09-07-2010, 08:24 PM | #776 |
Re: What did you do to your truck today!
Went to a machine shop to inquire about having my L6 head cleaned up. When I got back to the truck it wouldn't start..... The mechanic came out and gave me a jump. Then I replaced the alternator. What a better place to need a jump than mechanic shop.
09-07-2010, 08:50 PM | #777 |
Rottenwood Garage Member
Painted my control arms with POR-15.
I think I am still loopy from the fumes! Todd |
09-07-2010, 09:24 PM | #778 |
Cruzin
picked up the block and crank from the machine shop for the 67
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
09-07-2010, 10:43 PM | #779 |
Changed my cam and lifters. Easy job everything went perfect. Nothing went wrong.....NOT. What a pain in the but. If I ever have to do this again I will pay someone to do it.
Mark 1968 C-10 SWB 307/munci 4spd/411possi 1986-1990 1972 Cheyenne-10 LWB 350/TH350 IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER U. S. Navy Seabee "CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard" |
09-07-2010, 10:56 PM | #780 |
Installed a new battery tray and finally got her running.
09-09-2010, 05:17 PM | #781 |
Took the plunge and ordered the 69 camaro gas tank kit. Got the tank, sending unit, straps, lock ring/o ring and the anti-squeak kit for $194.00. Will relocate the filler to behind the license plate.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
09-09-2010, 05:31 PM | #782 |
Took Tilt Apart To Repair What Other Guy Should Have Fixed..
Started Lowering Ordered Weather Striping Kit Posted via Mobile Device |
09-09-2010, 07:27 PM | #783 |
Removed fenders and box for a trip to the body shop as someone frenched in some lights and it has since rusted. Shes going back to factory. Hooked up a TPS to the quadrajet
09-09-2010, 07:38 PM | #784 |
Who did you buy the kit from? I'm looking to do the same.
Truck's just for the fun of it. |
09-09-2010, 08:39 PM | #785 |
Cruzin
cleaned one window, changed oil in the 97
09-10-2010, 08:19 AM | #786 |
started cleaning up the burb for the Pickups-n-Panels show tomorrow.
http://www.picturetrail.com/jwill41 67 1/2 ton GMC short step side 68 1/2 ton Chevy long fleet side 72 1/2 ton Chevy Suburban 99 1/2 ton Chevy Suburban founder (and only member) of the primer/clearcoat club |
09-10-2010, 03:34 PM | #787 |
i done several burnouts and then went to my friends tire shop and got a new set of cooper cobra radial gt 275/60/15 it looks and handles a lot better i dont know why even make other sizes
09-10-2010, 03:44 PM | #788 |
get us a picture of those tires i am also looking at that tire size for my 1962 gmc.
09-10-2010, 09:40 PM | #789 |
Cruzin
got the bearings and rings for the 67
09-11-2010, 02:27 AM | #790 |
Re-installed clutch return spring. Was looking under my truck for something, and saw the spring had come loose from the frame. Slid(? forced) my big fat behind under the truck and put it back on. Thought the clutch pedal felt funny.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. Last edited by OhioDan; 09-11-2010 at 08:38 AM. |
09-11-2010, 07:49 AM | #791 |
Got my front cross member painted.
4 a arms and a cross member and I have only used 1/4 quart of por-15. This stuff sure goes a long way! -Todd |
09-11-2010, 08:30 AM | #792 |
Redefining LowBudget
yep just be sure to lay a piece of plasic wrap over whats left in the can (like a paint skin) then throw it in the freezer ..or whats left will be like a rock!!!
well I adjusted the drum brakes on the truck cleaned up the points lubed everything under the cap checked the tire presure...and loaded the chain saw!!...Yep its that time of the year again Fire wood season!!! |
09-11-2010, 02:27 PM | #793 |
Worked on some gauges.
09-11-2010, 03:42 PM | #794 |
hey on my wood detail today I scored an Apache pop up camper...the shell is good with all the hardware so I'm going to look into new canvas...if not it may get a chopped down tonue cover and I'll use it to haul my camping stuff..either way its a win
09-11-2010, 03:49 PM | #795 |
Mounted my front wheels and painted and installed my Big Block perches.
Brad handshoe |
09-11-2010, 04:13 PM | #796 |
re-installed the transmission ... yay! no leaks!
09-11-2010, 05:42 PM | #797 |
20' Daredevil (Ret)
Re-installed a steering stabilizer I had just cleaned up & re-painted. While I had the creeper out, I changed oil & filter and greased all the zerks.
Nothing exciting, but it needed done....
09-11-2010, 07:04 PM | #798 |
Cruzin
built the lower end of my motor for the 67
09-11-2010, 09:08 PM | #799 |
Started redoing the brake system on the 72. Then went and took a look at a 69 for parts, yes it followed me home tonight.
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
09-11-2010, 09:16 PM | #800 |
Pulled the bed, and the PO's in-bed gas tank off the '72.
