04-11-2022, 04:36 PM | #751 |
Re: My Dusty 71 GMCe Electruck
From my experience the tempered glass lasts a good long time. I bought 3 of them several years back and I am on #2 so far. you have to be aware of the bounce in the cabinet and try not to aim the gun so when you are blasting the edge it is not firing right at the glass, or bouncing off the material right at he glass. You can gain some more life by switching hands too. If you are right handed the left side of the glass will be pitted the most and difficult to see through. Switch to left handed and view through the clearer side.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
04-11-2022, 05:04 PM | #752 |
Cool video. Subscribed to your channel.
04-11-2022, 05:53 PM | #753 | |
Post Whore
South Paw FTW! |
04-11-2022, 05:55 PM | #754 |
Post Whore
Hey Chicogonian, thank you so much, how about them winds today?! lemme know if you wanna stop by for some tacos and parts cleaning ha ha I'm just 90 minutes away as the crow flies South on 99 in North Natomas the very tip os Sac Town
04-11-2022, 07:21 PM | #755 |
Post Whore
Why should you convert to electric? any questions, ha ha
and that was no where near fill up of the 21 gallon petrol tank of da wife's 2010 Honda Pilot, but the pump quit Quick Maff, $100 bucks twice a month is $2,500 per year so I can buy two almost three BMW 530e battery packs every year with that money and since I have two 2018 packs already that tells me they is at least good for three plus years - Good Times! |
04-11-2022, 07:30 PM | #756 | |
Post Whore
04-11-2022, 10:26 PM | #757 |
looking good. This really makes me want to do an EV conversion on something.
‘53 GMC COE stock ‘53 Chevy 3100 LSA/TR6060 http://67-72chevytrucks.com/vboard/s....php?t=805949‘ '70 Chevy C10 LWB 350/sm465 ‘74 Chevy C10 SWB 5.3/4L80e, Vintage Air, Dakota Digital, US Mags |
04-11-2022, 10:51 PM | #758 |
Post Whore
04-11-2022, 10:55 PM | #759 |
Post Whore
there comes a time during a project where you had enuff of doing something [like cleaning gunk off of suspension parts... I'm looking at you lower control arms] and just do something else, so lets weld some sheet
04-11-2022, 10:58 PM | #760 |
Post Whore
for this we're gonna need two things, one file folder and one dirty thumb
04-11-2022, 11:02 PM | #761 |
Post Whore
I've said this before and I'll say it again DeWalter White is my most utilized horse in the stable
first we deRustarize the rusty piece of scrap sheet metal maybe 16 gauge (I hope) |
04-11-2022, 11:05 PM | #762 |
Post Whore
then we cut out the proper shapeness roughly (going a bit bigger than need be, we can always trim the excess material off)
Note how the 4 1/2" angle grinder went from a wire wheeler to a cutterizer by simply switching the attachment |
04-11-2022, 11:06 PM | #763 |
Id need about 20 of those BMW battery packs and get 1 mi/kWh because of how big it is
04-11-2022, 11:06 PM | #764 |
Post Whore
then another costume change from the cut off wheel to the smootherizer
04-11-2022, 11:08 PM | #765 |
Post Whore
and after 47 nips n tucks, she almost fits perfectly, ah good enuff for the girls we date
04-11-2022, 11:10 PM | #766 |
Post Whore
hence the Cab Over we got the whole bed to load up with them 20 battery packs, and I may know a guy who knows two Armenian brothers in L.A. who just might could get their hands on sum mint Tesla parts ~ just sayin'
04-11-2022, 11:16 PM | #767 |
Post Whore
second verse, same as the first
but a whole lot larger and a whole lot worse |
04-11-2022, 11:21 PM | #768 |
Post Whore
oh yeah, since no one asked, lemme tell you about my spark machine setup
runnin typical 3 parts Argon to 1 part Carbon Dioxide commonly known as 75/25% blend for sheet metal (which is way harder to weld then them 1/8th inch brackets) I like to use .025" wire for that I try to remember to swap to the .025" roller as well as the .025" tip hope that helps some of you Young Padawans out don't mind the settings ie the knob position in this pic they got twisted by accident to the max Last edited by Gregski; 04-11-2022 at 11:47 PM. |
04-11-2022, 11:24 PM | #769 |
Post Whore
also I don't read sheet music, I go by clock position, so for this type of thickness or I should say thinness, the wire speed is at 9 o'clock and the poweridge at noon
Top Tip: if the wire coming out of your gun is bouncing off or tapping the piece you is trying to weld, the wire speed is too fast, turn it down Last edited by Gregski; 04-11-2022 at 11:47 PM. |
04-11-2022, 11:29 PM | #770 |
Post Whore
I just happen to find some scrap circular plugs that almost fit in them larger holes so I run what you brung
I think I had three of them so that took care of the three bigger round holes |
04-11-2022, 11:33 PM | #771 |
Post Whore
for them medium holes I use this Clint Eastwood backing plate thingie jobbie
04-11-2022, 11:36 PM | #772 |
Post Whore
counting them extra 17 holes in the floor boards I think 206 holes done and 180 to go, it aint perfect by any no means but maybe two gallons of bondo and some distance will make the firewall look real good
oh dingle dangle, I still gots to do that BIG circle, darn it! |
04-12-2022, 11:32 PM | #773 |
Post Whore
this morning I was greeted by this dreaded hard drive failure on my primary home computer where I keep all my EV Conversion pics and documentation
the Intel SSD 535 Series hard drive just failed 480 GB Solid State Drive I'm an IT guy but this sucks ballz! I tried to tether it to a working laptop as an external drive but it won't even power up |
04-13-2022, 08:21 AM | #774 |
I'd just quit! Man that really does suck. Good luck on any type of recovery.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
04-13-2022, 09:34 AM | #775 |
Let me be the tin hat in the room. Somebody doesnt want you building an electrified truck and them not share in the profits? Just a theory.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
