04-21-2013, 08:48 PM | #726 |
Re: 1981 Chevrolet C50 Pick-up Conversion
http://youtu.be/7oMrSg6_PcE
My son wanted to go for a little spin today... Took a lot of arm twisting.
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 |
04-21-2013, 08:49 PM | #727 |
04-21-2013, 08:51 PM | #728 |
Can anyone offer some assistance to me on how to have your video directly on your page? I am unable to get my head around this process..
04-21-2013, 08:52 PM | #729 |
On the youtube page, copy the "embed" link to here.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061 |
04-21-2013, 08:55 PM | #730 |
On the youtube page, copy the "embed" link to here. - I have tried that, but I keep getting nothing...
1981 C50 Conversion http://67-72chevytrucks.com/vboard/s...d.php?t=503247 1962 Grumman Olson http://67-72chevytrucks.com/vboard/s...d.php?t=613242 Last edited by UPNADM; 04-21-2013 at 08:57 PM. Reason: trying to ad youtube video |
04-21-2013, 08:57 PM | #731 |
Never thought I'd be jealous of a child. Haha The truck looks good on the road!
1979 chevrolet k-20 "O'l Blue" 350 muncie 465. Project in process. |
04-21-2013, 09:06 PM | #732 |
Not a very busy day. Got the rear speaker pods hung.
Have some new Kenwood 4x10's on the way.
04-21-2013, 09:08 PM | #733 |
Any thoughts on this situation... Why GM ever thought putting torx heads on seat belts was a good idea is beyond me.
I have broke two bits on them now... I am hoping some heat and a pipe wrench will do the trick. Any suggestions?
04-21-2013, 09:10 PM | #734 |
Quality bit, penetrating lube, and some heat. They use them so they can't be easily removed.
04-21-2013, 09:13 PM | #735 | |
The donor C50 where I got the new belts was all bolts. It was a little older though.
04-21-2013, 09:13 PM | #736 |
I know the pieces fit
Cool! Why'd the grill and bumper need to come back off?
04-21-2013, 09:18 PM | #737 |
pipe wrench it with a cheater.. lol thats wat i do. of coarse your not me. i mean what harm would it do to that bolt? and for the sheet metal.. i think itd damage the sheet metal before itd damage that bolt....
Her name is Quicksilver 1978 Chevrolet silverado, shortbox stepside currently being swapped IN is a LM7 5300 vortec, 4l80E, factory 4.11s, slammed, a dream ride and coined QUICKSILVER gotta pay $$ if you wanna play |
04-21-2013, 09:21 PM | #738 |
I had to take the grill out to install my overflow tank for the radiator. Two of the bolts where easier to get at with the grill out. Never got it back in today.
As for the rear of the bumper, a couple things, I scuffed some of the paint when we did the fit for the new brackets and installation. And I need to finish installing the lights that are mounted in the bumper as well as the license plate lights. I keep bouncing around my finish list, keep crossing things off. I keep saying to myself, do one thing, then the other, but I see something and it draws me to it. As long as it all gets done... ha.
04-21-2013, 09:23 PM | #739 | |
78K & 79C Jimmys
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-21-2013, 09:26 PM | #740 |
Good idea...
I thought worst comes to worst, I will get my cousin to come over and weld some nuts on the top of these bolts. We have done this in the past to remove some broken wheel locks...
04-22-2013, 08:08 AM | #741 |
Watch out for your cornhole !
Using all of the heavy duty methods mentioned is asking for trouble. If you snap that bolt off you have a bigger problem to solve. Use good penetrating oil, top and underneath and some patience. Spray it every day for a week or so. Then have someone under the truck with a little propane torch to heat the welded nut up nice and warm next time. I'd bet it comes out and you won't be left with having to drill and remove a broken bolt stub.
Posted via Mobile Device |
04-22-2013, 09:19 AM | #742 |
If I'm not mistaken those bolts are located above the saddle tanks so the only place to torch it from is the top.
04-22-2013, 09:32 AM | #743 |
I was looking at the pictures and it looks like he's just running that big square gas tank under the passenger side door. Looks like heat on the weld nut might be an option. I guess he's the only one can tell for sure what access he has under there. It would surely help if he can make it happen.
04-22-2013, 09:37 AM | #744 | |
Good idea, heat is always your friend in these situations...
04-22-2013, 09:40 AM | #745 | |
04-22-2013, 03:19 PM | #746 |
78K & 79C Jimmys
can you hit the lower exposed thread with a sand blast
04-22-2013, 03:24 PM | #747 |
The threads/bolts are really clean... Just really tight... ha.
04-22-2013, 04:44 PM | #748 |
high-Tech Red Neck
PB Blaster and a few days will probably be more than enough to work them right loose.
As well if you have to heat them PB Blaster is a great oil to use because it comes in a spray can. I would just spray a bunch on it from the top and bottom, it will soak through, give it a couple of days. With applying more every day.
"He used to be a pretty nice feller, now he's a welder!" |
04-22-2013, 04:55 PM | #749 |
PAM cooking spray works really well. I've tried them all but in the past year I've been using it over anything else.
04-24-2013, 08:41 PM | #750 |
Did a little blasting tonight...
Seat mounts done, sun visor frames ready for paint.
