Closed Thread
Old 05-01-2013, 01:47 PM   #7576
Blue_Aura
Blue_Aura's Avatar
Re: What did you do to your truck today?
Finished up replacing all my head bolts with new Fel-Pro bolts with sealant already applied. Now I have to redo the valve lash, since I had to loosen the rockers to get the socket in between them. Not too much work left to have an engine ready to be dropped in. Now I have to get my firewall and frame cleaned up and repainted.
Current Vehicles:
'62 C10 - 350 (current project), '03 Tahoe (C Series)
Some Past Projects:
'69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB
Blue_Aura is offline
Old 05-01-2013, 08:23 PM   #7577
robber grin
Pulled the 62 outside and cut the windshield out, started to strip the cab down... scraped what seemed like 5 lbs. of old Super Yellow of the ps door opening weather stripping.
rg
robber grin is offline
Old 05-01-2013, 09:09 PM   #7578
azdude1964
azdude1964's Avatar
Here is my new 1964 bbw longbed ..its gonna get restored .....stay tuned if you have a set of hubcaps i would be interested in buying them also need stock 283 air cleaner.
efi 496bbc th350 custom brakes narrowed 9 coilover rear.
azdude1964 is offline
Old 05-01-2013, 11:03 PM   #7579
markeb01
Senior Enthusiast
markeb01's Avatar
Got the Comp Cams bumpstick swapped into the new engine today.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 05-01-2013, 11:05 PM   #7580
mud.man.rj
mud.man.rj's Avatar
Which comp cam did you use. I just put a Comp Extreme 4x4 270H in my 454 lately, what a huge difference.
mud.man.rj is offline
Old 05-01-2013, 11:50 PM   #7581
markeb01
Senior Enthusiast
markeb01's Avatar
I went with the High Energy 268H in a stock 350. Should be a lot more fun that the OEM cam I've been running for the last 21 years. I've got a Richmond 4 speed with 2.64 low gear and a Dana 44 in the rear with 4.10's.
markeb01 is offline
Old 05-02-2013, 04:48 PM   #7582
donthekawguy
donthekawguy's Avatar
Got my rear end buttoned up, installing the upper rear shock relocators, new tailights and housings, new rear wiring harness. Just waiting on the Lowes guys to bring my replacement compressor then I will install the springs and maybe the rear end tonight.
66 shorty
donthekawguy is offline
Old 05-02-2013, 04:52 PM   #7583
hemifalcon
Why do your tail lights look off-centered??? Isn't there an aluminum housing for the lens to attach to?
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline
Old 05-02-2013, 05:18 PM   #7584
donthekawguy
I just noticed that. They came out all stuck together and I was so excited I didn't notice. Time for another trip to classic chevy.
66 shorty
Old 05-02-2013, 08:10 PM   #7585
robber grin
Stripped the PS door, continued taking stuff off the cab...
rg
Old 05-02-2013, 08:15 PM   #7586
hemifalcon
Like this--
http://www.customclassictrucks.com/f.../photo_02.html
Old 05-02-2013, 10:17 PM   #7587
donthekawguy
Like this--
They are kind of like that. They fit in the tail light recess. I ordered new ones from classic.
66 shorty
Old 05-02-2013, 10:24 PM   #7588
donthekawguy
Just went out and put on the springs and shocks. Getting closer! I should have the rear end in Saturday and then the detail stuff starts.
66 shorty
Old 05-02-2013, 10:51 PM   #7589
MikeS.
MikeS.'s Avatar
Took off the front gas tank to my MH, it was leaking. Took it to a radiator shop for repair.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline
Old 05-03-2013, 08:04 PM   #7590
robber grin
Pulled the 62's column, pedal assembly, built a dolly from scrap wood and pulled the cab off the frame.
rg
Old 05-04-2013, 05:35 PM   #7591
jbgroby
jbgroby's Avatar
Picked up the Hood from the painter, the bird is mounted (safest place for now) Damn she looks good. He's got the tail gate and should get that back soon. Then the bed and she be done.
jbgroby is offline
Old 05-04-2013, 05:41 PM   #7592
jbgroby
jbgroby's Avatar
One more
jbgroby is offline
Old 05-04-2013, 06:23 PM   #7593
markeb01
Senior Enthusiast
markeb01's Avatar
Adjusted the valves on the new engine today. It's just about ready to go in the truck:
markeb01 is offline
Old 05-04-2013, 09:00 PM   #7594
Vernski
Originally Posted by jbgroby View Post
One more
Looks good with the bird sitting on it Jake...Vernski
Vernski is offline
Old 05-04-2013, 09:54 PM   #7595
robber grin
W O W ! Hood looks great!
I got the 283 mounted on the 62's chassis where it belongs...
used the standard bell housing to locate and drill for side mounts - bottom holes on 78 cross member were spot on.
rg
Old 05-04-2013, 09:57 PM   #7596
baggedbigblock
Installed my 15x8 Front and rear smoothies and Coker G78's.
baggedbigblock is offline
Old 05-04-2013, 10:08 PM   #7597
robber grin
Man bbb, I LOVE your truck... looks great!
rg
Old 05-04-2013, 10:43 PM   #7598
jbgroby
jbgroby's Avatar
Vern The painter took his time to fill all the joints with seam sealer, so I never have to worry about water getting in the joints. Best way to go by far.
jbgroby is offline
Old 05-04-2013, 10:45 PM   #7599
jydbowtie
jydbowtie's Avatar
stripped the interior... started with floor first
jydbowtie is offline
Old 05-04-2013, 10:53 PM   #7600
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Wink Re: What did you do to your truck today?
Project: "Full Metal Yellow Jacket" Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Closed Thread
