#726 |
Re: 1976 Square "Simple Green"
#727 | |
#728 |
#729 |
Well, that's a ****ty ground.
Maybe (and this is a stretch) when it's cold the only areas that are making good "ground" have shrunk due to the cold and when it gets around 100 degrees it warms up and grows and makes contact (thermal dynamics). Everything moves when it comes to temperature, granted it may be only .001 but even a .001 can make a difference. You edited your post as I was typing The studs do have a good ground but the studs are threaded in to the intake. The throttle body coating could possibly not make electrical contact to the studs or not make a good enough one for the ECU. Again it is a stretch but it could be an issue. Last edited by swampbog; 01-01-2016 at 11:18 AM. |
#730 |
Ray here.
Went gray kind of.....And I hade my best bake your batty charger on it. and it spun over good.. The way I finally saw it was if my battery was any good I would not need a charger.. for more than a short time.... Ray. |
#731 |
I looked at some pics of the FiTech body and I do see none coated areas at the base where the studs go, or are they coted but in a clear only?
Is there only one area that is "non coated"? The few pics I saw it looks like only one area is bare. |
#732 |
Yep how mine is only 1 bare area. It has 2 but how mine bolts in it is only contacting 1 bare spot. I believe that may be why they said run a ground from the carb stud.
#733 |
I looked at your video again, (it's one of the videos that popped up on a search) and I think I found a issue.
It's that damn clear air cleaner cover you have. The FiTech unit can see that it's crappy outside and it doesn't want to get out of bed. https://youtu.be/rfauqfN8m7c?t=18s ![]() |
#734 |
#735 | ||
#736 | |
#737 |
No. I hooked the HEI module to a back carb stud and its is grounded. Also just checked the bare are it is getting ground also.
#738 |
Ray here.
I'm done beating this horse after this...For it my not be your problem. Lets go back in time when Yamaha made the XS650 twins late 70s They would not e-start when cold unless the battery was less than two months old but would go off first kick.....when warm they fired rite up it drove me crazy and the customers weren't real happy.....The Ing.would not work over the draw of the starter.. I'm glad those days are over... Well its time to load my snowmobiles and go for a ride. You do have a kick starter...Well maybe a hand crank....just kidding.... Ray. OUT Last edited by ray1970; 01-01-2016 at 11:57 AM. |
#739 | |
Or could it still be a fuel issue. But the screen going white (or gray for Ray) kinda makes me think it's electrical somehow. Some of what I've been reading http://www.chevelles.com/forums/show...835633&page=10 Post 142 to 169 and it continues on with others stating no issues. And another who fiddle with the IAC and had 12V issues http://gmc.mybirdfeeder.net/GMCforum...o=292259&rid=0 http://www.corvetteforum.com/forums/...-review-4.html Post 65 talking about ground issues with cold start Seems to be something with the 12V and ground. I still say try the direct wire for hot and ground and on the ground try all the studs just to put that to rest. We have a few more months of cold to get this figured out. Just what you wanted to hear, isn't it. ![]() |
#740 | |
#741 |
I'm with you swampbog. Sometimes I ground my grounds!
"In an insane world a sane man must appear insane" ~Spock~ |
#742 |
Like I said i get to mess with yours to fix any problems when I finally get mine.
It's just me thinking of myself. ![]() Speaking of myself... Have you seen Holleys' new Hydra Mat https://www.youtube.com/watch?v=yfE1v65fNZI I'm thinking of getting one for me or maybe even going to Tanks Inc fuel pump module http://www.tanksinc.com/index.cfm/pa...prod/prd84.htm But I kinda like the idea of having the fuel pump externally mounted so if it goes bad on a trail I can easily replace it without dropping the tank. But the Hydra Mat isn't cheap either and they say 5-10 years before you should replace it depending on the dirtiness of the fuel and how often you drive it. Again dropping the tank to replace it. But if I cut an access panel in the floor I can do either easily. Oh and I'm running all PTFE line from tank to the EFI. |
#743 | |
#744 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I've been watching installation videos for some of the other guys units, and I noticed that also. Their computer units have a large black wire and a large red wire, and they want them both wired directly to the battery terminals.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#745 | |
#746 |
The FiTech does not have a ground wire it ground thought the studs on the intake. And I will argue until I am blue in the face about how I have it hooked up. Lol. The junction block is tied into the battery.
#747 |
I have a Jeep with a fiberglass body so I know all about grounds. Plus the older CJs were known to have ground issues. If you wanted brighter headlamps the easiest thing to do was run a dedicated ground from each light and taa-daa you look like your running your high beams and now your high beams are actually blinding people.
On my Jeep everything has a dedicated ground or it's clustered to a dedicated ground. I have ground lugs everywhere and it's ridiculous. |
#748 |
I have a friend who installed one on a Bronco. Engine would start and then die. Changed the battery and it ran great for a while. Then it wouldn't start at all. It burned up a couple of the pins in the power connector. (the yellow one) He sent it back to FiTech and I have not heard the outcome.
I am getting ready to put one on a friends 69 Camaro. We have already decided if we have any of these issues we will just use the throttle body and the injectors and run it with a GM computer like we are doing with the Retrotec throttle bodies on my Apache. I hope it doesn't come to that.
#749 |
This is how I described it to Jeremy from FiTech. Imagine it like this battery on the left junction box on the right starter in the middle. They all connect at the start which is the center point. So what would it make a difference connecting at battery vs junction box. It all runs to the starter.
#750 |
Looks like this. So you have a visual. The batter terminal and the terminal from the junction block connect on the same stud on the starter. So how in the hell is connecting direct to be battery different that how I have it hooked it is getting the same voltage it is tied into the battery?
