04-23-2013, 01:46 AM | #7526 |
Re: What did you do to your truck today?
Very nice. Did you make your own lines or were they Pre-made? If Pre-made, where did you get them?
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
04-23-2013, 01:53 AM | #7527 |
Did a little mock-up to try and decide what color to paint the intake manifold. Spent hours cleaning and wire brushing, then painting... Only to realize that I torqued down the heads without using non-hardening sealer! Going to fix that on Saturday and paint some more pieces.
The air cleaner will match the final blue color on the engine. Those are temp v/c the ones going on it are Mickey Thompsons and will have the flutes and the M/T in the same color blue. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
04-23-2013, 02:24 AM | #7528 |
Didn't do anything to my truck but I did get my compressor hooked up so I can do stuff for my truck. I had the wires hooked up wrong in the plug I put together but got it figured out. It's in my laundry room so I only had to build an 8 foot long cord for it. Being single has it's advantages.
66 shorty |
04-23-2013, 08:43 AM | #7529 |
lowslow64 - I think I'm in love with your truck...
joedoh - can't stop looking at your truck - s w e e t with attitude... rideblueCO - very nice bit of work on those lines - please come do mine. Snowbound - did you try some rubbing alcohol to get the "rubber" parts to slip around better for you? It should flash dry fairly fast without residue. Liv'n the dream - rg |
04-23-2013, 04:23 PM | #7530 |
Got the front LED turn signals installed and working on the MH.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
04-23-2013, 06:46 PM | #7531 |
Busy Beaver today. On the left headlight the top adjustment screw was broken. Actually the plastic piece the screw screws into was broken. I had ordered 4 new ones from LMC they came today. So I got the tools back out and replaced them. It was actually easier than I thought it would be.
I should've ordered new springs for the headlights I didn't think to so next time I put together an order I'll try to remember and order new springs. Now I need to find a shop that can adjust them properly. I'll do the old shade tree trick tonight using the garage door. Posted via Mobile Device
04-24-2013, 12:06 PM | #7532 |
Been at it for a while now but it's slow moving with kids and wife work and home life, but I've managed to get a couple of things underway....
If you used to be...then i guess you never were. |
04-24-2013, 12:08 PM | #7533 |
Broke my neck looking at that Photo
Waiting on that guy, to tell me a Price on my Truck I hope its not outrageous
1971 GMC Sierra 1959 GMC 100 |
04-24-2013, 12:10 PM | #7534 | |
04-24-2013, 12:15 PM | #7535 |
04-24-2013, 04:07 PM | #7536 | |
04-24-2013, 06:00 PM | #7537 |
wowee there bobbylast.... what happens when you lose that 9/16 wrench?? must be heck trying to find it!!
I made a fixture to stretch my hood springs so i could powder coat them |
04-24-2013, 11:07 PM | #7538 |
I got my rear end blasted and coated with rust treater, replaced one seal so far and screwed up a spring holder on a backing plate. Good thing I have my old rear end to get parts off of. I wish I would have figured out what the gear ratio is before I took it apart I'm dying to know. Oh well I can wait till tomorrow. I need to take the brake parts off my other rear end, clean up all the springs and stuff, change the other seal, paint it with por15 and I think thats it. I'm still waiting for my trailing arms and wiring harness then I can get it all together.
66 shorty |
04-25-2013, 12:37 AM | #7539 |
Adjusted idle on carb,was ideling too high,lowered it just a tad,it purrrrs like a big cat now.
04-25-2013, 10:16 PM | #7540 |
Well, I went and looked at the ultimate add on for my truck... A 5 bay garage with a paint booth and a sandblasting booth!
If the guy agrees on the price I may be stopping work on the truck and the falcon and moving them to the shop after I do some cleanup work, repair the huge compressor and run lines, add more lighting and paint the place. I think the other smart thing to do would be to go ahead and buy the 65 1 ton truck I looked at last week, and turn it into a car hauler. I plan on renting out booth time and bay time to help cover the payments, which by the way, would be so cheap I could actually pay them by picking up sand blasting jobs. No pics of the place yet. Keep your fingers crossed! Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
04-25-2013, 11:03 PM | #7541 |
I got a coat of por15 on the new rear end and spent another 400 bucks at classic.
66 shorty |
04-26-2013, 12:03 AM | #7542 |
work on my 76 chevy luv.. tryin to get it straight again
efi 496bbc th350 custom brakes narrowed 9 coilover rear. |
04-26-2013, 10:53 AM | #7543 |
Just swapped out my fuel tank sending unit. HEY!!!! My gas gauge works!!! Now to re-gasket that carburetor...
04-26-2013, 11:13 AM | #7544 | |
or you can count the pinion tooth count and the ring gear count and divide the pinion into the ring count...
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
04-26-2013, 01:45 PM | #7545 |
Put some SS rail caps on Frank, I think he likes these better than the wood racks I concur. I could not find any for 60-66 any where, these are for a 73-80 I just trimmed each end a little...Vernski
04-26-2013, 06:39 PM | #7546 |
Bought a remanufactured PS kit to replace the current leaking parts.
04-26-2013, 09:28 PM | #7547 |
Spent some time at a local muffler shop getting a new cat installed on my civic and talked with the owner of this 56 Bel Air. He has done a lot of them. After he left the shop owner was telling me that the owner of the 56 was complaining about the new exhaust costing $280. The shop owner was running 3" dual galvanized pipe (one whole piece each to the mufflers) to the Summit turbo mufflers (provided by 56 owner), then to chrome tips. You ask me, that was one incredible deal!
Car was a complete frame off and has an IROC engine in it. The front clip was off. The owner trailered it there and I saw that he only had two lugs per tire installed and paint on some tires. Those Cragar stars are his junk rims! Posted via Mobile Device Posted via Mobile Device
04-26-2013, 09:40 PM | #7548 |
nice project hes working on
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-26-2013, 10:34 PM | #7549 | |
I finally got my parts from Performance Online so now I can start getting it together. My trailing arms are still at the coaters so thats going to slow me down. Plus I have school 3 days next week and test for my CDL Saturday after working 40 hours this week. I'm hoping to squeeze a few hours in on the truck tomorrow and Tuesday.
66 shorty |
04-27-2013, 07:45 PM | #7550 |
I used mine around the farm today. Then took it for a joy ride. Man those old tires scare me somtimes!
