Closed Thread
Old 06-14-2013, 10:46 PM   #7901
Rac65
Re: What did you do to your truck today?
Can you guys tell me where you got the aluminum radiators and what they cost? I have a 65 that needs a new one.
Rac65 is offline
Old 06-14-2013, 10:56 PM   #7902
luvbowties
luvbowties's Avatar
Smile Re: What did you do to your truck today?
Got mine on Ebay (Champion brand, iirc), and they cost about $175--again, iirc. Mine has worked great for 3 years or so. Our garage has ordered/installed several for other ap's and they have served well too.
Hth,
Sam
luvbowties is offline
Old 06-14-2013, 11:33 PM   #7903
Trsmotrhed
Trsmotrhed's Avatar
Hth,
Sam
Got mine off eBay also.
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline
Old 06-15-2013, 03:07 AM   #7904
markeb01
Senior Enthusiast
markeb01's Avatar
Went out for a late night gas fill up and just as we turned into the rather congested gas station, a 58-60 F100 was pulling out of the driveway. We spotted each other at the same time, exchanged waves and he gave a shot on his ahooga horn. At first I thought I was looking at my doppelganger! His truck was a black or dark burgundy stepside, had a full set of 5 spoke mags, and the beam axle was up in the front. I wish we had arrived a few minutes earlier so I could have gotten a better look. The whole encounter only lasted a second or two.
Ironically earlier in the day I spotted another 58-60 F100 two streets over. It was a gloss black shortbed fleetside. It had custom wheels, was lowered and very clean. Had I been driving the truck at the time I would have stopped and talked a bit. Just kind of funny to see two very similar trucks on the same day when I haven’t seen any nice examples like these in several years.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 06-15-2013, 09:46 AM   #7905
jbgroby
jbgroby's Avatar
Spent an 1.5 hours putting in new halogens lamps - why 1.5 hours you ask to put in 4 headlights?
The outside low beams lights dropped in perfect and fit like a glove. The inside high beams however had factory tack welded "fitting tab" that did not line up with the hole in the buckets, these keep the bulb from rotating or vibrating. I had to haul out the dremel tool and find a cut-off wheel to remove some of the fitting tabs.
I then mounted the new heavy duty headlight hardness to the back side of the barbell. got all proud of myself and then realized I have to flip it as the red leads to the battery are on the wrong side. The mistake is a simple one to make. The wiring harness comes in from the drivers side from the factory, but the new harness needs to be hooked directly to the battery for power.
The white pipe cleaners "wire ties" are only temp. I could not find the pack of wire ties I have. I've probably moved them 3 to 4 times over the past year - now I can't fins them - go figure, Just as well as I would have had to cut the off anyway - small favor.
jbgroby is offline
Old 06-15-2013, 01:38 PM   #7906
markeb01
Senior Enthusiast
markeb01's Avatar
Looks great Jake.
markeb01 is offline
Old 06-15-2013, 02:49 PM   #7907
jbgroby
jbgroby's Avatar
Mark
I ordered the heavy duty harness from LMC for $29.99
36-3580 HEAVY-DUTY HEADLIGHT HARNESS
Remember to lay it our so the red leads are on the battery side.
jbgroby is offline
Old 06-15-2013, 05:08 PM   #7908
donthekawguy
donthekawguy's Avatar
Originally Posted by markeb01 View Post
That turned out nice. What a lot of work. I hate sanding and stripping more than just about anything else, but sometimes it just has to be done the hard way.
Yeah it took a couple of hours just for the inside of the tailgate. It looks so much better now. When I do the outside I'm going to paint it. I have never painted anything before so we'll see how it turns out. I'm going with flat sublime green for the whole truck but just doing the tailgate myself.
66 shorty
donthekawguy is offline
Old 06-15-2013, 06:05 PM   #7909
cortcomp
cortcomp's Avatar
Sanded last night, primed this morning and painted the white cab/stripes today. I finally broke down and took the fenders and grille support off so i can do those separately, and put a new grille support panel in as someone had done some bondo work on the nose, and it looks a little rough and i just don't want to spend a week working on it just to find out it doesn't look right anyways.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline
Old 06-15-2013, 07:53 PM   #7910
62 Barnfind
62 Barnfind's Avatar
Painted and installed my rear bumper.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 06-15-2013, 07:55 PM   #7911
jbgroby
jbgroby's Avatar
Had a great early Fathers Day present, I was able to get both of the boys over at the same time to help with the fenders and hood.
Not a bad days work, even at 93 degrees! Still need to tweak the upper howl cowls and screw down the wiper transmission cover, but DAMN I finally got the front assembled!!!
jbgroby is offline
Old 06-15-2013, 08:01 PM   #7912
jbgroby
jbgroby's Avatar
Mark, here is where I mounted my relays for the new harness. I wanted to be able to unsnap them with out a lot of work. they get covered by the rad support cover
jbgroby is offline
Old 06-16-2013, 03:01 AM   #7913
Vernski
Jake I like that color blue it goes well with the white, won't be long and you will be driving it around. Although long time coming some things are worth the wait, and no one deserves it more than you..Vernski
Vernski is offline
Old 06-16-2013, 11:00 AM   #7914
TJ's Chevy
TJ's Chevy's Avatar
Well since I did not get done tell late last night I am going to put down what I did yesterday. Work on my old 64 and got it running. Put the new intake and exhaust on my 66 also. Boy! Working on two trucks is tiring! But it was a great day all the same. Love the sound of straight pipes! Don't you?
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline
Old 06-16-2013, 12:15 PM   #7915
markeb01
Senior Enthusiast
markeb01's Avatar
Your truck is really turning out beautifully. When you first brought it home, did you ever envision it would take this long and the amount of work it’s taken to see it finished? And – with the years of effort and investment in it, will you be able to find the courage to actually drive it?!!
markeb01 is offline
Old 06-16-2013, 12:17 PM   #7916
markeb01
Senior Enthusiast
markeb01's Avatar
Yep I sure do! Almost as much as I enjoy a 4 barrel dual exhaust inline 6. Nice work.
markeb01 is offline
Old 06-16-2013, 01:36 PM   #7917
jbgroby
jbgroby's Avatar
And – with the years of effort and investment in it, will you be able to find the courage to actually drive it?!! [/QUOTE]
Several times I'd given up all hope, but glad to have stuck with it!
jbgroby is offline
Old 06-16-2013, 07:17 PM   #7918
jbgroby
jbgroby's Avatar
Mounted the bumper, I need to order two more bolts (or find the ones I had!) and the first lens. I need to figure out how to make the other lens get riveted or mounted to the housing without breaking it. It is WAY too rare to gamble with. The OEM factory ones I have plain mushroom head rivet, not the traditional type, where you pull the shaft though. I think they are airplane style, if so I have a friend who just built his own aircraft who has all the tools
jbgroby is offline
Old 06-16-2013, 08:27 PM   #7919
gofastnut
gofastnut's Avatar
Got some paint slapped on her! It's far from good, but good from far!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline
Old 06-16-2013, 08:45 PM   #7920
JWheeler331
JWheeler331's Avatar
Great day with the boys it looks like. Your truck is looking great.
JWheeler331 is offline
Old 06-17-2013, 07:50 AM   #7921
K98AL
K98AL's Avatar
Hauled my 1957 Starcraft to the lake....
K98AL is offline
Old 06-17-2013, 08:31 AM   #7922
jbgroby
jbgroby's Avatar
Thanks Joey, we deff. need to hook up, Mondays is shot maybe later during the week.
jbgroby is offline
Old 06-17-2013, 07:45 PM   #7923
jayoldschool
Moderator
Unloaded my wheels/tires that I just mounted up, and gave them a little cleaning.
Used tires off my parts car. The WWs were mounted to the inside, so they have never been cleaned.
If you have WWs, make sure you buy some of this. Never use something abrasive like steel wool, it only makes scratches that catch more dirt.
A little time with the pressure washer...
And, a sneak preview with the caps:
Think I should add trim rings?
jayoldschool is offline
Old 06-17-2013, 09:27 PM   #7924
endlessearth
endlessearth's Avatar
I vote yes.
endlessearth is offline
Old 06-17-2013, 09:46 PM   #7925
JWheeler331
I know this will sound dumb but what holds the hubaps on the wheel?
Closed Thread
