 63 wouldn't have the 425/472/500.
Old 01-30-2004, 02:21 PM   #55
iluvmy72
I'D GO WITH THE 455 MAN!!!
These BOP 455 were some of the best engines ever made......there is nothing wrong with using a 350 or 327.....however if you want real power and a strong response feel from your engine, I'd go with the 455. I however can't run the 455 because I'm trying to save gas and pass smog at the same time.....and after the smog test.....the smog pump is coming off!!!!
iluvmy72 is offline   Reply With Quote
Old 01-30-2004, 03:18 PM   #56
jorgensensc
jorgensensc's Avatar
I haven't ever been one to like to swap makes of vehicles and engines, but after this thread I might have to look into it. HMMMMMM
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 01-30-2004, 06:58 PM   #57
shortymac83
hmm...
shortymac83's Avatar
wasn't the big block caddy before the 472 a 429? Well, at least, that's what's in my books as being the BBC before the 472. Then the 472 was eventually phased out and replaced by the 500, which was used in all caddies in 76, then after that, it went to the 425. At least, if my memory serves correctly.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
