Closed Thread
Old 09-29-2013, 09:26 PM   #1
ClemsonChevy
8 vehicles only 4 that run
ClemsonChevy's Avatar
Re: What did you do to your truck today?
Took engine down to replace gaskets. Intake to exhaust gasket was gone. I took the timing cover off with the pan still on. Am I gonna be able to get it back on with a good gasket sealed surface? How far would I have to lift the engine to do the oil pan and rear main seal?
95 2500 350 w/ 3.73
72 GMC 1500 SWB stepside
65 Chevy C10 SWB stepside
72 Chevy C10 LWB fleetside
ClemsonChevy is offline
Old 09-29-2013, 10:13 PM   #2
Lugnutz65
Lugnutz65's Avatar
I installed the HEI on my 250ci. Still have to play with the timing and plug gap.
https://www.youtube.com/watch?v=1mUh_ceeX8k
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 09-29-2013, 10:19 PM   #3
mud.man.rj
mud.man.rj's Avatar
Nothing like electronic ignition over old points, a good step up.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 09-29-2013, 11:12 PM   #4
'65 chevy lover
Finished up installing the fuel pump. After that it was removing a broken right exhaust manifold...was quite the PITA!!
'65 chevy lover is offline
Old 09-30-2013, 03:07 PM   #5
verdell
verdell's Avatar
Cool Re: What did you do to your truck today?
Spent the weekend redoing my Apache in Hot Rod Satin Black. This "satin" has a little more gloss than I'd like though. Still have work
to do on the tailgate but I hung it on to see what it would look like. We'll be "Cruisin the Coast" next week!
verdell is offline
Old 09-30-2013, 03:10 PM   #6
Lugnutz65
Lugnutz65's Avatar
First picture looks more glossy than the 2nd. Looks good to me, but you should make it how you want it. Keep up the good work.
Old 09-30-2013, 07:14 PM   #7
mud.man.rj
mud.man.rj's Avatar
Maybe the gloss will dull up after a bit of weather and sun.
5.0 4spd std.
7" lift w 35's.
Old 09-30-2013, 08:36 PM   #8
markeb01
Senior Enthusiast
markeb01's Avatar
Turned out very nice! Have fun at the event.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 10-01-2013, 07:54 PM   #9
verdell
verdell's Avatar
Thanks, means a lot coming from you guys. Can hardly
Wait to hit the Gulf Coast next week! We always have a blast..
verdell is offline
Old 10-01-2013, 07:58 AM   #10
robber grin
Looks GOOD verdel - love the black!!
robber grin is offline
Old 10-01-2013, 08:50 AM   #11
FetchMeAPepsi
FetchMeAPepsi's Avatar
I rebuilt my first transmission and got it cleaned and painted. Today it'll be installed.
Step by steps:
Remove primer to reveal original paint
Rebuild a carburetor
See My Build - Cecilia!
Some people are like slinkys. Not worth much but funny as heck when pushed down stairs.
FetchMeAPepsi is offline
Old 10-01-2013, 05:10 PM   #12
lowslow64
lowslow64's Avatar
Finally finished the truck, just in time for the GoodGuys Show this weekend
lowslow64 is offline
Old 10-01-2013, 09:28 PM   #13
19666Trucker
19666Trucker's Avatar
Killer job you should head out to phx az in November for the git down
19666Trucker is offline
Old 10-01-2013, 07:59 PM   #14
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Drove the wheels off that mutha!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline
Old 10-01-2013, 09:24 PM   #15
JBX66
JBX66's Avatar
Figured out passenger's side door lock, turn signal switch/ relay thingy, Brake lights and backup lights all don't work/ acting weird. Also some bodywork is in order to be done.
Yay! Something else to do besides homework this weekend.
White 1966 C10 LWB Fleetside
1983 Mercruiser Marine 305 V8/Chevelle 4spd
"Ellen of Truck"
JBX66 is offline
Old 10-02-2013, 02:52 AM   #16
familyfast64
familyfast64's Avatar
I purchased all the necessary brackets to convert my throttle rod to throttle cable so I can hook up the kickdown cable correctly. The bracket interferes with the throttle rod but a throttle cable doesn't work with the stock pedal. It has to be attached to the firewall and bracket at the intake and carb linkage. I also purchased new return springs, brackets, wire looms, and blower motor. Im going to purchase the lokar accelerator pedal assembly and after a total of 90$ for the brackets and150$ for the pedal I will finally be able to hook up the kickdown cable! Wahoo.
I did put in the blower motor. The old,sealed, unit was leaking. The new one is not a sealed unit with fluid like the old one but it fit right in there. Still doesn't work tho so I'm thinking the... What is it? Resistor or switch... I don't know but there's another part that I've read fails often and should be the culprit. Seat belts, radiator overflow and oil catch can for pcv is next. Then I want to tint the windows and hook up some underglows that I took on trade last year. Whoop whoop. She's running good tho and ran about 250 miles today without a hiccup.
Live and let live
familyfast64 is offline
Old 10-03-2013, 09:25 PM   #17
pdxhall
pdxhall's Avatar
I bought a tailgate and a custom comfort option bench seat frame. Now that I've got the frame I can go ahead with my bucket seat project. I also blasted my radiator support a few days ago. It the rain stays stopped tomorrow it get some epoxy primer.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline
Old 10-05-2013, 11:49 AM   #18
markeb01
Senior Enthusiast
markeb01's Avatar
FYI - on both the economy and deluxe heaters, the resistor is found on the firewall side of the heater ducting between the blower and the deflector as shown in these 1960 schematics:
markeb01 is offline
Old 10-03-2013, 09:55 PM   #19
zippeay
zippeay's Avatar
Got the bed put on, finally...
zippeay is offline
Old 10-04-2013, 06:57 PM   #20
donthekawguy
donthekawguy's Avatar
Put my tail gate on. Now I can go get my stuff out of my kids garage.
66 shorty
donthekawguy is offline
Old 10-05-2013, 08:52 AM   #21
earl84
Picked up most of the front end from a '74 3/4 ton from Jonboy over on the 73-87 side of the forum. Had everything but the lower control arms and power steering pump. Thanks Jonboy! Had a nice visit after loading it up.
Then went to the Ft Worth Goodguys show at Texas Motor Speedway, some REALLY nice stuff there. Found the brackets for the power steering pump for my SBC 350.
earl84 is offline
Old 10-05-2013, 12:07 PM   #22
zippeay
zippeay's Avatar
Thanks Mark I need that schematic soon when I put the heater back in.
zippeay is offline
Old 10-05-2013, 01:50 PM   #23
mud.man.rj
mud.man.rj's Avatar
I decided to not sell me big beast of a truck, just spent "way" to much on it and don't think I can replace it without spending a lot more, plus some people just don't understand what a truck is worth even when you ask 1/2 of what you have into it, so keeping it and adding more cool things. Oh ya.
5.0 4spd std.
7" lift w 35's.
Old 10-05-2013, 01:53 PM   #24
NEWFISHER
NEWFISHER's Avatar
Installed side moldings today.
NEWFISHER is offline
Old 10-05-2013, 04:11 PM   #25
donthekawguy
Very nice! When I get around to doing mine I'm going to take the lower piece that goes on the door and move it to the back of the bed to be a little different. I'll have to see how it looks before I put it on permanently.
66 shorty
Closed Thread
