12-15-2015, 01:04 AM | #751 |
Re: What did you do with your truck today, take 2
And a few more...............
Dan
1947 AD 3100 |
12-15-2015, 01:07 AM | #752 |
Just crossin' my fingers that the shop where it's at now won't drag this project out forever.
Dan
1947 AD 3100 |
12-15-2015, 07:35 AM | #753 |
working on jag rear end & new wheels.
12-16-2015, 04:38 AM | #754 |
Done with my rattle can overhaul of a strong running 84' 4 bolt 350 and recently rebuilt TH400. I disassembled, cleaned, sandblasted as needed, primed, painted, and reassembled all front accessory drive. Added some valve covers that came off my grandpas stock car in the 70's and some Camaro headers I got dirt cheap. Installed in my 53 and did a valve adjustment that should get rid of the tappet ticking up near the #1cyl. Will do some wiring and hopefully fire it up by the weekend
12-16-2015, 02:24 PM | #755 |
Test fit stuff om motor
12-17-2015, 01:29 PM | #756 |
A320 Pilot/USAF Retired
Installed the carpet kit that's been boxed up for nearly 10 years!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
12-17-2015, 09:03 PM | #757 |
Pulled the Kansas truck out of the carport, tracked down wiring problem, bought a battery, changed the oil, threw some antifreeze in her, cleaned gas tank (along with a lot of nastiness under seat) and hooked back up, threw $5 of gas in her and brought her back to life from who knows when. Actually ran but carb loading up and leaking like a sieve. I'll deal with that and a couple other minors and she'll be ready to flip so I can get to the real project.
12-17-2015, 10:43 PM | #758 |
Chopit, do you need a filler neck for that?
1969 Chevy C10 SWB 350/400 4"-6" drop on steelies 53' Chevy 3100 5 window http://67-72chevytrucks.com/vboard/s...d.php?t=660793 http://67-72chevytrucks.com/vboard/s...d.php?t=771679 |
12-18-2015, 12:50 AM | #759 |
Back to my five minutes a day work plan after over a year, feeling good getting back at it. Tonight welded up a few more seams on the drivers door.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
12-18-2015, 11:36 AM | #760 |
Thanks Jeff, but that actually is a filler neck, just no rubber seal and picture makes it look like hell, lol. (I actually have a couple more filler necks and even that old gas tank I got from you and never used.)
Got an old gas cap laying around? |
12-18-2015, 12:07 PM | #761 |
Nice chop MARTINSR
12-18-2015, 06:35 PM | #762 |
Thanks, now if I can keep on it so it actually gets done.
Brian
12-18-2015, 11:19 PM | #763 |
You bet!
12-20-2015, 02:35 AM | #764 |
All I did was get a curtain up after going to two different stores twice each to get all the right things for the project. I now can walk into the garage and put in my five minutes a day without spending time getting ready. WHOOO HOOOOO!
Brian
12-20-2015, 01:38 PM | #765 |
At least you have your project in the garage where you can work in it even in tight quarters.
Good idea on the curtain, I've known a couple of guys who ruined the paint on the finished car because it got hit with the results of grinding on the project vehicle. If it snows much more I'll be able to build a shop out of snow and work inside it.
12-20-2015, 02:34 PM | #766 |
polishing a turd
Lkq dropped off the explorer 8.8 rear for the 55.2 project
Posted via Mobile Device |
12-20-2015, 06:17 PM | #767 |
Worked on smoothing glove box/ash tray.
12-20-2015, 07:00 PM | #768 |
That looks soooo nice. I appreciate the time that takes.
Earl
You have to have patiences or you'll be one. |
12-20-2015, 07:49 PM | #769 |
Dash is looking good!
12-21-2015, 12:24 AM | #770 |
I looked at the frame while trying to figure out why my tankless water heater was giving me an error code "11"
12-21-2015, 04:48 PM | #771 |
Since my cab is 5" longer, I needed some 6 "longer
trim pieces for the cab floor to door rubber strip. I copied the old one, but made it from brushed stainless. I trimmed them to length, and will finish the cutout with an end mill. I made a simple countersink die and used it in the arbor press. |
12-21-2015, 08:15 PM | #772 | |
Brian
12-21-2015, 08:18 PM | #773 |
Nice job. Simple when you have the tools!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
12-21-2015, 08:20 PM | #774 | |
12-21-2015, 08:55 PM | #775 |
I have pictures from the beginning of this project.
I just need to get going on a build thread... |
