#751 |
C/10 junkie
Re: Shawno72's long overdue 68 daily driver build thread
Ok guys I have run into a snag with the disc brake install. I installed the POL Disc brake conversion front hard line set and it fits pretty good. I got the CPP disc brake front conversion hoses from a board member and the hose ends are larger than the line ends
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#752 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
I told him to align it as low as possible. He did the best he could at keeping it low,... but I would have liked a lower ride height. That's really what a Dropmember is for. LOW ride heights!
#753 | |
The 71-72 hoses have two different size hose fittings. (thats the way they were from the factory) So you would still need an adapter on one side. I used the ECE conversion hoses on my red '69. They are a direct bolt on. I have extra long 73-87 hoses on my blazer, so it doesn't stretch the brake line so tight when air'd out. But they require an adapter also. I got my inverted flare adapters at my local ACE hardware store.
#754 |
You need the "tube" adapter.
http://www.oreillyauto.com/site/c/se...1164/C0248.oap
#755 |
C/10 junkie
Thanks Keith I am checking into that now!!
#756 | |
Slam Specialties bags have a huge port size, (3/8"npt or 1/2"npt), that requires a pipe thread bushing to reduce down to my PTC air line fitting. I think I used a uni-bit up to 3/4" and then cleaned up the hole with a 7/8" standard drill bit with a 1/2" reduced shank.
#757 | |
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#758 |
C/10 junkie
#759 |
C/10 junkie
Ok so I bought a set of the 4x4 front brake hoses from Oreillys and they fit like a glove and are longer for the aired version thats coming
#760 |
Part numbers?
71-72 4x4 application?
#761 |
C/10 junkie
Oreilly's part number BH79339 and they are for 72 4x4. Had to cut the two ears off but they bolt up to the caliper just like the conversion hoses. Plus I didn't need and adapters
![]() I still need to figure a sanitary way to mount them to the lower A arm. Any ideas?
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() Last edited by shawno72; 03-30-2013 at 05:08 PM. |
#762 |
C/10 junkie
Some more progress, check out how short the PO cut the stock coils. That's my 3" drop coils next to them.
#763 |
C/10 junkie
Almost there......
#764 |
Must be nice to have a lift and your own alignment equipment available to you.
You're killing your mods one by one!
#765 | |
![]() Join Date: Dec 2006
![]() Posted via Mobile Device
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#766 | ||
C/10 junkie
![]() Quote:
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() Last edited by shawno72; 03-30-2013 at 08:53 PM. |
#767 |
C/10 junkie
And some pics of the finished product. The front ended up much lower than I really expected even though it was right on with Keiths red truck. It dropped an additional 1 1/2"
#768 |
Looks good.
The stance is perfect! The 4x4 hoses have a through frame connection just like the 73-87 hoses. I think there should be a nut on this hose to mount it solid to the bracket. How close are your a-arms to the ground? You might have to learn how to drive it differently. Watch out for potholes in the road!
#769 | |
C/10 junkie
#770 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
looking good Shawn
Posted via Mobile Device Posted via Mobile Device
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#771 |
![]() ![]() Join Date: Jan 2011
Looks great buddy! The stance is perfect.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#772 |
A day late and $1 short...
OUTSTANDING!! Oops, sorry, didn't mean to yell.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#773 | |||
C/10 junkie
![]() Quote:
#774 |
VA72C10
![]() Join Date: Mar 2008
Nailed the stance!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#775 |
Nice fix with the 4x4 brake line!!!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=563712 Instagram: http://instagram.com/rockylakekustoms Rocky Lake Kustoms Russ |
