#776 |
Re: 68 S/C update.....
That is a beautiful thing
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
#777 |
![]() Join Date: Apr 2012
![]() Posted via Mobile Device |
#778 | |
Ok she said we are good. Lol Posted via Mobile Device
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
#779 | |
![]() Join Date: Apr 2005
Thanks!
Thanks! Quote:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#780 |
![]() Posted via Mobile Device Posted via Mobile Device
#781 | |
Bolted headers and Dirty Dingo mounts on for fitment...
#782 |
very nice Rob!
-Rus |
#783 |
Cool motor and Trans.
Been watchin for awhile. Dig this build. Posted via Mobile Device |
#784 |
2WD Jimmy
![]() Join Date: Mar 2005
Hi Rod,
How much weight do you figure you'll be saving with this swap? Also, got any ideas on HP and torque estimates? Posted via Mobile Device |
#785 | ||
Thanks Rus.
#786 |
rob sweetest jewelry i have seen so far for valentines day imo!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#787 |
And the carnage continues.....$&^(*)#@#$%^&*(......
#788 |
A day late and $1 short...
Sometimes you have to backup to move forward...
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#789 |
You putting a Billet Specialties set-up on there, or sumtin similar?
#790 |
2WD Jimmy
Have you thought about that new no wires kit from MSD? It looks pretty sweet.
#791 | ||
True dat!
#792 |
looks like quite the assortment looks good brother
![]() Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289 - Dylan (209)-985-7721 |
#793 |
Hey!!!!!!!!!!!!!!
You cannot do carnage without the wrecking crew. You were supposed to save us something to do! We can't fix that. ![]()
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
#794 |
Hey Rob!!
Fantastic Build and engine!!! I had no idea you had changed directions with the motor until I started doing research for my 6.2 swap. Quick couple of questions for you if you don't mind. 1. What engine stands did you use? I'm going to use the dirty dingo mounts but I'm a little confused about if I can use the Big Block engine stands in my '72 Burb, or if I need to change over to the 73+ stands. 2. Will the factory ac compressor mount with the Dirty Dingo engine mounts? I found out from a reputable shop that the 6.2 AC compressor will work just fine with my Vintage Air Setup (yeah, that means I don't have to buy another compressor for the serpentine system and I hopefully won't have to buy other brackets, depending on what you say). THanks for your help!! Looks great!!! Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
#795 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#796 | |||
Thanks!
![]() Quote:
2. Just depends on the compressor and where you align your motor fore and aft. As far as using the factory compressor, as long as it's not a variable speed one, you will probably be OK. However most of the LS compressors won't work, at least that's what i've been told. Every setup is a little different, so there will be some trial and error no matter how much research you do. Quote:
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 03-01-2013 at 11:43 AM. |
#797 |
Time for some more carnage this weekend......
#798 |
Every great journey requires a first step.....
#799 |
No stopping you now man.
#800 |
And it only took 8 hours to get that far!
