#751 |
Re: 69 GMC "Ol' Blue"
I built a clutch linkage with rod ends like yours for my vette years ago. Makes the clutch really smooth.
Your truck is looking really good. Lots of thought is going into it and some cool mods!
Mike 1971 C10 350 1969 C20 396 1979 Corvette L-82 |
#752 |
Thanks Mike! I am having a lot of fitment issues due to the engine move, but it's moving. I really need to get the 4wd lever and wiring figured out.
#753 |
Headers fit quite well, have seen way worse myself. Coming along nicely, lots of small picky stuff hey.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#754 | |
#755 |
![]() Join Date: Jan 2009
Looking great mike!! You just need to get it running and then you will really want to get it finished!
I found out that my 8 year old flowtechs have a giant hole where the four pipes join the collector. I was considering the same headman headers that you have, but since the flowtechs fit so well, I may go with them again. The thing i hate about the flowtechs is they have really cheap header flanges and I end up having to use aluminum gaskets to get them to seal off.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#756 | |
I'm not sure how well these headers will hold up, but what do you do ![]() |
#757 |
Today I finally worked on my rear brake lines. I now have them bent, but not completely tied down.
#758 | |
#759 |
![]() Join Date: Jul 2009
The brake line looks good Mike - one more step done. I'm counting on you to get all the wiring figured out so that you can answer my questions when the time comes!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ![]() 2001 GMC Sierra K2500 |
#760 | ||
![]() Quote:
#761 |
Man you on a roll now! Should sound great with the headers. Any luck with the 4x linkage yet?
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
#762 |
Hell yeah! Good job Mike, things are looking awesome.
You are really killing it, keep inspiring me haha
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
#763 | |
Thanks Jason! |
#764 |
Yesterday, I started mocking up my idea of where I want the clutch linkage to go. I think this will work, but just in case, I'm using the cheap scrap tubing instead of the chromoly stuff that I will finalize the design with.
![]() In this first pick, if you look through the hole below the steering column, you can see the top of the Z-bar. For this to work, I'm going to have to extend the bar up a bit. |
#765 |
Ok, if anyone sees an issue with my clutch linkage setup, please let me know!
#766 |
Making progress. So when do you think its going to get fired up? I would like to be there for that if I can?
#767 |
Not seeing a problem as long as it doesn't bind and you have full motion and can adjust the bar lengths for optimal pedal/throw out bearing adjustments I'm thinking it's good to go!
![]() Edit: Make as much room as possible between the brake and clutch pedal arms. It would suck to get something stuck in there at the wrong time.
#768 |
i would be sure to gusset or support your stand off on the pedal arm itself. if you rely on the tension in the bolt alone to hold it all i think it will begin to wiggle and wallow.
how is the z-bar pivot on the frame held in? it looks loose |
#769 |
That looks nicer than my hydraulic setup
#770 | |||
It's held on exactly the way it was in its stock form, but I may not have had it tightened down when I took the picture. Thanks!!!! I think it's turning out ok, just a bit more tweaking and I think it will be rocking! |
#771 |
![]() Join Date: Jul 2012
That clutch linkage looks great, Mike. It'll be one of those things you will feel bad about covering up with such frivalities as the cab and stuff...
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
#772 | |
#773 |
So, I've been out of town all week and don't have any new progress to report. I did realize that I never posted pictures of my latest mockup for the 4wd lever. I do have a lot of snaking and moving around to do here, but I think this will end up working out. I will have some items to address with the floorboard, but hey...we'll figure it out
![]() See how high the pivot point ends up having to be though. I am not sure I like that idea, but honestly I'm not sure if I have a choice. Nothing is set in stone here, so if someone has a better idea, I'm all ears. After sitting here staring at the picture, maybe it would be best to go back to the original mounting location and see if I could tweak the shifter to keep it out of the seat. Last edited by mjensen; 01-18-2015 at 01:49 PM. |
#774 |
Looks confusing with all those shifters, if left alone only you can drive it,,
#775 | |
