![]() Join Date: Nov 2007
Re: PO has me PO'd
Looking really good Jim. That engine should purrrrrr.
Re: PO has me PO'd
what's the part numbers on those heads? looks nice
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
![]() Join Date: May 2006
Re: PO has me PO'd
Thanks AJ, eventually I'll build it for some low end torque, maybe a BigSmallBlock 400 stroked, and then I'll be in your Cubic Inch range
Mike, gotta get back to you on part numbers...congrats on the Masters first attempt on the flange removal was a bandsaw, to get most of the meat off. Then some creative grinding, couldn't find my hub nut removal thingy, so I just used the cutoff wheel. It got into some tight spots, so it worked out. Don't use it without the guard!!! Studs had to be chased, junk part that needed extra work! A little anti-seize, a coat of Eastwoods Stainless Steel coating and I will be good to go ![]() ![]() ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 07-27-2010 at 01:27 PM. |
Re: PO has me PO'd
Got an hour or two to work on my fuel line over the weekend
![]() ![]() IMHO, GMPP got this one wrong, 1/8" gap between intake runners and heads.Intake bolts up, just doesn't cover the intake ports...gotta buy another intake ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Can't wait to retire!!
Re: PO has me PO'd
Looking good Jim.
When are you driving it over?
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 Last edited by Chevyman63; 08-01-2010 at 10:52 PM. |
Re: PO has me PO'd
Lookin' like Spring of next year
Re: PO has me PO'd
[quote=
IMHO, GMPP got this one wrong, 1/8" gap between intake runners and heads.Intake bolts up, just doesn't cover the intake ports...gotta buy another intake [/quote] OK, seems like I was wrong, GMPP was right!!! Talked to them today, even had a case started, the smmmmaaaalllll print states that you must use a extended runner intake manifold (by .200") to run Vortec heads, seems that even though the early style intake will bolt up, w/o the extended runner design there will be a gap My apologies to GMPP, you were right, I was wrong. Should have read all the printed information on the page, as it states to use a specific intake
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-03-2010 at 03:40 PM. |
I miss this truck.
Re: PO has me PO'd
That's amazing to me. Is there going to be an intake out there that does cover those gaps?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
Re: PO has me PO'd
Those heads appear to be the Vortec style bolt pattern with the taller intake ports.
#10 | ||
Re: PO has me PO'd
Why they even bothered to drill and tap holes for the early style intake is beyond me Jeg's said they run into this guite a bit
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-02-2010 at 03:39 PM. |
#11 | |
Re: PO has me PO'd
If I understand this correctly, they weren't the heads you wanted in the first place but you installed them anyway?? You won't have to worry about lack of low end torque with vortec heads. They only have 170cc intake runners, and with the taller ports they have a better short turn radius. They make gobs of torque. They are actually a much better choice than the standard port heads you initially wanted. |
Re: PO has me PO'd
[QUOTE=Firebirdjones;4119502]If I understand this correctly, they weren't the heads you wanted in the first place but you installed them anyway??
---------------- At the time I installed them, I thought they were the heads I ordered, until I realized it, it was to late. My focus was on the poor quality of the machining, and I just forgot to check the details You won't have to worry about lack of low end torque with vortec heads. They only have 170cc intake runners, and with the taller ports they have a better short turn radius. They make gobs of torque. They are actually a much better choice than the standard port heads you initially wanted. ----------------- THAT makes me feel better, hope it holds true
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-03-2010 at 12:47 AM. |
#13 |
I miss this truck.
Re: PO has me PO'd
AHHHHH, now I see. Didn't realize that was one of the differences with the Vortecs. I'm not as amazed now...
I can see your frustration, though. If it were me, I'd probably get a SCREAMING deal from Jegs on the right intake, like their cost plus free shipping. They're going to turn around and get the money back out of GMPP anyway...
#14 | ||
Re: PO has me PO'd
![]() Quote:
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-03-2010 at 02:30 PM. |
#15 |
Too Dumb To Know Better
Re: PO has me PO'd
Bummer!
#16 |
Re: PO has me PO'd
back to where I was a month ago...got to do some engine wiring for the engine temp. and fan wires, still working on the electric choke
March was kind enough to send me the bolt and spacer for the alt. at no charge w/ shipping since I lost it in the workshop, well, its not lost just put it in a safe place so I wouldn't misplace it ![]() ![]() ![]()
#17 |
Re: PO has me PO'd
One step closer!!
![]() 2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
#18 |
Re: PO has me PO'd
Thanks Tim. Back to collecting parts for the final push
![]() Cliff Ruggles for the Quadrajet parts
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-06-2010 at 02:32 PM. |
#19 |
Re: PO has me PO'd
Got some time to cut off the last flange on the exhaust manifold, cutoff wheels do a very good job on cast iron, just a little filing and ready for coating
![]() ![]() Picked up a console from Olskool ![]()
#20 |
Re: PO has me PO'd
I ran into Jon (tri-pro) at Carlisle today... looks like he's doing well...
#21 | |
Re: PO has me PO'd
I guess he is the top banana, lol. Did ya pick up any parts??
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-07-2010 at 10:29 PM. |
#22 |
Re: PO has me PO'd
Don't really need any large parts, except bed wood and paint (to include body work). Sourkraut (John) bought some bedsides and header panel off him though.
I asked when he was having a banana eating contest at the show! I figure the local Hooters girls are available for a dual promotion event! ![]()
#23 |
Re: PO has me PO'd
Vay- K Montana.....Yellow stone
#24 |
Back in the sticks
Re: PO has me PO'd
Ha, I just drove past there last month on vacation myself. Didn't stop in Y-stone. Wife had a bad experience there with one of our housecats that got loose in the park. Did eat at Taco Johns tho. Tasty...
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#25 |
Re: PO has me PO'd
Awesome...have a great time Jim!
