#776 | |
Re: my 80 build
#777 |
Badass
Re: my 80 build
Step away for a little bit. But don't sell it. Good work takes time. Dont rush yourself you'll go crazy. Dead lines are ment to be broken. You put to much hard work in it just to give up on it now.
Think outside the box? -84c10 (1stcar)→My Build← ![]() -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 ![]() |
#778 |
Re: my 80 build
I agree with everyone. Selling your truck now would be like throwing money away. I can appreciate selling a vehicle once it's finished, or the sell price is equal to or better than the investment. You've gone this far. See it through, drive it, enjoy your masterpiece. If you still feel like selling the truck after driving it, your choice... Great progress BTW.
#779 |
6.0 powered square
Re: my 80 build
don't worry guy's its going nowhere, I'll just through more money at it
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#780 |
Re: my 80 build
Man.. It doesn't cost anything to have it not be done. (unless your paying storage). I've moved my junk around for 8 years and across the country until I finally got building it. This thing is way to nice to give up now. You will regret it if you sell it.
#781 |
6.0 powered square
Re: my 80 build
Actually my truck is the only vehicle I own, I can't stand it not being able to drive it
so I can get back on the road before December 2 coats of lizard skin sprayed in ![]() steering column back in ![]()
#782 |
6.0 powered square
Re: my 80 build
In progress of the fat mat install, plan to wrap in up tomorrow
#783 |
Re: my 80 build
Lookin good man!
#784 | |
Re: my 80 build
nOtHiNg LiKe ThE gOoD oLe ChEvYs.... ![]() |
#785 |
![]() Join Date: Feb 2010
Re: my 80 build
Hey i can understand what your going throught... my truck is the only vehicle i own... 5grand in the hole on it driven it down the road once just to find out i had a knock in my motor... rebuilt that now... but it sucks not driving it... hurts coming home and seeing it in the driveway but stick with it boss youve got it... someday maybe we will both be driving our toys
1980c-10 mybaby |
#786 |
6.0 powered square
Re: my 80 build
thanks guys, I still have a little more fat mat to install so fare I've gone through a 50sq feet roll
#787 |
Re: my 80 build
Aaron, you've done an amazing job. Thank you for inspiring me. I have been without a vehicle since I got into a nasty wreck coming home from Sacramento. I am just now picking my truck back up. Keep at it bud. Your ride is my inspiration and I'd love to see you finish it
With enough time and money, you can do anything Quoted from my father 1976 C-10 Project |
#788 |
6.0 powered square
Re: my 80 build
#789 |
Re: my 80 build
what kind of harness is that?
#790 |
6.0 powered square
Re: my 80 build
the body harness is American auto wire Power Plus 20 and the engine is psi conversion
#791 |
6.0 powered square
Re: my 80 build
#792 |
6.0 powered square
Re: my 80 build
Ive got a few things done got the truck to crank by the key but it didn't want to start, but look more in to when I get done with the wiring got the steering column wired up, new master cylinder, wire loom
#793 |
Re: my 80 build
You should really have that fresh paint on the firewall covered w/masking paper & tape while all the work is going on in the engine compartment.
#794 |
6.0 powered square
Re: my 80 build
#795 |
6.0 powered square
Re: my 80 build
#796 |
6.0 powered square
Re: my 80 build
#797 |
6.0 powered square
Re: my 80 build
#798 |
Re: my 80 build
glad to hear u got some sense kickd in to you dunno what u were thinking. Dont give up finish what you started it will be finished sooner or later you cant rush quality, hand crafted wok takes time. Its only money drag the build rob a bank do something but dont sell something you love
#799 |
6.0 powered square
Re: my 80 build
thanks smoke, I got a little done in the past two weeks, got the gauges mostly wired up, added a 2 gauge ground cable for the block to the ground and the grounds for the body to frame and engine and added a second ground to cylinder head to the frame, got some 8 gauge wire to run from the battery to electric fan, also found some problems with my engine harness I had a least two wires pull out terminal pins, so fare they told me there sorry and they send me some replacement pins, but I have sent some pictures of the poor craftsmanship and waiting to hear back. I have ordered a blackbear tuned computer, and in the process of purchasing some captain fab rear disc brake brackets and wilwood d-52 caliper package
#800 |
Re: my 80 build
Thanks for being an inspiration to me. I am about to attempt the same thing more or less and your thread is awesome in how you kept after it. Don't give up. I know I'd like mine to be done too, but I've got years to go before that will happen. Hopefully I can get a thread started once I figure out how to do that.
Keep after it Aaron and the fruits of your labor will be great! |
