Re: What did you do to your truck today!
Maybe some of you can do some video's on the metal work you do on your trucks, so the rest of us novices might learn something... Nice work......
Blasted, Primed, Sprayed with 2 coats of 2k epoxy bedliner. Made good progress today.
Took the ol truck and my little girl out this morning for breakfast. It is her 11th birthday and we have a tradition of going out for breakfast just the two of us. She still giggles when I punch the gas and the truck takes off. Good memories. Merry Christmas.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
GOOD DADDY !
![]() Keep this up and you'll reap huge dividends in another 20 years.....
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
Santa brought me some R&M wire looms. Nothing fancy but helped with routing a bunch.
Went from ![]() To this ![]() ![]() ![]()
Owner: Times Are Tough Toys 92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it. 89 Mercedes 560 SEL, Merdle. Wrecked 71 Chevy K20, Clifford, BB and 1 Tons |
Every little bit helps, ^^^looks good.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
Came on the truck. No telling where it came from. The engine has been in since the 80's.
Big block. mmmm ya.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
Installed my clutch petal getting ready for my auto to manual trans swap.
VWNATE1 ,trickflow make an oil extension ,i have one on my engine .makes filling the oil easy.got it from summit
Since it was warm here today & no wind blowing, I spray painted my visors black.
#13 |
blasted some more parts today.
got my hinges put together and finished up. and finally finished fabbing my trans c member it was also blasted and primed today. i put a frosty beer can on my ta. c member before it was fully cured you can see the can ring right by the ece logo ![]() tomarrow lube finished parts and paint c member. and reblast my f'ed up blackend door parts. and prepare to FINALLY PERMENETLY! after one year mount my cab ![]()
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#14 |
Mailed out my application for my 60's plates drove her 2 hours and got some Moto seat time in...bought some new belts for her.....stopped only 4 times for gas....ahhhhhh
Roll Tide! '69 C20 Longhorn 396 |
#15 |
![]() Join Date: Dec 2013
Installed new window regulators. Finally after owning the truck for 2 weeks I can roll the windows up and down. Thanks to the help from the Forum it was an easy fix. Thanks Guys.
#16 |
Yesterday I received my weatherstrip order from WES at Classic Heartbeat.
I also picked up my Craftsman Double Angle Flare Kit at SEARS last week. I'm very eager for spring to arrive so I can get back on my truck! |
#17 |
Fun Stuff
![]() Join Date: Jan 2010
I designed a marker light cover plate that allows the deluxe lens to be mounted from the back, only the reflector part shows through. I think it is going to be cool.
Jay 68 C10(project) 88 Honda Accord(DD) 93 Chevy Astro EXT 2wd |
#18 |
The Niner
![]() Join Date: Nov 2010
Cleaned up a lot of the stains on my intake with Freon tf solvent. I'm pretty happy with the results.
First pic is before, the last 2 are after.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
#19 |
Well the other day I noticed that my volt meter was reading a little under 12 volts,so I look under the hood and noticed that the bolt that holds the bracket under neath the alternator broke to where its bolted to the passenger side of the head on the engine..So I attempt to tap out the broken piece left in the head. I drilled a hole in to the broken bolt. ( That was no fun ) I tried to use an extractor to get the piece out, but I needed to drill the hole in further so I could tap in the extractor. I could get to go in as soon as I turned the the extractor it would just pop out. I tried to drill the hole another size bigger, but still I couldn't get it to come out. Anyone have any other Ideas as to how I can remedy this? It seemed so simple...but.... no.... Is there another type of bracket I can use that can mount else where? The alt. is mounted on the passenger side of the engine.
The top pic is where my head ache is.. And the bottom pic is the bracket that is on there now. Maybe some can tell me how to use a different mounting point... Thanks one and all....... |
#20 | |
86 Scottsdale
Get a carbide cutter for a dremel, and take it slowly. I had a cheap extractor break off in a bolt like yours one time. I used a carbide bit with a ball tip like this one ![]() Note: Keep a magnet handy if you're going to do this with the head on the vehicle to try and corral all the shavings you can. I'd probably suggest pulling the head if that isn't a blind hole so you don't introduce fine metal to your engine/cooling system. |
#21 | |
Fun Stuff
#22 | |
#23 |
Well guys, I appreciate all your suggestions, and I will further to try tomorrow. In another forum I found a lot information and found another way to mount the alternator. They suggest I use a different mounting brackets you can mount at mid point on the passenger side with a special lower bracket that mounts to the back of the alternator that mount off the water pump. They use these brackets with engines that don't have the drilled holes in the heads. I just might do that instead. I figured out why the bolt broke in the first place. the PO put a different engine in the truck and sort of slapped it together. It didn't have the bottom bracket that goes off the water pump, so more or less the alternator was just hanging off the top bracket and created tension and that top bolt snapped, so I will get the bottom bracket and will probably get that med point bracket and be done with it.
I will post my results either way in case anyone else gets in the same situation. Thanks again one and all.. Great forum....... |
#24 |
i installed my used cpp rear coilovers
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
#25 |
i finally re-installed the defrost hoses and vents! picked up the 2 1/2 diameter flexible kind from autozone. so much nicer on those cold mornings
'69 c10 longbed granny 4spd 292 "Behemoth" ![]() '67 c10 longbed granny 4spd 292 "Burzum" some pictures of my work in progresshttp://photobucket.com/zaeea R.I.P. Corey "Flattus Maximus" Smoot 11/3/11 You will be missed. Your sound lives on. |
