Old 05-23-2011, 08:06 PM   #751
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
Originally Posted by 68 TT View Post
Is that just the lighting or are your calipers cad plated? If they are cad plated where did you get them?
Not sure if they are plated but they are a gold ish color. Got them at autozone. 12.99 each.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-23-2011, 08:08 PM   #752
85burb
85burb's Avatar
Originally Posted by 68GMCCustom View Post
having that booster tank holding reserve vacuum for the power booster and a Wilwood adjustable proportioning valve to dial in the rear brakes...mine sill stop on a dime and leave some change.
The wifes 68 has 4 wheel durm breaks and they were fun some times. Her dad almost missed an exit one day at about 90 and when he got stoped all 4 drums were glowing red. Needles to say when it came time to turn the drums it did not go well at all.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-02-2011, 02:49 AM   #753
y5mgisi
Second Chance Program
y5mgisi's Avatar
So have you figured your mpg yet?
y5mgisi is offline   Reply With Quote
Old 06-02-2011, 07:06 PM   #754
85burb
85burb's Avatar
No i have not. I filled up friday and and drove friday to work 24 miles, to wash it 8 miles and work tues day therw today like 75 miles and still have little over 3/4 tank. Way better so far
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-02-2011, 08:33 PM   #755
y5mgisi
y5mgisi's Avatar
Sweet! I think that even if mpg was just slightly better, then it would still be crazy worth it from a drive ability standpoint! So jealous!
Old 06-02-2011, 09:49 PM   #756
85burb
85burb's Avatar
It does not drive like a new car but is way better then a carb to me. You have to let it run for a min befor putting in gear maybe 30 sec or so but it is way better then 4-5 mins with the carb
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-03-2011, 05:18 PM   #757
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
woah.....you still have to wait? I would have thought not.
I guess its because the efi computer doesn't have control of the MSD box?
Maybe you need to change your initial to 1000rpm timing?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 06-04-2011, 12:21 AM   #758
85burb
85burb's Avatar
Well when it start it goes to 1000 rpm then drops to like 600 then goes to 700 what i have it set at. It is still learning and it is cammed so that may be a factor in that. What do you mean by initial to 1000 timing. What should i try? If i punch it from idle it does not bog or miss or anything. That would be cool to have timing controll with this efi. All it would take is 4 extra connectors. cam, crank, 2 coil harnesses. Fast makes a controller for ls igitions but they still dont do that. They also sell a kit to put the hole fast maniflod on and control everything and it is self tuning. But price is outrages
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-06-2011, 07:41 PM   #759
85burb
85burb's Avatar
Well i am on day 9 on my gas and still have about half tank. Befor efi i could drive to work 6 days and that is it. So far it is tons better. Now if i run out of gas cause my gauge is stiking i will be a little mad. It has never moved this slow. Not even with old 350 in it. I cant wait to fill it up and check milage.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-07-2011, 11:42 AM   #760
okieraptor
okieraptor's Avatar
Wish I could drive nine days on a tank of gas! Must be nice. And to think I have a diesel!
82 chevy longbed(grey truck)first truck when i was 15!
okieraptor is offline   Reply With Quote
Old 06-07-2011, 01:24 PM   #761
68GMCCustom
yeah....but its like a 35gal. to 40gal. tank too!
Kurt -
Old 06-07-2011, 07:25 PM   #762
85burb
85burb's Avatar
Well tomorrow will last day on this tank. I only let it use 17-18 gallons. That is 1/4 tank or so. 11 days on this tank. That is a record for my truck. VERY Happy with the efi.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-08-2011, 11:14 PM   #763
85burb
85burb's Avatar
Yep 11 days to work and one short trip. Have not filled tank yet but that i around 15 mpg mixed city/hiway.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-14-2011, 07:04 PM   #764
85burb
85burb's Avatar
Well now i have a transfer case seal leak. It is the front output (front drive shaft) yoke seal i hope. It has been leaking for ever. I managed to spray off my t-case good last time i washed buddy and i parked over clean pavement to day at work and it is leaving a wet spot about 6 inchs around. Not a puddle just wet. Will try to replace it this week end. Any one know what size the nut is to take the yoke off? Thanks.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-14-2011, 11:23 PM   #765
85burb
85burb's Avatar
pic of what i should be doing sat. Does not sound too hard. Hope the yoke is not messed up. Also in the pic is my dads day pic. NEW SHOES. (My cat hates them.)
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-18-2011, 12:22 PM   #766
85burb
85burb's Avatar
I got the new seal installed today. Took under one hour. My yoke nut was bearly tight. I was happy to see i had about 2 qts of fluid left in my transfer case. It has been leaking from the day i bought the truck. When i checked everything to move to tx it was 2.5 qts low...that is how much they are supposed to hold. Good thing i checked it. I hope now it will stop leaking. I need to find a new front drive shaft tho. My slip joint is loose and my cv joint has some slack in it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-18-2011, 06:29 PM   #767
y5mgisi
y5mgisi's Avatar
Me too!
Old 06-29-2011, 04:29 PM   #768
85burb
85burb's Avatar
I am looking to get a more hp now. I will be making extra money soon and will have some to play so ideas are welcom. I will first replace my rear springs and blocks with a 6 inch lift spring to leavle out the ride. Then rebuild my rear end with the truetrak i have. Any ideas on hp increase other then nitro and forced induction? I also cant loose low end tq due to size.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-29-2011, 09:14 PM   #769
68 TT
Still plays with trucks
68 TT's Avatar
Some time on a chassis dyno to really dial in the tune would be a good place to start.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-29-2011, 09:25 PM   #770
68 TT
68 TT's Avatar
Did you ever get a set of headers to fit it? If I remember right you had problems with the ebay f-body headers.
Old 06-29-2011, 10:49 PM   #771
MTCK
MTCK's Avatar
Air in, air out. Headers, exhaust, a cold air intake if you don't already have one... You already have a cam, right? Heads would be the next logical step. Happy with your axle gears? A shorter rear end always helps the giddy up... A perfect spark and fuel curve tune also works wonders, as stated above.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-29-2011, 11:59 PM   #772
85burb
85burb's Avatar
I want a set of headers but none are avalible. Dougs said they have some in the works but everytime i ask he does not answer or has no idea. I have called everyone. The only ones that are said to fit is s&p shortys. I cant see spending 600 buck on shortys. BRPhot rods also said they had a set in the works but i have sent many emails and they say now they dont have any. So my options are keep buying sets and hope they fit or keep what i got and work around them. On the exhaust i have duel 2 1/4 pipes with h pipe and flowmaster 40s. I wanted a 2.5 inch or bigger but i was told by 2 exhaust shops that it would not make a difference. I am sure i am getting all the induction i need with a 1000 cfm 4 barrle throttle body and a edelbrock intake. As of now i have a 14x4 round air cleaner on it. Not sure if that is holding me back but i dont think so. I am sure my ignition could use some work but i cant really feel the difference when i change the curve or degrees. I want to dyno it but dont know where there is one around here. I do have a cam i think the specs are in my sig. Dont get me wrong it will boil the rear TIRE threw second gear if i punch it but i would like more lowend and normal driving range power. Seems like takes a lot of throttle to pass. But if i put it to floor it comes alive. Let me know if i am crazy or not. Or if i dont make a lot of sence.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 06-30-2011, 10:03 PM   #773
68 TT
68 TT's Avatar
A cold air intake will do wonders for you at all RPM ranges. With the open element air cleaner you are sucking in hot air once the engine warms up and giving up some power and efficiency.
Your cam is big enough that a little more stall converter will help get that tank moving better too. Not the easiest or cheapest thing to do in a 4x4 but it makes a big difference on a cammed motor. Somewhere around 2800 rpm will work well for your application and since it is a lock up converter it won't mess with your cruise RPM or freeway mileage. It will also put you further into the engines power band where you need to be to get moving easier and let you gain access to the power you already have.
You have enough cam and cubic inches that the headers are the next step. You might have to modify a set to make them work for you and stay on budget. Did you keep the ebay ones you picked up?
If you can cut out the offending tubes from the f-body set and cut up some mandrel U-bends to clear you can have a welding shop finish the job for not much cost, typically $60 and hour around here. You can rent (or borrow) a MIG welder to tack the cut tubes in place so the welding shop has no guess work to do as to how they are put together.
I had a muffler shop make and weld the modified tubes in place for the first set I did before I got my own welder. I just bent up a piece of coat hanger into the shape I needed and they matched it with tubing.
A set of inexpensive small block headers that fit your truck could be merged with a set of LSx headers if all else fails. Back in the 80's I did this to put a 428SCJ motor into a friends 73 Mach 1 that never came with the 428 as an option so no headers to fit it existed at the time. It worked great and cost a bunch less than a scratch built custom set.
With the cam you have the LQ4 should have no problem making 400 hp at the engine using the stock heads if you tune it right. The muffler shop built 2-1/4" exhaust system is definitely a restriction. Their compression bends are reducing the pipe to less than 2" in cross section and create severe restrictions to air flow. A mandrel bent 2-1/2" system will make a huge difference. A set of Flowmaster mandrel bent tail pipes will give you a majority of what you need to fit the Suburban. The rest can be done with a couple mandrel U-bends and some sections of straight tubing.
http://www.summitracing.com/parts/FLO-15803/
The Hooker Aero Chamber mufflers sound great and flow better than the Flowmasters for about the same amount of money. Lots of clips on youtube so you can see what they sound like. I have put them on two of my vehicles and liked them a lot. Less drone than the Flowmaster with a similar sound.
http://www.summitracing.com/parts/HOK-21502HKR/
Found this test listing for some ideas of HP & sound level differences.
http://www.facebook.com/note.php?note_id=371165168511
They don't say which Flowmaster muffler they tested so it is kind of vague but gives you some idea how they do.
Old 06-30-2011, 10:53 PM   #774
85burb
85burb's Avatar
Thanks for the info. The exhaust i think really sucks. On the driver side the factory maniflod puts the exit inside my frame rail so they had to make a thight s bend to move it out. The pipe he used fits inside the 2 1/4 pipe so i am guessing it is a 2 inch. But that is all they could do. I may just take my chanses with the mid lenght headers. They say they exit at the bellhousing area so should not matter if it is 4x4 or 2wd. Maybe i can set up a deal with them where i pay and if they dont fit i get to send them back and get all my money. Really wish i could get long tubes. I have no garadge so modifying a set is not an option now. I sold the fbody headers long ago. They would take so much work it would be better to just get the flanges and start from scratch. I will have to call brp back.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 07-01-2011, 12:47 PM   #775
68GMCCustom
check out jhl8cn (or something like that) LSx K10 in this thread....
http://67-72chevytrucks.com/vboard/s...=412159&page=5
Kurt -
