Old 07-27-2010, 08:54 PM   #776
eagleuh1
eagleuh1's Avatar
Re: 1967 C10 Custom Big Window
Wow, wish they'de still have some rockers and cab corners in stock. Maybe a core support too. The trucks real nice lookin slick67. I really like the side emblem, makes it look like its going real fast sittin still.
eagleuh1 is offline   Reply With Quote
Old 07-28-2010, 04:11 AM   #777
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by 67chevy1series View Post
man looks nice even with the hood not lining up it still looks awesome
Thanks! It sux, but I'll get it there!!!
Originally Posted by ripdog28 View Post
Damn this thing is just Beautiful.
Thanks Ripdog! Been a long time to get it there. My first build is comin out a little better than I had expected.
Originally Posted by VA72C10 View Post
hey, quick ????
Got my antenna installed today in the cowl but don't see the hole for the grommet....do you remember where it's located since you just installed that mac daddy antenna???
Right by where the antenna goes in the cowl there is a small hole like 3/8 just below the windsheild in the cab.
did your truck have a antenna from the factory or dealership if not then you will need to drill a hole but if you did then it should be there i would take the cowl panel off and put it all the way you want it then bolt the cowl back on
^ agreed!
don't want to thread jack too much but it did have an antenna...so that's what is puzzling me...everything is shaved on my other truck so I never paid attention to where the antenna came out of and this one was done before as well of course...
Drill in the closest spot on the cab where the antenna wire is, you will be very close!
Originally Posted by suville View Post
Ya might remove the springs and then see if you can get it aligned, but I'm thinkin and from experience yur hinges are worn out You can find good used ones, cant vouch for repops tho.
Hey Suville! Yeah, worn out hinges will do that but I gotta try aligning the hinges one more time.
Originally Posted by 68 Quad C10 View Post
that is what i was just going to say if you take the springs off and it can be lined up good then you need new springs if it don't then i would say you need hinges..... its been to long since i did mine i had the same issue and i believe we went with new springs and hinges........oh and your truck looks AWSOME!!!!!
Cool. That gives me a little something to try. Thanks for the compliments!
Originally Posted by smbrouss70 View Post
DO NOT USE REPRO HOOD HINGES! They will fold up due to thin metal and damage your hood and fenders. GMpartsdirect.com has Original GM Hood hinges, so they are probably still available from a local GM dealer (special order, I'm sure). GMpartsdirect shows the parts numbers and prices like below:
LH Hood Hinge 3911705 $66.64
RH Hood Hinge 3911706 $45.46
I have heard they suck too. The hinges are tight and seem to be in perfect shape, guess I'll test them by taking the springs out.
Meeee too! Thanks eagleuh1, guess you are talkin about the 55 Bel Air emblems on the side! When people see it they don't even realize it's not factory badging..............I love that.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-28-2010, 10:42 PM   #778
67-C10
67-C10's Avatar
Oh, yeah this is looking sweet buddy, Great Work.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now.....
Needed: paint and lots of it. and i'm sure lots more misc. parts.
Project 67 short step Build Thread
01 Sierra Crew 6.0
2015 Ford F150 Work gave me truck i really wouldn't buy a ford.
67-C10 is offline   Reply With Quote
Old 07-29-2010, 01:01 AM   #779
67chevy1series
67chevy1series's Avatar
x2
67chevy1series is offline   Reply With Quote
Old 07-29-2010, 01:45 AM   #780
jlaird
jlaird's Avatar
looks great but what happened with the rallies?
jlaird is offline   Reply With Quote
Old 07-29-2010, 10:26 PM   #781
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks for checkin out the thread! I appreciate the comments!!!
x2
Thanks Bro!
Still got em! They are in the storage shed behind the shop and are awaiting new tires. I have plenty of other things to spend my money on for now so the tires are kinda on the backburner. Radiator and hoses, brake booster and lines, and front crossdrilled rotors are on the menu for now.
Old 08-03-2010, 09:01 PM   #782
67chevy1series
well when you get any of that stuff let see it or hear about it oh wait its a sit well lets see about it
Old 08-03-2010, 10:46 PM   #783
kev2809
low n' slo
kev2809's Avatar
hey david, figure i would drop by. i checked out your truck and "that other car" the day i went by the shop lol
both are very clean man, the paint on both of them looks flawless. i was asking your friend ronnie about the a/c setup and he said you might go with vintage. did you already get the stock setup or is it just going to be easier to go with vintage?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-04-2010, 12:40 AM   #784
Slick67
Sofa King Crazy!!
Slick67's Avatar
It's gonna be a while before that stuff happens, having to slow my roll on the project to save some $$$. It will crank back up when the funds are right!
Thanks Kevin! Glad you got to see them! It was an A/C truck so I have all the stuff that came off of it, but Vintage Air is probably what I will go back with. The expense and the reliability are what made up my mind. To revive the old system would actually cost more in the long run. I'll get those parts powdercoated Thursday maybe Friday so you can scoop em up this weekend.
Old 08-04-2010, 09:53 PM   #785
kev2809
low n' slo
kev2809's Avatar
no rush on the parts. im going to corpus christi this weekend anyways, might get a chance to go sunday if your there.
hey, what headers are you gonna run? i seen the stock ones in there, you gonna paint them or go with shorties?
-_--_--_ _________
Old 08-05-2010, 01:11 AM   #786
Slick67
Sofa King Crazy!!
Slick67's Avatar
Goin with shorties or 3/4's not sure yet, but they will be ceramic coated. I hope others on here don't think I am going to run the crusty manifolds!
Old 08-05-2010, 11:10 PM   #787
67chevy1series
so whats next on the interior
Old 08-06-2010, 12:06 PM   #788
Slick67
Sofa King Crazy!!
Slick67's Avatar
Ducting under the dash and getting the seats bolted down for a test fit with the carpet in. I suppose I could wire everything under the hood so I could get my radio workin. You are more than welcome to come by and help!
Old 08-06-2010, 01:26 PM   #789
67chevy1series
i will be right there
Old 08-07-2010, 10:50 PM   #790
David67
David67's Avatar
Man.....I just read through the thread and your truck is sick!! Nice meeting you at the show tonight. I hope I can see this someday in person!
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 08-08-2010, 02:04 AM   #791
Slick67
Sofa King Crazy!!
Slick67's Avatar
Dude, anytime you like. Likewise, nice meeting you. I'll PM you my number and you can swing by the shop and check it out. It's about 12 minutes from the car show.
Old 08-08-2010, 10:53 AM   #792
kev2809
low n' slo
kev2809's Avatar
what car show was there that I missed?
-_--_--_ _________
Old 08-08-2010, 12:40 PM   #793
Slick67
Sofa King Crazy!!
Slick67's Avatar
It's the Niftee 50ees, every Saturday night starting at about 5:30 till about 9. Located at Spring Cypress @ Champions Forest Dr. right off of 249.
Old 08-09-2010, 10:08 PM   #794
Slick67
Sofa King Crazy!!
Slick67's Avatar
Since I got my new camera I have been takin a few photos. This is my nephews truck beside mine, and a shot of the candy paint. If you look to the side of the shop......Ronnie's new doghouse is being built for when the little woman gets mad at him.
Old 08-09-2010, 10:50 PM   #795
David67
David67's Avatar
Attachment 619937
Attachment 619938
Attachment 619930
Good to see them together! That paint really pops!! What's the color again?
1967 C10
IG: david_r67
Old 08-09-2010, 11:05 PM   #796
kev2809
low n' slo
kev2809's Avatar
I see you guys cleaned up lol..truck looks nice! what's the plans for your nephews truck?
ima have to check out that show when I get my truck running..sounds like fun. I wish we had somethin like that around here.
-_--_--_ _________
Old 08-10-2010, 12:00 AM   #797
VA72C10
VA72C10
VA72C10's Avatar
Looking good! Nice pair of trucks. Clean stock and clean modified!!!
Love the pearl....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-10-2010, 12:24 AM   #798
mcbassin
Still Learning
mcbassin's Avatar
Still trying to get used to your avatar change, it was different for so long.... Every time I stop by, I'm like, I recognize that truck but not that avatar? wait I know who that is. Anyways, the paint looks amazing in the sun! The other truck is very nice too!
mcbassin is offline   Reply With Quote
Old 08-10-2010, 12:24 AM   #799
67-C10
67-C10's Avatar
Heres his info.
Here we go. PAINT!!! Went to the paint store and got my paint it's called Oh So Orange. I got my blue ghost pearl powder in on Thursday so ready to paint. I moved everything outta the shop and cleaned it. We moved all of the truck parts in and set them up as they would be painted. Ready for Saturday.
Bottom line - 1 coat of sealer, 4 coats of orange, 4 coats of candy, 1 coat of ghost blue pearl, 2 coats of clear coat. That's 12 coats on it. D@MN!!!!!
01 Sierra Crew 6.0
Old 08-10-2010, 12:29 AM   #800
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks David! It is PPG Oh So Orange with Ghost Blue Pearl in the clearcoat.
We cleaned a little, but still have a mess to the side. Cody wants to keep it as stock as possible which is cool cause it is a Highlander truck. Come out before you get it running too. It's every Saturday and it's close to the shop.
Love the pearl....
Thanks VA, since I have not done anything to it lately I decided to take a pic of NO progress.
1967, custom, lwb
