08-24-2018, 10:52 PM | #751 |
Re: What did you do to your truck today part IV
Had a chance to pull the sender out of my tank today. I knew the truck had been sitting a while but I had hoped the tank might still be usable. After seeing what the inside looked like I pulled the tank out. I took it to a local shop only to find out they want $100 just to tell me IF it was salvageable. Going to check out what the hot rod hoarder at work has tomorrow and hopefully he will have a fuel tank that will fit between the rails under the bed.
08-26-2018, 12:39 PM | #752 |
Well after almost a year and many setbacks I finished the brake upgrade. Went from Manual Drums to power assisted Disc Brakes on all four corners. I also replaced all of the brake lines.
08-26-2018, 05:02 PM | #753 |
Congrats on brakes sorted! I am in the process of doing roughly the same, but keeping the drums on the rear. My first time running my own brake lines. I am having quite enough of lying on my back on the gravel drive way with crap falling in my face Question, how did you route the line going to the rear end? Stick with passenger side, or switch to driver's side? Thanks.
1961 GMC half ton, short step, Canadian model. Just starting work on it. |
08-26-2018, 09:52 PM | #754 |
venat - Sending a private message.
08-26-2018, 09:57 PM | #755 |
1965 Chevy C10, 2005 4.8L/4l60
Putting some of Clyde’s bling back on!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-26-2018, 11:41 PM | #756 |
Friend of mine painted signage on the truck today. Original owners son said I could use their name, it was on their dairy since new.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
08-30-2018, 09:38 AM | #757 |
Got the Nitrous bottle mounted, next week is exhaust system.
09-04-2018, 10:48 AM | #758 |
Picked up new wheels and tires.
Before After |
09-04-2018, 09:00 PM | #759 |
Put the front of the engine back together: new belts, pulleys, PS pump, fan shroud.
Dan "Ratman" Ratcliffe Fourth generation Chevy truck guy, raising the fifth 1978 Scottsdale Big 10 "Bad Medicine" Daily Driver 28 yrs 1965 C10 Panel Truck "RWC" http://www.67-72chevytrucks.com/vboa...d.php?t=749003 |
09-04-2018, 09:42 PM | #760 |
09-05-2018, 11:16 AM | #761 |
10-08-2018, 10:03 AM | #762 |
test fit an insulation kit I got off eBay
10-08-2018, 06:15 PM | #763 |
I built a bracket to lock my hood. It’s not foolproof but no one will expect it.
10-09-2018, 09:26 AM | #764 |
Today I'm finally going to wash mine. It's been sitting for a few weeks because work has been running me like crazy.
10-09-2018, 11:25 AM | #765 |
Got my frame back from the sand blaster on Friday and sprayed it with epoxy primer Saturday. Finally making progress again on my truck.
65 short step edited by staff |
10-09-2018, 07:18 PM | #766 |
Moderator
Took off one of the rad/grille top pieces so I could take out the bird's nest behind the driver's headlight.
10-11-2018, 12:38 AM | #767 |
Added a coolant recovery jug/windshield washer unit ( you sharp eyes will note that it came from a f**d), relocated the horns behind the grill and out of the engine bay. Searched a pile of tanks at the wreckers, couldn't locate one that "fit" the wheel well.
Brent W 66 short step 4 x 4 |
10-12-2018, 04:44 PM | #768 |
new shoes
front, 225/70r15 on 15x7 chrome smoothy, no caps rear, 275/60r15 on 15x8 chome smoothy, no caps
1972 gmc 3500 ramp truck, 350, sm465, dana 70 rear Last edited by pinturbo75; 10-12-2018 at 04:52 PM. |
10-12-2018, 09:56 PM | #769 |
After 3 years of ownership, I finally gave Frankentruck a bath. At some point I need to completely scrub the truck in some sort of cleaner, because the car soap and sponge was not extremely effective
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-14-2018, 04:11 PM | #770 |
Not today but I got my vintage air ac installed. I have not tried the heat yet but the cool works amazing 👍
10-14-2018, 04:28 PM | #771 |
the engine bay looks real good. nice work.
10-21-2018, 10:27 PM | #772 |
Prepared the frame for the new power steering bracket from Capt. Fab.
10-21-2018, 10:31 PM | #773 |
Cleaned it up a bit.
10-21-2018, 10:33 PM | #774 |
Cut out the back of cab for big back window and made a template for the glass and inner panel
10-22-2018, 07:57 AM | #775 |
Cussed it, because I'm having issues with getting the headlights to work.
http://s1299.photobucket.com/user/jb...23904108567829 |
