02-02-2010, 12:24 AM | #726 | |
Re: Finally "Silvers" build thread!! ('78 swb 2wd silverado)
right on brother! hey, that was the nastiest text ive ever recieved... almost puked when i saw it was a dude!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
02-02-2010, 12:47 AM | #727 |
progress! i got a lot done today!! (Dennis Standards) went to see Larry at Specialized today. got the factory egr/air tube block off plate for the intake. new tranny dip stick(the 6.0 doesnt have a threaded bolt hole in the block for the tranny dip stick??) i also got a different pulley tensioner.(mine had a crack on the pulley)
also went to Sears and picked up an awesome drill bit set called cobalt. along with the tap for the engine plate mod. bought other stuff just cant remember what! as for the progress...we started the "Modded Fred Mod". Draggin86 brought over the custom bracket he made and tacked it on the x member! i need to get a bottle for the welder tomorrow so i can finish it off(flux core sucks) i also did the mod to the adaptor plates like Fred. (Drilled and tapped the holes) Tomorrow i have to take the intake off so i can set the motor in the frame to check the bracket and mark the holes to be drilled. i also sandblasted, primes, and painted the clam shells and bolted up the driver side. on to the PICTURES!!
02-02-2010, 12:50 AM | #728 |
more!
02-02-2010, 12:52 AM | #729 |
more
02-02-2010, 12:54 AM | #730 |
bracket...
02-02-2010, 01:00 AM | #731 |
the bracket piece is just tacked so when i set the motor i can adjust it or move it. i measured exactly 2 1/8" back so i think it will be perfect and its big enough so i can move the stand up to 1" either way. i'm learning alot. the more i do the more i understand and realize its not as hard as it seems!
BTW, THANKS FOR ALL THE HELP BILLY & WILLY!
02-02-2010, 11:43 AM | #732 | |
Next project: 1970 K10
That the ticket brother! Mine was a learning experience for me too. Just gotta jump in there like Chuck Norris and not be afraid of anything!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
02-02-2010, 11:53 AM | #733 |
yeah, i think your better off! needless to say i wont be getting drunk with Gerald!
thanks for the encouragement Bob! how'd the bracket piece look to ya??
02-02-2010, 12:58 PM | #734 |
I looks great, and is a very reasonable solution.
02-02-2010, 02:07 PM | #735 | |
I have car A.D.D.
The bracket set up is looking good. Will it need some gusseting, or is it strong enough as is? (Once welded up of course.)
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
02-02-2010, 02:54 PM | #736 |
Looks good Dennis. Nice to see your making progress. Even if it is by Dennis Standards
02-02-2010, 03:34 PM | #737 |
Formerly- 1972SuperCheyenne
Looks good buddy.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
02-03-2010, 02:42 AM | #738 |
thanks guys!
Well..... SHE'S IN!!!!!! just got cleaned up... i went and spent a small fortune at the local welding supply today, came home and got busy. i was out there for 10 hours straight. i ended up taking off the bracket we tacked on yesterday because the flux core was horrible. i welded everything up, smoothed, and painted. For those doing this swap the Fred way, i had to clearance the clam shell so the bolts would clear. then i ended up just beveling out the front, right, bottom bolt hole so i could just put the flush mount bolt in. painted everything up and dropped her in. i left the passenger side engine stand unbolted and lined everything up. it just so happens there is a bolt hole on the xmember that lines up perfectly so i could put 1 bolt in and mark the holes. took the motor out for the final time to drill the holes and dropped her back in. this all sounds alot easier than it was and thanks Bob for taking the emergency phone call today! really helped out here's all the pictures from today
02-03-2010, 02:45 AM | #739 |
more
02-03-2010, 02:50 AM | #740 |
few more
02-03-2010, 02:53 AM | #741 |
last ones
02-03-2010, 03:00 AM | #742 |
so next is help Draggin86 make a template for the trans x member. i think i'm going to go with tubing and let him do his magic. the tranny is sitting in there perfect right now so it should'nt be too bad... i'm also going to start cleaning up and painting the acc. brackets and get everything on the motor. reminds me i need to get a knock sensor harness, sensors, and intake gaskets just for piece of mind. hopefully in the next few weeks the body work will start so i can get the cab on her!
and if it werent for my neighbor buddy Will i'd still be out there trying to line those damn motor mount bolts! thanks man!!
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list Last edited by menace121978; 02-03-2010 at 03:02 AM. |
02-03-2010, 04:00 AM | #743 |
dude looks freaking great! im glad you got that bad boy in there! im also glad you got some gas for the welder you defiantly will enjoy it more! i work saturday ill 3-4pm if it doesnt rain so we'll see..
02-03-2010, 08:37 AM | #744 |
Looking good Dennis.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
02-03-2010, 09:59 AM | #745 |
O HELL YEAH! Engine looks sweet in there. Great work on the engine stand mod. Glad to see you made some progress and it wont be long the cab will be back on and it'll start looking like a truck again. Once i got the cab back on my last project it really made me believe I was getting somewhere.
02-03-2010, 10:02 AM | #746 |
Slots go on anything!
Looking good, buddy!
1974 Jimmy- 5.3/4L80e/NP241 |
02-03-2010, 10:06 AM | #747 |
AWESOME!!!
Looks great sitting in there man. I'm really psyched for you. Oh in that last pic. That's just a battle wound man. It's been a battle getting it in there, but your winning the war! |
02-03-2010, 12:35 PM | #749 |
Oh yeah, it looks sweet sitting in there! I dig the black and silver together!!
Battle scars FTW!
02-03-2010, 01:43 PM | #750 |
I have car A.D.D.
Looks great man!!!!! I am sure you are not excited. But, I know the rest of us are excited for you. Good job!
