#7551 |
![]() Join Date: Dec 2012
Re: What did you do to your truck today?
Used my Neighbors truck to Bring home Two Boats
1971 GMC Sierra 1959 GMC 100 |
#7552 |
Hooked up the overflow bottle, and cleaned up the wiring for the electric fan and switch. Going to a car show tomorrow, if there are any other trucks I'll post them.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb ![]() |
#7553 |
![]() Join Date: Jan 2013
Rebuilt the rear brakes with all new hardware and shoes, and got everything together to replace the oil pan gasket tomorrow.
Aaron 1964 K10 1964 C10 1965 Suburban 2005 Yukon |
#7554 |
#7555 |
![]() Join Date: May 2007
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
#7556 |
Took the yoke off the rear end only to find out I bought the wrong one
![]() Posted via Mobile Device |
#7557 |
![]() Join Date: Mar 2012
Patched some rust on the inside of bed.
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#7558 |
#7559 |
I got my 1966 parts truck 250ci started (1st time since I purchased it 4/4/13) and . . . I checked the compression! It's all good, so it will be going onto my 65 frame sometime within the next 2 weeks!
This is my makeshift gas can on the roof fuel pump! ![]() ![]() ![]() ![]() ![]()
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#7560 |
Um I watched it rain on mine with the door off,cuz I'm replacing the rocker...
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#7561 |
WOW! Racecougar... Booo-yahh!! That metal work looks great!!! Way to get at it!
Stopped over at my buddy Keith's Friday and he had some light fixtures laying there in his garage, so I asked him if he was putting up some more lights, and he said "Nope you are." I think he was tired of working in the dark at my place. My brother Johnny came up Friday night and helped me out, so I got some lights up in the garage. Saturday wired a couple more regular outlets, and one 220 outlet for my stick welder. Then started parting out the 63 doors I had bought for the vent-window assemblies - got one stripped. Try to get the other done tonight... rg |
#7562 |
Post Whore
![]() Join Date: Mar 2013
I put a tarp on mine this mornin. Seems like it wants to rain in my neck of the woods.
#7563 | |
#7564 |
Stripped the other 63 door for parts, then finished taking my fleetside bed sides apart.
Cleaned out the garage & with the back half of the 62's frame showing I now need to build a cab dolly to go totally frame off. rg |
#7565 |
Moderator
Put a dent in the bank account. Scored complete used side trim for my 65 C10 long fleet, and ordered a new front bed panel, wheel tubs, and stainless bed strips and bolts. Almost time to start a project thread!
#7566 |
ordered some engine parts and sent body out to paint
#7567 | |
66 shorty ![]() |
#7568 |
Post Whore
#7569 |
Painted the cab white and the hood black to match the rest of the truck.
#7570 |
Got the carb swap done to a Holly 4412, replaced the distributor, voltage regulator. Need to get a bigger air cleaner and replace valve cover gaskets. This weekends project so I can use it without fear of fire due to valve covers leaking oil on the exhaust manifold.
#7571 |
Finally got my trailing arms back from powdercoat. Got them in with only one extra trip to the hardware store!
66 shorty ![]() |
#7572 |
#7573 |
#7574 |
My buddy blasted the stock 78 HD spindles I had left over from the 62's front end conversion; then I primed and painted them to put into inventory in case I need to adjust ride heighth at some point.
Changed the starter in my 90 K2500 because it was toast. Cut all the old brake lines and bits of wire from the back half of the 62 - pondering the next move... rg |
#7575 |
Post Whore
Painted my 4 barrel intake today.
