Closed Thread
Old 04-03-2015, 03:54 PM   #726
TJ's Chevy
TJ's Chevy's Avatar
Re: What did you do to your truck today part III
Got my tremic ordered today!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 04-03-2015, 04:51 PM   #727
markeb01
Senior Enthusiast
markeb01's Avatar
Which model are you going with?
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-03-2015, 08:55 PM   #728
TJ's Chevy
TJ's Chevy's Avatar
I went with the TKO600 with the .82 od.
Old 04-04-2015, 09:20 AM   #729
Grizz1963
Grizz1963's Avatar
Went over to Martin's early this morning as Nicola was off to visit her daughter in Buckinghamshire for a couple of days.
He needed to move a load of stuff in his garage and shed, including getting his V8 and gearbox out the way, and then getting the straight six from his truck and it's gearbox out to the front of his carport for Über Cool, Andy to collect next weekend for his truck build.
I took my new to me, steering wheel and column with to test fit/offer it up to his upside down cab to see if it will fit.
So after the engines and sheds were sorted, we tried it out.
My current Moon style wheels rim and boss are both 9" from the dash edges.
The new one is 11" away, so I will need to do a bit of thinking around the best solution for form and function when I get to fitting it.
While I was there, Martin ripped the airbag and it's ring and wiring out as well.
When I got home I cleaned it all up, much improved.
So now the steering wheel and it's airbag bits can get sold as I do not want a modern wheel on my truck, still need to figure out what splines the column has and see what adaptor I may have to fit to get a new steering wheel fitted.
I personally like the older style stuff and love my Moon style that is deep dished and will be removed.
One of the things we realised this morning was that the small plastic cover behind the light and indicator stalk is missing.
Aaaaaaarrrgghhh !!!!
This means I now need to find one from somewhere, and one would expect most columns to come with them fitted, so not many about to buy or scavenge.
Anyway, if anyone knows where, or has one...... Please let me know.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 04-04-2015, 09:54 PM   #730
RaXaR117
Installed a cpp aluminium rear mounted gas tank. Have not run the lines up front though.
RaXaR117 is offline
Old 04-05-2015, 12:01 AM   #731
mattbert56
mattbert56's Avatar
Got 2 more 16.5 spare mud tires for the 65 for 20 bucks from another member. Incase I blow out my current spare on a trail or something. AND (I know it's not a truck) but i got a 4 bolt main 327 roller motor that runs like a raped ape from my coworker for the price of helping him install his new motor in his 70s 4x4 land cruiser. He's going LS and didn't want the 327 Anymore.
Well that didn't go as planned.
1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6
mattbert56 is offline
Old 04-05-2015, 03:22 PM   #732
mjh1965
mjh1965's Avatar
Well after getting back from a car show today I decided to get a little truck time in .
I managed to get both of the right side cab supports in
Once I had done the front one I tackled the rear one . A little harder to fit due to having to trim and fit it up to the front to rear brace and having to drill the holes to bolt it to the inner rocker
And the last picture showing the penetration inside
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline
Old 04-05-2015, 09:57 PM   #733
Lugnutz65
Lugnutz65's Avatar
Time for some epoxy primer. I'm putting this GMC hood on my 1965 Chevy C10 SWB SS.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 04-05-2015, 10:33 PM   #734
iceship
I did the lt1 throttle body bypass, new plugs and cleaned mass air flow on the old truck..
iceship is offline
Old 04-05-2015, 11:01 PM   #735
TJ's Chevy
TJ's Chevy's Avatar
Took it for a nice 20+ mile cruise. Thing ran flawlessly...minus a squeaky wiper and a leaky windshield and no front turn signals(who cares right?). 2500 rpm is optimum highway cruising for that thing. Love it!!!
Old 04-06-2015, 01:42 AM   #736
Grizz1963
Grizz1963's Avatar
Nothing like a bit of good penetration ehhhh??
Well done buddy.
Old 04-06-2015, 08:54 AM   #737
rickywideglide
rickywideglide's Avatar
Size:  38.2 KBgot shock relocators installed,and adjustable panhard bar in . something didnt look quite right ,check here on forum, put upper mounts backwards no biggie at least its just four bolts and not rivits
rickywideglide is offline
Old 04-06-2015, 05:28 PM   #738
Grizz1963
Grizz1963's Avatar
Not a lot to the truck, but while stripping a donor bike......
One of the nice things we discovered about the tail end of the little bike is that it will also be donating its number plate bracket and light to the truck......
You see, every Chevy needs a little Honda in its life.
Thanks must as always go to Martin for coming over and creating havoc in my life, but also keeping me company and taking the lead on the stripping of the bike, he has clearly done this a few times before, and it may point at a very misspent youth......... Only he will know.
Old 04-06-2015, 05:49 PM   #739
rickywideglide
funny my tag light is off a harley
Old 04-06-2015, 08:15 PM   #740
dwcardfan
dwcardfan's Avatar
Mounted steering wheel and mocked up shifter.
dwcardfan is offline
Old 04-07-2015, 06:07 PM   #741
J & E Speed Center
J & E Speed Center's Avatar
I filled in the license plate recess. Going to install the factory bumper with the roll pan. Also ordered up a set of 49 Pontiac tail lights frenched into the tail panels.
J & E Speed Center is offline
Old 04-07-2015, 06:33 PM   #742
65Gregg
65Gregg's Avatar
The cold air fairy stopped on my door step today.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 04-07-2015, 06:34 PM   #743
65Gregg
65Gregg's Avatar
That gets installed when this project is finished.
65Gregg
Blue long bed
White TBSS
61 Impala
65Gregg is offline
Old 04-08-2015, 09:41 PM   #744
pimpston65
pimpston65's Avatar
added more parts to my stash!!!
pimpston65 is offline
Old 04-08-2015, 11:01 PM   #745
earl84
I hope you post some pics when this is completed. Seems like that would look REALLY clean.
earl84 is offline
Old 04-08-2015, 11:01 PM   #746
earl84
Ooh, nice!
earl84 is offline
Old 04-09-2015, 01:04 AM   #747
pimpston65
pimpston65's Avatar
mocked up my locking hubs, i need either a spring backing the inner hub or a spacer to push the inner hub out to make a positive lock!!!
Old 04-09-2015, 01:07 AM   #748
pimpston65
pimpston65's Avatar
with outer shaft pulled out
Old 04-09-2015, 01:08 AM   #749
pimpston65
pimpston65's Avatar
[QUOTE=pimpston65;7125593]with outer shaft pushed in, the spring will keep pressure on the gear and in turn the shaft to make a positive lok...
Old 04-09-2015, 02:34 PM   #750
Grizz1963
Grizz1963's Avatar
I got a call earlier today to say my wheels were ready for delivery back home.
So when I got in, there was a rather awesome pile of gifts waiting for me.
I think that going from this......
I am in awe at the finish.
Along with my exhausts antisocial thuggery, the eye searingly red rims and white hot new chrome, this project promises to look pretty decent as long as I do the body work justice.
Next job will be to source four decent 235/75-15 tyres.
I think I may have found some..... From Germany, a set of four, delivered for £306.00
If anyone has a better option, let me know.
Closed Thread
