Closed Thread
Old 08-13-2013, 11:03 PM   #7676
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today!
Broke out my new Harbor Freight drill na d wire wheels and began zizzing the rust off the very bottom part of it ~ this looks very do - able , it'll just take some time .
I also may have located a running & driving 292 TH350 equipped donor for my '69 C/10 , I go to look at and maybe buy it to - morrow afternoon .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-14-2013, 04:58 AM   #7677
sboris
sboris's Avatar
Originally Posted by Mr Chevorlet View Post
Worked on the bed not today but this week
Looks really nice.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline
Old 08-14-2013, 07:32 AM   #7678
Gor77
Gor77's Avatar
___________________________________
Dima
1970 Chevrolet C10 stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=569197
Gor77 is offline
Old 08-14-2013, 05:59 PM   #7679
Dunenutt
Newbee
Dunenutt's Avatar
Originally Posted by MLB57 View Post
Broke my new windsheild
Thats why I sit back with a beer, and let the professionals cuss at it.
Dunenutt is offline
Old 08-14-2013, 06:01 PM   #7680
Dunenutt
Newbee
Dunenutt's Avatar
Originally Posted by budman k20 View Post
Put on the camper and a loaded trailer then I drove it 25.3 miles and put in 4 gallons of gas! After that test I decided I need a cheaper way to get to Milwaukee for the HD party!
Cool truck, and camper combo!
Dunenutt is offline
Old 08-14-2013, 06:02 PM   #7681
In The Ten Ring
I continued to wrestle with my drum brakes and right when I think I've won......I find the drums won't go back on!
http://i1313.photobucket.com/albums/...ps10bb3532.jpg
In The Ten Ring is offline
Old 08-14-2013, 07:28 PM   #7682
72Souper
72Souper's Avatar
My dad and i watched a window installation video (i have a truck with stainless trim), looked pretty "easy". Then i read a lot of experiences on this board. Decided it was anything but "easy". We took it to an autoglass shop and it took them 3 tries to get it in! Best choice we made in a long time!
72Souper is offline
Old 08-14-2013, 07:45 PM   #7683
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
In The Ten Ring (Post #7738):
Nice truck. My taste veers away from the Lincoln (or whatever) hood ornament.
But that's one of the great things about these trucks...You get to do whatever you want.
Okay, would it be idiotic to suggest that you have to make sure you're adjusted all
the way "in" before the drums will slide over the shoes?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-14-2013, 07:50 PM   #7684
In The Ten Ring
My dad put that hood ornament on there in the late 1970's....it's part of her as far as I'm concerned....but I feel ya man.
I tried turning the adjustor nut all the way "in" but no change. It's odd as yesterday, when I had one of the sleeved washers in backwards...the drum slipped right on like nothing!
I've had suggestions to remove the strut, replace the parking brake cables, bleed the brakes....oh man! I am in over my head here...
Old 08-14-2013, 08:00 PM   #7685
magwakeenercew2jh
If you got one?.....You'll get it.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-15-2013, 11:53 PM   #7686
ekgguy
ekgguy's Avatar
Spent most of the afternoon cutting out this...
so I can make enough room for these...
Matt
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655
"Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!"
ekgguy is offline
Old 08-16-2013, 12:43 AM   #7687
magwakeenercew2jh
Not disrespecting your homage to your dad...But I thought this would look nice:
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-16-2013, 01:29 AM   #7688
WIDESIDE72
WIDESIDE72's Avatar
I adjusted the float on my qjet on the "army truck budget build", fixed the oil leak shop that painted truck also tore engine apart to detail it (dont ask sore subject) and when they added oil i guess they forgot that small detail. I also noticed when they pulled the engine they removed the frame stands and those bolts are loose too. I got my sanden compressor mounted for the vintage air. I bought the kit used never installed for $700 and po lost a lot of the bolts for brackets. I called vintage air and they wanted $50 just for the bolts nuts an spacers, so i said "no thanks" and made a trip to tractor supply across the highway and came back with everything i needed for about $6.
WIDESIDE72 is offline
Old 08-16-2013, 01:40 AM   #7689
WIDESIDE72
WIDESIDE72's Avatar
A while back i bought a new underhood harness for my 72 as the old one was a rats nest. Since i was planning on going with HEI, i bought a harness that is supposed to be "plug and play" from Brothers. I started the truck maybe twide then tore it apart for paint, having never actually driven it. I am putting the teuck back together and reinstalled the harness. I started the teuck fine and drive it about 100 yards and it quit. I checked and have 12 volts at the pink power wire plugged in to rhe dist with key on not cranking. When cranking it drps to 8-9 volts. I had to unplug the pink wire at the dist and hook a hot wire from the battery to the dist to get it to run. I posted my issue on the forum and with some input from good people here and some research on my own i have a few things to try tomorrow. 1. Check grounds 2. Lube connections 3. Possibly install a relay if it still wont work.
Old 08-16-2013, 01:47 AM   #7690
WIDESIDE72
WIDESIDE72's Avatar
I tried to install the pre bent exhaust down pipes to the rams horns but it appears the pipes are too large as they wont bolt up. Where the pipe is flared for the donut it is too large for The pipe to fit between the studs. Nice Hooker system all pretty bends but im going to have to take it ti a muffler shop after all.
Old 08-16-2013, 01:59 AM   #7691
SCHRUMGMC
SCHRUMGMC's Avatar
Took the cowl off..Got her running
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline
Old 08-16-2013, 03:21 AM   #7692
dakattack7
Active Member
dakattack7's Avatar
Spent 6 hours installing retro sound.. Ran into multiple problems and it's probably coming out to fix them, but it has to in a few weeks for ac duct work anyways so. Thought I shorted it out and fried it after all the work but I didn't! Yay
dakattack7 is offline
Old 08-16-2013, 09:45 AM   #7693
zellway
zellway's Avatar
I have a retrosound in my short bed and suburban. My first install was kinda long and mistakes were maid. It's a good unit and worth the work. Hope you like it as much as I do.
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline
Old 08-16-2013, 09:48 AM   #7694
zellway
zellway's Avatar
Pulled my old 3/4 out of the back yard, gave it a quick bath and fluid change. It's nice to have it back on the road.
Erik
zellway is offline
Old 08-16-2013, 10:31 AM   #7695
Dobster
I so want to do this to my truck... I am not that talented. Awsome!
Are you shorting the rear end yourself? I have a 5.3l that just blows the tires off...I would like to see more of this build ! ! !
Dobster is offline
Old 08-16-2013, 11:46 AM   #7696
ekgguy
ekgguy's Avatar
I am not going to shorten the rear end or narrow the frame. I ordered a set of 15x12 wheel hoops from the EBAY and I am going to have the centers welded in so I can have a custom backspacing and keep the stock width.
The wheels in the picture are going away.
Matt
ekgguy is offline
Old 08-16-2013, 02:31 PM   #7697
BugzC10
BugzC10's Avatar
Installed Taylor spark plug wires and looms. Had to cut to length and crimp on connector/boots. Initially it was a PIA to get the wire through the boot, but once I figured out that liquid soap and a pair of hemostats were the ticket they went together easily.
Before:
After:
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 08-16-2013, 04:14 PM   #7698
twisty
twisty's Avatar
i took pics of the rear end i found to see what it came off of. so far ive had zero luck identifying it, the casting number doesnt make sense and the stamp on the passenger side axle tube doesnt decode from any site ive been able to find. it starts with THS which isnt anywhere on any site. i also found 4 wheels and hub caps from a 2000ish astro van for it. i guess ill have to pull the cover tonight and see what is inside. may as well change fluids while im in there.
twisty is offline
Old 08-16-2013, 10:12 PM   #7699
sKnNyPpY
sKnNyPpY's Avatar
Finished replacing my upper and lower ball joints. She's riding nice and level now that the passenger spring is seated properly and the driver's side is now right side up (put it in upside down after spraying brake cleaner in my eye)
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline
Old 08-16-2013, 10:17 PM   #7700
In The Ten Ring
I picked up my renewed gas tank today and I must say, it does look impressive. I still think I'll go on and order a new one, just to be sure.
I also called around and found a service center that will turn my drums for $15.00 each.
Closed Thread
