#7751 |
Re: What did you do to your truck today?
I painted my engine. Needs a couple more coats. I cleaned and put Calyx on my manifolds. I also sandblasted a few parts.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#7752 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
New seat upholestry......new carpet....and tried something new with the sill plates. Shifter work ,rewired the last of the taillight harness,patina blending and a host of other things......and tada it's on the road just like that
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
#7753 |
The washed it and sat there looking at it for a few mins.....with this big a$$ smile on my face.....406 Small block ,fast burn heads solid lift cam 4 wheel disc brakes,coil overs ,complete powder coated chassis and it keep saying drive me drive me.....
#7754 |
looks awesome wutnxt
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
#7755 |
Managed to hook up with my buddies and head out for a nice cold beeeeeeeeeeeeer it was a good day all the way around
#7756 |
#7757 |
Well the Caprickup got some new shoes today. I also hung the doors today. It is coming together FINALLY!!! i put a fender on to make sure the tires cleared and start thinking about how low I should go...
My Build CAPRICKUP 1964 Chevy SWB on a 94 Caprice http://67-72chevytrucks.com/vboard/s...d.php?t=492640 |
#7758 |
A method of creating clearance at the point where the frame and rear axle tube come together using a section of pipe to notch the frame.
It would have been great if I got that point correct when I did it... two forward - three back... rg |
#7759 |
Thanks Robber Grin. I looked it up after the post and found moocho info on it on this amazing site.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb ![]() |
#7760 | |
"Where were you in '62?"
![]() Join Date: Jul 2004
![]() Quote:
Sat progress... Project: "Full Metal Yellow Jacket" Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=321173 ![]() ![]() ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#7761 |
Wired up the wipers.
Posted via Mobile Device |
#7762 |
My passenger side notch was @ 3/8" off center to top of the axle tube - not happy - but it "will work"... tube hits the snubber.
I relieved the front lower edge a bit with the grinder and dressed it up. Moved the driver's side notch up a bit to correct and I got it welded in yesterday. My buddy Keith say's I'm a mad-man for attempting it in the first place - it was my first time doing something like this... scary. No guts - no glory... DONE with the NOTCH-OHS! With the bed sills on pads and full extension of the rear suspension to the snubbers it looks like it could hit the bed wood at some point. Raising the bed floor for clearance I guess... Rear 4" drop springs today. rg |
#7763 |
Post Whore
![]() Join Date: Mar 2013
Well boys,
I am way behind, So yesterday I hauled a lot of junk with mine. Then tarped it that evening, and now its raining today! Good thing I threw the tarp on it! |
#7764 |
With the 62 original rear still in I decided to "finish" the rear drop to see what it will look like when I am actually done with the chassis and suspension...
I have to figure out shock placement, pinion angle for saddles on new rear, and so on. I have another question - Are any of you that went 5 1/2" front // 6" rear on a static drop running a rear tank and has it been a problem? I got the rear-tank conversion "kit" from Brothers and I'm looking at making that work somehow too. Thanks doesn't really cover the gratitude I have for this site... rg |
#7765 |
Gear Jammer
My truck got pulled out of the garage to pull my wifes furd in.................Happy wife happy life right??
#7766 |
![]() Join Date: Mar 2012
Installed my fan shroud for my electric fan and aluminum radiator. Runs a little cooler now.
![]() Worked on my bed sides again. ![]() Posted via Mobile Device
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#7767 |
Shot the base color for part of the firewall. I only had a tiny bit of paint, but I stretched enough to cover enough of the portion that I wanted blue. The rest will be satin black, like the inner fenders and under hood.
I'll clear it tomorrow night after work (hopefully). I was supposed to be finished with the firewall AND the frame, but I spent a lot of time sanding some more on the firewall. Still didn't take it all the way to bare metal everywhere (wished I would have). I also had a comparability issue with the rusty metal primer and the self-etching primer; it ended up cracking. I guess I didn't wait enough for the rusty metal primer to cure, so it was still off gassing and shrinking. I was able to cover it with some high build primer and sand it down so it doesn't show. Aggravating though. Alright, I even flipped the picture upside down in photoshop and it still came out upside down on the post! Sorry, I tried! Posted via Mobile Device Posted via Mobile Device
Current Vehicles: '62 C10 - 350 (current project), '03 Tahoe (C Series) Some Past Projects: '69 Nova - 350 , '70 1/2 Camaro Z28 - LT1 350, '73 K20 Full-time 4x4 - 400 SB, '77 1/2 Camaro Z28 - 350, '84 Camaro Z28 - 305, '68 Buick - 430 BB |
#7768 |
Installed Langdon's HEI in my 235, swapped turbos for Cherry Bombs, filled in some dents...
#7769 |
Nothing today but yesterday I threw hay in the back and took it down to the barn to feed the horses.
#7770 |
e l e - digg'n that last pic big~time - nice truck!
Today I relocated my front shock mounts on my 62 C10 chassis - Thanks Mark! rg |
#7771 |
Finally got my electric problems solved. Bad grounds-imagine that! Tomorrow new mufflers and work on the bed if it's not raining.
66 shorty ![]() |
#7772 |
Got my back ordered fender from Truck and Car parts in Cali... I now have no excuse.....
#7773 |
Moderator
![]() Join Date: Dec 2012
Ordered a muffler and a driveshaft bearing. Loaded my bedwood on the roof of my station wagon to take to a friend's house to cut to the proper dimensions tomorrow. Time for a project thread...
#7774 |
Finally got that beast of rear end (ho52) today just need to bleed the brakes since it was apart I stuck 2" blocks in it my 66 c20.
#7775 |
![]() GOT A/C WORKING freezing cold now , bought 2 front tires 10 ply |
