#7601 |
Re: What did you do to your truck today?
New fuel pump installed today on my SB350. It started and ran well so I guess I did it right.
------ 65 Chevy C10 Fleetside |
#7602 |
BLAZER THIRTY!!
![]() Join Date: May 2007
not today but last thursday Holley 500!!!!!
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() ![]() ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
#7603 |
Still working on my 73 suspension/disc brake change over. Trying to bleed the brakes was driving me crazy. Pumping the brake pedal & bleeding didn't work, gravity bleeding didn't work, using a Mighty-Vac didn't work. I've NEVER had this much trouble getting brakes to bleed. So while at work I cut up a piece of 3/8" scrap aluminum slightly bigger than my master cylinder with a rubber gasket to match. I drilled & tapped the plate to 1/8" pipe thread, installed a regulator & ball valve, topped off the master with brake fluid, chained down my contraption, cranked the air pressure to 14 lbs and bled my brakes. I now have firm pedal pressure and good brakes!!! Next, paint the motor and get it installed.
#7604 |
Senior Enthusiast
Initiated the process of pulling my engine.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#7605 |
Post Whore
![]() Join Date: Mar 2013
I painted my side covers today. Blue was a little lighter than expected.
#7606 |
Post Whore
#7607 |
My son-in-law dropped off first of four homemade WWW's.
I leveled the chassis with the 283 on the side mounts and standard bell housing mounts - then checked the motor for level across the exhaust manifold and it was very close to being level as well. Blocked up the engine to keep the same position. Cut the bell housing cross member out and cleaned up the frame. Cleaned the FILTHY TH350C that I put in the 62 tonight. Replaced input and output shaft seals before I installed it. Worked on my filler tube since it was dinged up at some point. Leveled engine and tranny and sat the tail-shaft on a jack stand. Pulled some string from yoke to yoke... Stared at it for 20 minutes since it seems so high in the frame (to me anyway). rg |
#7608 |
I went from THIS
![]() to THIS ![]() to THIS ![]() All by myself in just under 4 hours. (OK, a friend helped me lift the engine out, but I had it all set up ![]() So the 250ci is now out of my parts truck and getting ready for a freshen-up. ![]()
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#7609 |
Dropped the TH350 today so I can install the correct size flex plate for the new starter. The old starter blew the nose cone to pieces over the weekend because the PO used about 1.5" worth of washers to shim it in place so it would mate with the flex plate. As luck would have it, the supply store ordered the wrong size flex plate
My truck ain't dead, it just smells funny. |
#7610 | |
![]() Posted via Mobile Device Posted via Mobile Device
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
#7611 |
Got my new AC compressor mounted.
#7612 |
you are in Canada why do you need a/c
http://s1299.photobucket.com/user/jb...23904108567829 |
#7613 |
I got the rear end in, hooked up the shocks, put in the new track bar. I still need to put the driveline in, replace the rubber brake line, fill the diff and put all new brake stuff on. It's nice to have all new shiny parts on!
66 shorty ![]() |
#7614 |
Back home. Took the 1962 out for a ride and updated my build thread. Got the hood back from paint, final bodywork no seams, just in time to get to show on Sat. Working on striping doors.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#7615 |
Cleaned for show, set ride height. Lil low, hit stops without the rear shocks.
#7616 |
#7617 |
![]() Join Date: Mar 2012
#7618 |
I tried to install the new rubber line for the rear brakes and it wouldn't come lose from the hard line. Good thing I got a new complete kit last week. But the rubber line is the wrong size so I need to call classic parts and see what to do. They have the wrong line listed on the site for my 66.
66 shorty ![]() |
#7619 |
![]() Join Date: Dec 2012
Nice white truck man
1971 GMC Sierra 1959 GMC 100 |
#7620 |
Picked up a nice gauge set and cleaned the garage so I can start bodywork.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
#7621 |
Went to the Bank and Cashed my Government Check I got and turned my 20's into one HUNDRED dollar bills ...Got a trailer to pick up tomorrow and go get my Truck
#7622 |
![]() Join Date: Sep 2011
I got the 2nd gas tank back from repair and installed in the motor home.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
#7623 |
Make this my first post-
Installed some 64 Cadillac Hub Caps on my new 64 Custom. If you know about Caddy caps you know this is not any easy task! LOL ![]() ![]() ![]() Used them as a cheap way to cover the rusty chrome mods it has on it! ![]() As you can see I also took off the All Terrains in favor of some passenger car tires. 3" whites coming soon! |
#7624 |
Nice truck!
Welcome to the board! I would have never thought hubcaps would work those rims. Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
#7625 |
