#7826 |
Re: What did you do to your truck today!
Guys quit showing off such nice bikes. I lovem.
Got in the truck this morning going to a car show and the alternator went out. So you know what kinda day I had. BYW,I did get the later model alt. and put it on so the upgrade on that is done. now for the headlights. |
#7827 |
#7828 |
speaking of headlights, just came back from a 700 plus mile road trip and my truck is so high I couldn't see the road due to normal halogens in it so just upgraded to HID headlights today, wow what a difference, can't wait for the next roadtrip...have to save for gas first.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
#7829 |
Broke it again.....
![]() Posted via Mobile Device
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#7830 |
The hanger bearing design sucks though, see you even had some extra welded to the sides.
#7831 |
RAT1968 '68 Cab/'71 Parts
Changed the oil and filter.
Had some "soft" in the brake pedal. No one else around. So, I started at the rear passengers side drum and cracked the bleeder (after I made sure the m/c was full). Took about 20 seconds and then out came some brake fluid. Repeat on the driver's rear drum. Maybe 10 seconds this time and I got some gravity-fed juice. The two front calipers only took less than five seconds each until I got some. Brake pedal was "hard" on the test drive...Great!!!! I was surprised. I'll have to do it again when I have help. But that was good for a solo-run. When I pulled back into the house after the test, the LMC gap cover (covering the space between the grille and radiator core) was sitting in a box at the front gate. I put it on. Easy fit. I kinda wish it was made out of heavier stock. They advertised, "polished aluminum"...I guess it *is* aluminum. But I couldn't really tell it from shiny sheet metal. I like it, though. A good day.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#7832 |
I finally decided what I would do and dropped the carb and rebuild kit off at a garage for the job.
#7833 | |
#7834 |
Dang...how does that happen?
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#7835 |
Painted some of the parts two weeks ago.
[IMG] ![]() [IMG] ![]() [IMG] ![]() Posted via Mobile Device
Rincon |
#7836 |
#7837 |
![]() Join Date: Jul 2013
HorsePower! I guess.... I used to break them all the time in my 69. That is until I made one out of heavy steel and urathan bushing. That is the only way I know, it is just a crappy design.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#7838 |
![]() Join Date: Dec 2012
What type of What fiber spark plug does I 1971 GMC Sierra take
1971 GMC Sierra 1959 GMC 100 Last edited by SCHRUMGMC; 09-03-2013 at 11:41 PM. |
#7839 |
Another bit of fun in the garage today. Had some left-over carpet. The chunk from my failed attempt at creating a home-grown headliner.
So I cut *it* up to make some kick panels for below the door panels. Cleaned up the elec. window wiring. Tightened a cab mount and called it a day.
#7840 |
This is usually caused by improper drive line angles and or unbalanced drive shaft. This is very common when a truck is lowered and the drive line angles are not corrected. This is very uncommon on a truck with stock suspension.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#7841 |
It is common with a lot of HP though, torque is hard on them.
#7842 |
Bought a Coil and some new spark plugs
1971 GMC Sierra 1959 GMC 100 |
#7843 |
Waited for the muffler shop to call and say its ready ,never got the call so it must be being a pain ,had a few broken bolts in the exhaust manifold (6 cyl 74 Chevy) ,but all is good ,need to drive the El Camino some anyway.
#7844 |
I changed the oil and oil filter. It has been over a year and a half since I last changed the oil. I have put on over 10,000 miles highway on the old 350 with in the last year alone.
Went through a devastating break-up over a year ago that really took me down. Just now really putting my life back together. ![]() Keith |
#7845 |
![]() Join Date: May 2007
Took her to the alignment shop....
#7846 |
Got the windshield and seal replaced.
received a Christmas package from LMC Truck - Headlight harness - new dome light w/ clear lens and LED bulb - Black round head mirrors - new T-case boot bought tint for the back glass, gear oil for the differentials as well. Tomorrow will be busy! ![]()
1990 Suburban Silverado 350, SM465 and 35" tires |
#7847 |
Took off the Towing Mirrors I am looking for the Tripod Towing mirrors and can't seem too find any ?
#7848 |
Good for you. Trucks help that stuff.
#7849 |
No physical labor, just ran up the debit card lol. New tires for the new wheels and new chrome bumpers from brothers. Wheels/bumpers should go well together.my truck came with mismatched bumpers anyways.
![]() ![]() Also have an ece 4.5/6 thats goin on soon along with power disc brakes and a 350 with a 700r4 The paint/interior are whats left from the assembly line all that im gonna leave, gives the truck some character ![]() The maiden voyage is getting closer!!!! ![]() Posted via Mobile Device Posted via Mobile Device |
#7850 | |
![]() Join Date: Jun 2012
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
