#7951 |
![]() Join Date: Mar 2012
Re: What did you do to your truck today?
Painted my bed sides flat black for now.
![]() Posted via Mobile Device
Sold the 63 and have a 68 now. 63 ![]() LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18 http://67-72chevytrucks.com/vboard/s...d.php?t=544174 |
#7952 | |
Posted via Mobile Device |
#7953 |
[QUOTE=19666Trucker;6135301]Funny my c20 got it two, a coil, plugs, and reman dizzy, and clean ed the wires behinf the cluster and alternator hook up for remote volt reading. Some day I like see the farm truck
Posted via Mobile Device[/QUO Just let me know when you plan to hit the Pavilions or some other car show and I will spin over. I put 50 miles on it in downtown Phoenix yesterday. 108 degrees and no A/C. I am not scared. ![]() |
#7954 |
Old grumpy is my daily he been working me over wife say he going to be new lol
#7955 |
Installed my bed sides and hooked up my fuel tank door.
![]() Worked over the stock Tahoe fuel setup. ![]() Fuel door came out great ![]() Posted via Mobile Device Posted via Mobile Device
#7956 |
Post Whore
![]() Join Date: Mar 2013
Started mine today.
Vacuum leak fixed. Water heating system not leaking. Intake and exhaust header sealed properly. Ticked of the neighbors....accidentally....I mean come on it's running straight pipes! HMM. Must be to loud or something....Wish I could drive it that way. ![]() And last but not least, it runs like a champ! Its gettin to be a scary 6 cylinder though! ![]()
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#7957 |
Put the bed on mine today. And drove it for the first time with its 305 V6 and 4spd trans.
#7958 |
Moderator
![]() Join Date: Dec 2012
How did you see out the window? lol
Looks great! |
#7959 |
Truck looks great and love the color! Driving it makes it worth all the time and effort.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#7960 |
#7961 |
![]() Join Date: Dec 2010
Well rolled it out today, been busy with the kiddos gokart racen, I am officially registered for the Oct Goodguys event
#7962 |
Finishing up the PO wonderful wire job twisted patches and wire nuts. I know it's a long bed but but nit a house
#7963 |
I test fit my 88 Camaro world class T5 on the bell. I already swapped in a tail housing from an S10 to move the shifter forward. Looks like I can use my e-brake cross member as a tranny support. It's in the perfect location. I'll remove the center e-brake mechanism and remove the frame rivets and bolt it on instead.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
#7964 |
Moderator
Finished the refurb on my driveshaft. New U joints, new center bearing.
#7965 |
Worked on getting the antenna installed. The new after market unit I got from LMC (same as others I would suspect) may all have this problem.
The existing hole from the factory (you can tell if it OEM factory because the hole has a slight notch) is designed for a slightly different antenna base. The one from the kit will need to have the rubber bushing/gasket glue in place to hold it while you tighten down. Also the lower mast brace is too short, I had to make a new one from a piece of flat bar aluminum. Picture 1 shows the original and the new heavier long brace. I was able to use the supplied speed washers and wrap-around. Picture 2 shows the hole you have to drill to mount the brace through. Picture 3 shows the new brace mounted. Picture 4 shows the assembly braced at bottom. Pictures 5 shows the size of the kit supplied vs. home made brace.
http://s1299.photobucket.com/user/jb...23904108567829 |
#7966 |
Con't
This is the new antenna, although leaning inward, there is nothing I can do about it right now until I find a different mount. Also you will have to use a step drill to enlarge the factory antenna cable holes because of the heavier insulation. All in all about an hours work.
#7967 |
When I finished up with the antenna, I mounted the spotlight. I replace the switch wire as well. Added the mirror as well
#7968 |
Sat in truck with hood fully close and got this picture,
View to a Kill
#7969 |
Installed a overflow reservoir for my coolant. Sorry for the crappy pic.
#7970 |
Left my ignition switch on last week or the week before, so I tried to jump it today with the wagon so I could take the dog to the river. Ended up having to pull the wagon's battery to put in the C10 to get it started, then swapping the dead battery back in while it was running so the alternator could charge it. I hadn't made the ignition mistake in a long time.
-Jason '66 C10 LWB 2 BBL 283 w/ T-5 '90 V1500 Suburban TBI 350 w/ 700R4 |
#7971 |
Posted via Mobile Devicegot my west coast mirrors on yesterday's the alternator wants to charge to 18 volts and load down the engine got my tach in and bunch of other little stuff. Still a vacuum leak I am chasing transmission modulator next.
#7972 |
Took out the crappy electric fan, put the flex back in with the broken taped together shroud.
Drove it all over North Texas. Cleaned it some more and took some pictures of it.
If your strength is small, don't carry heavy burdens. If your words are worthless, don't give advice. Chinese Proverb ![]() Last edited by 1964Chevy; 06-24-2013 at 10:43 PM. Reason: The pictures did not stick |
#7973 |
Senior Enthusiast
Received my exhaust cutouts this afternoon and set up an appointment for 08:00 tomorrow morning to have them installed!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#7974 |
i walked by mine to go to work thinking "man i got to get some rear tires so i can get this old girl to my buddies house to start work" then said yet another day....
live like you are dying ![]() |
#7975 |
Found out that my driveline I had done had a yolk with the weep-hole in it. it leaked about a quart of the trans fluid on my driveway. So today I JB welded the weep-hole shut as the yolk doesn't move like on a one-piece driveshaft truck.
"You can have it Fast, Safe or Cheap. Pick any two" "If you're gonna be dumb, you better be tough" 1965 C10: http://67-72chevytrucks.com/vboard/s...=1#post6114617 ![]() 1971 Baja: http://www.thesamba.com/vw/forum/viewtopic.php?t=459552 |
