Old 11-11-2010, 01:55 PM   #776
67cheby
67cheby
67cheby's Avatar
Re: 67 cheby's Dropmember build thread
im not sure about the gm application someone said s10 ?? i dont know
67cheby is offline   Reply With Quote
Old 11-11-2010, 01:59 PM   #777
texastrendz
found it, thanks. looks like a good idea on the alignment issue to move stuff around.
texastrendz is offline   Reply With Quote
Old 11-11-2010, 02:02 PM   #778
67cheby
67cheby
67cheby's Avatar
yes ... i havent drilled my arm for my brake yet but everything else has been really simple ,and looks a ton better, i used the upper 2 holes and just had to redrill the bottom 2 holes and used a 3 inch hole saw for the boot to go through , i will try to post a pic of that so you can see
Old 11-11-2010, 09:15 PM   #779
jasonhall
jasonhall's Avatar
That booster looks sweet.. might have to copy that idea!!
jasonhall is offline   Reply With Quote
Old 11-11-2010, 09:51 PM   #780
watahyahknow
watahyahknow's Avatar
i like the idea but i like to see if it will hold after some use , the shorter distance to the pedal lever might give the pin going intoo the booster a bit of up and down motion , im not sure if that will matter to the seal or not , if theres enough distance between booster and pedal you could make a valveguide like sleeve for the pin and some sort of cam/lifter type arangement on the pedal to prevent the pin from rocking
if you make the lift/ramp in the cam extreme at first and less so further up the travel you might be able to lessen the pedalswing and increase the feel of the braking
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-12-2010, 01:23 AM   #781
Bowtie468
Bowtie468's Avatar
Nice job on the booster. I've been eyeing mine and i think i need to do something with the stock mount. Trucks looking sweet !!
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1969 Camaro X44 LS swap
1968 C10 SWB Fleetside (SOLD)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (SOLD)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 11-12-2010, 03:22 AM   #782
ajgriffin
ajgriffin's Avatar
Originally Posted by 67cheby View Post
got my refurbished ac controls , today from TKORINEK (on the board) he did a super job they look awesome
Can you give us some details on these? Did you just remove your old A/C controls and send them to TKORINEK or did you just buy a refurb set off of him? They look awesome!
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 11-12-2010, 10:12 AM   #783
67cheby
67cheby
67cheby's Avatar
i just bought the refurbished one from him !! i think he has more, nice piece and very reasonable
Old 11-12-2010, 10:13 AM   #784
67cheby
67cheby
67cheby's Avatar
thanks bowtie468
Old 11-12-2010, 10:16 AM   #785
67cheby
67cheby
67cheby's Avatar
last nights progress , stripped the underneath of the hood..... what a PAIN IN THE BUTT
Old 11-12-2010, 11:26 AM   #786
es67chevy
es67chevy's Avatar
You do know about soda blasting don't ya?
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 11-12-2010, 11:40 AM   #787
67cheby
67cheby
67cheby's Avatar
i do know about it...my labor is free and soda blasting is very expensive, the one i checked with was like 120 an hour , it took me 2 hours to do the underneath of the hood , they could prob soda it in an hour but thats 120 i saved, i have about 20 hours in stripping the whole cab and front clip and my only cost is the sanding discs and paper, i think the soda blasting of it all would have cost me $800 ???just a guess
Old 11-12-2010, 11:55 AM   #788
es67chevy
es67chevy's Avatar
Good point and good figuring. We paid $775. You should treat yourself to something nice for saving all that money....like paint.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 11-12-2010, 12:17 PM   #789
67cheby
67cheby
67cheby's Avatar
what all did you get soda blasted for $775 ?? the whole truck ?? my buddy had his frame the inside of his bed the underneath of his bed and cab and it was 1200, that was last year, and who did you use ??
Old 11-12-2010, 01:15 PM   #790
68 TT
Still plays with trucks
68 TT's Avatar
The shops up here are a little less expensive but not much. I paid $600 to have a whole car soda blasted inside & out and underneath on a rotisserie. They had it done in a day.
I don't count my time as free labor. There are plenty of things I can do to make money with my time away from my job so I put a number of $20 / hour on my vehicle tinkering time. If I can get a job done by someone else for less than my labor rate doing the job myself would add up to I have someone else do it. This also includes having to buy a special tool to do a job. If it doesn't add up I do the job myself.
It would have taken me at least 40 hours to do that total body strip job mechanically and probably $50 in abrasives plus all the electricity to run my compressor non-stop for a week. I figure it saved me about $250 in time & materials plus I was able to spend that 40 hours on other tasks making more progress.
I nearly bought my own soda blasting setup instead to do the job myself. I may still do that as I have several projects that could use that right now.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-12-2010, 01:24 PM   #791
67cheby
67cheby
67cheby's Avatar
if i would have been able to get the whole thing done for $600.... i would have hopped on that also !! great deal, and yes that is a good point about what to figure your pay at
Old 11-12-2010, 01:29 PM   #792
LEEVON
Moderator
LEEVON's Avatar
Elbow grease is cheaper. A guy down the road does commercial soda blasting and alot of cars, trucks, jeeps on the side. He's $100/hr plus materials. Since I've seen him spend a very long day or weekend on a whole car you could figure at least $1200 plus materials at maybe $300-400. I've had him blast some stuff and usually wish I had just prepped it myself.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-12-2010, 01:37 PM   #793
67cheby
67cheby
67cheby's Avatar
with the auto business in its current state ... i have alot more time than money!!!!!
Old 11-12-2010, 01:41 PM   #794
67cheby
67cheby
67cheby's Avatar
i copied it from 1moretoy....the credit is all his
Old 11-12-2010, 02:04 PM   #795
es67chevy
es67chevy's Avatar
I had the cab, doors, and bedsides blasted. No hood, front clip, etc. they said if they were doing it again, they would have stepped up to a more abrasive media. they used walnut shells for mine. there was so much bondo though, that's what added the extra time. I can't remember what their business was called but the number is 531-7355 if you are ever curious.
Since you have the time and the energy, sounds like you went the right way for sure. I just didn't have the patience or time myself.
Eric
1967 C10 SWB
383 Stroker/TH400
Surf Blue Paint
Old 11-12-2010, 07:20 PM   #796
superflysteiny
superflysteiny's Avatar
1200 is cheep for a car to be blasted and sealed. Out here it is close to 2000 a car. The guy is the best in Sacramento but he is not cheep
superflysteiny is offline   Reply With Quote
Old 11-12-2010, 07:39 PM   #797
67cheby
67cheby
67cheby's Avatar
wow.... do they do any chemical dips ??/ is that more expensive, i always thought that would be the way to go but there is not anyone around here that does it and i am sure i couldnt afford it anyway
Old 11-12-2010, 09:12 PM   #798
watahyahknow
chemical dip is exremely iniromently unfriendly most people working the stuff dont live long
it is better for the metal though and leaves the protective zinkoxide on the surface (sanding and blasting takes it of ), it allso leaves a resideu on the metal and in the holow spaces holes need to be drilled intoo them to get the liquid to draw out after the dip
those holow spaces will be stripped but theres no posibility to get paint in there again , theres also a chance of the resideu contaminating the new paintjob
Old 11-13-2010, 10:24 AM   #799
67cheby
67cheby
67cheby's Avatar
oh... no wonder you dont hear to much about the chemical dips then !!
Old 11-15-2010, 02:33 PM   #800
superflysteiny
new pictures
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
