#751 | |
![]() Join Date: Aug 2012
Re: 1968
#752 |
Re: 1968
Yeah GDavis there is all kinds of things you run into when you start changing configurations, no worries everyone learns this way.
Right now I'm going through my own troubles with the fuel system for the 2003 Vortec 5.3L but I will get it figured out with some help from people more knowlegable on the subject. You will get everything figured out also with a little help. |
#753 |
![]() Join Date: Jul 2012
Re: 1968
It's no wonder they have a bazillion holes in the frame. They need them for all the cross member configurations, etc.
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
#754 |
Re: 1968
#755 | |
Re: 1968
#756 |
Re: 1968
Today, I pulled the front end off the truck. I did not want to burn the primer while I was grinding the ribbits out.
I also pulled the engine out. I could not get to the top two ribbits without pulling the engine. I even had to jack the front of the cab up 6 inches to clear the ribbits. I cross cut the ribbits and punched them out and got rid of the cross member. As you can see in the pictures. The cross member is laying on the ground in 3 pieces. Tomorrow I am going to drill the two new holes for the stands for the motor mount. |
#757 |
Re: 1968
I have to remove the manual transmission reinforcement crossmember on mine this week also, I'm not looking forward to it but it has to be done.
#758 |
Re: 1968
Why are you drilling two new holes for the engine perches, the stock V8 perches will fit in the factory drilled holes closest to the radiator, and if they don't then they arent 67-72 v8 perches.
#759 |
![]() Join Date: Jun 2011
Re: 1968
Brian's right davis, you can see in this post, what the factory mounts look like and where they need to be placed. In my configuration anyway. 350 and TH350 transmission.
http://67-72chevytrucks.com/vboard/s...6&postcount=31 |
#760 |
Re: 1968
Just put it in your mind that it has to be done and do it. as you can see I did and now I am happy. I am going to leave the motor out for a while. I think I will run my brake lines on the front first. I know I should have done that already but I thought i could do it later. Well I put it off and still it has not been done. The second shift are not doing their job. Let me know what trouble you have doing yours.
#761 |
Re: 1968
They came off of a V8 motor. I assume that they were. Anyway I drilled the new holes today. I know what assume means. So what you are saying is I don't have V8 stands. Here is a picture of the same stands I am using. What do you think?
#762 |
Re: 1968
I went outside and took two pictures of the perches in the truck. I have already drilled holes, but will I have any problems using these in the future. If you think I might then I will get a new set. For heaven knows I have had my share of problems in this motor change.
#763 |
Junior Member
![]() Join Date: Jan 2008
Re: 1968
looks great. keep up the great work.
#764 |
Re: 1968
I will look at my V8 small block perches, and crossmember mounting location and compare and get back to you.
#765 |
Re: 1968
So you were able to pound out all of the rivets? I've ground off lots of them on the Mustard project, and only get about 25% of them to pound out after grinding off the head. I end up using the torch to cut stuff apart at that point.
I think I have a set of small block perches if you need them.
#766 | |
Re: 1968
#767 |
Re: 1968
Today, I just layed around and rested and getting ready for court tomorrow. I got called as a witness on a case that I would like to stay away from. This guy did some bad things to some kids and now he thinks I will help. It would have been wise to never call me as a witness. Anyway guys say a pray or two for me tonight.
so intill I post again God Bless |
#768 |
Man of Mini-Talents
Re: 1968
If his attorney is sharp at all, he's going to interview you before you ever get close to getting on the stand.
Praying for you.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#769 |
Re: 1968
Prayers sent. Sounds like an ugly case.
In lighter news, here is a pic of the extra engine mount perches I have alongside the originals from Mustard (72 350 truck). They look pretty much identical as far as I can tell. The extra set came with a frame I picked up and there was no engine in it. If you want them, pay the shipping and they're yours.
#770 | |
Re: 1968
#771 |
Re: 1968
Here's a couple more. Definitely different (shorter, and fit the holes) than the ones you have. Uglier, but they fit, and you already know what to do about the ugly.
#772 | |
Re: 1968
#773 |
Re: 1968
Guys, thanks for the prayer on the court case. The lawer didn't interview me. He came out and seen that I was a litter upset with the whole thing. He figured that he better cut his loses and he excused me from the witness list. God does answer prays.
#774 |
Re: 1968
Hey GDavis;
I also have a set of V8 perches that are already painted and ready to go if you need them. |
#775 |
Re: 1968
thanks
