Old 03-01-2014, 10:35 AM   #776
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Originally Posted by jbclassix View Post
So, why just angle the exhaust manifold rather than fabricate a complete masterpiece? Educate please.
for this engine it really wasnt necessary to improve the OEM manifold. this one is going to be somewhere in the 500hp range. so as opposed to create a huge can of worms trying to make a manifold(and believe me, i thought about it) it was more sensible to go with an OEM. since i cant leave anything alone, i had to cut it to fit my needs. the next engine will probably get a fabricated exhaust and intake. looking for 1k HP from that one, so a masterpiece will be better. also, in the name of tax deductions i am going to try to get myself a tig welder this year, and that will greatly assist in making a manifold.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-01-2014, 11:02 AM   #777
mx289
mx289's Avatar
Re: 72 k20 project
Looking good Ryan.
Those stands look killer.
Tom
mx289 is offline   Reply With Quote
Old 03-01-2014, 07:22 PM   #778
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks!
i melted the mounts together. these mounts are big and give me a solid landing pad for the turbo support and on the other side i need to fab a rear support for the hydraulic pump and air compressor.
i also yanked all the stock lift pump and fuel filter off the engine. i'm going to have to start thinking about fuel filters and lift pump mounts soon and it was in the way anyhow.
72 K20 12v build
Old 03-02-2014, 03:34 AM   #779
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
Nice work Ryan. Does that little heater on your bench work pretty good?
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-02-2014, 10:25 AM   #780
ryanroo
ryanroo's Avatar
Re: 72 k20 project
the yellow one works fast, but doesnt cover much area... haha
usually what ill do with that is turn in on when i head to the gym. it cuts the chill down enough by the time i get back that i can usually be fine. i have a propane space heater that i run if it is real cold. as long as i am parking something in the garage that is warmed up when its parked, the garage space stays over 40 most of the winter. so as long as i can get it up to about 50 i can work comfortably
72 K20 12v build
Old 03-02-2014, 12:41 PM   #781
Dieselwrencher
Re: 72 k20 project
40* sounds like summer for around here right now.
Ryan
Old 03-02-2014, 06:26 PM   #782
ryanroo
ryanroo's Avatar
Re: 72 k20 project
i installed the now cooled off enough to touch mounts on the engine. everything worked after welding with no problems.
then i could do this
so could measure the back of the engine.
72 K20 12v build
Old 03-03-2014, 02:27 AM   #783
Dieselwrencher
Re: 72 k20 project
Ryan, nice work. It looks like it balances out nicely.
Ryan
Old 03-09-2014, 04:08 PM   #784
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks Buddy. it did come out well. i looked at the OEM oilpan after i pulled the trans. i may actually be able to make one work if i rework a pick up tube. i kind of want to have a BA aluminum pan, but i am considering taking the easy way and just cut and paste on a stocker. the trouble is, my pan is junk, so... i either buy a new one and chop it up, or buy some aluminum and sacrifice several extra hours of my life for the sake of wow factor.
anyhow,
i got my engine stand finished up and pulled the engine. now the cleaning and tearing down starts and i will be ordering seal kits soon.
72 K20 12v build
Old 03-09-2014, 05:37 PM   #785
BigRed76
BigRed76's Avatar
Re: 72 k20 project
Now that's an engine stand, it makes a Cummins look small
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 03-09-2014, 07:26 PM   #786
ryanroo
ryanroo's Avatar
Re: 72 k20 project
that was my first thought when i looked at it. "man, that doesnt look that big..." must be the pink, sucks the manly right out of everything. haha
this thing is solid as a rock. several times i leaned into a tight bolt and it never crossed my mind that i was working on a engine that was on a stand. not an experience i've had before...
looks nice and clean up top
KDP is in place and never been tabbed. lucky.
definitely need a sleeve.
need a bigger bag...
72 K20 12v build
Old 03-09-2014, 07:58 PM   #787
mx289
mx289's Avatar
Re: 72 k20 project
That is an awesome stand Ryan.
Of course its pink.!
Tom
Old 03-09-2014, 08:49 PM   #788
classicthrasher
Re: 72 k20 project
Where do you get your gaskets and internal replacement parts? I'm guessing the local parts store would have most of the stuff, but didn't know if you use Cummins stuff or had a preference on aftermarket. (Begin thread hijack). I have a 95 dodge auto trans motor that needs at least gaskets. I have no idea of mileage, but the head and water pump have been replaced more recently than anything else. New to the diesel world and not sure how far into the motor I should go...pull the head and make sure pistons and cylinders are okay? Motor is currently in a p30 bread van and has an nv4500 behind it, and runs. I drove it 70 miles home without a hitch. You or Diesel Wrenchers (or anyone else's) advice would be appreciated. What do I need to do to get reliable and economical 350-400 HP from a 160hp motor?
Thanks. Great build as well. I enjoy seeing the fantastic welding and fab.
Oh, no signature yet as I haven't really done anything to my project...49 Chevy 3600 is what this is going in.
classicthrasher is offline   Reply With Quote
Old 03-10-2014, 12:30 AM   #789
6lcummins
Re: 72 k20 project
As far as gaskets, I know we tend to go with Genuine Cummins Gaskets. We also have another source that we get overhaul kits from. I'm DieselWrenchers brother BTW. To get the HP goal you want its some pretty small adjustments but it will depend how good your clutch is too. As far how hard you push it. I'd do Injectors, governor springs, and play with the AFC and be good.
1996 Dodge 2500 Ext Cab Long Bed P24V Cummins Turbo Diesel 5 speed 4x4
"STOCK"
ASSEMBLY THREAD
6lcummins is offline   Reply With Quote
Old 03-10-2014, 07:21 AM   #790
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Well, he is alive! haha
i had typed out the same basic response, but i guess i hit the back button instead of the submit button or something. i dont really know what happened.
72 K20 12v build
Old 03-10-2014, 03:49 PM   #791
Dieselwrencher
Re: 72 k20 project
Hopefully Ryan doesn't mind a bit of a hijack...
Stay away from felpro head gaskets for these engines. They are junk. We've even had multiple failures of the blie felpro valve cover gaskets. We usually use genuine cummins parts because they are better in quality and we can get them locally. That bread truck didn't come from Lathrop did it?
Ryan
Old 03-10-2014, 03:51 PM   #792
Dieselwrencher
Re: 72 k20 project
Ryan, that stand does make the engine look small. You did a great job on that stand. I'm jealous. Why bag your engine now? You've had the lower end open for a while. Haha I know where a stock pan is or even a little different more capacity pan is as well.
Ryan
Old 03-10-2014, 04:24 PM   #793
classicthrasher
Re: 72 k20 project
Yes, it came from Lathrop.
Old 03-10-2014, 08:56 PM   #794
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Thanks! i figured you would be jealous after the pink paint.... i covered the bottom any time stuff was flying. but its easy for stuff to fall in the top, hard fro it to fall in the bottom. plus. dust season is coming. i just need to be in the habit of keeping it clean. we see a lot of utah in the air during the spring wind season.
ill think on the pan. i am still on the fence as to weather i want a flashy pan, or an easy one.. haha
and why would i care about a thread jack at this point? this thing is all over the board already, the more the merrier!
72 K20 12v build
Old 03-11-2014, 09:49 PM   #795
ryanroo
ryanroo's Avatar
Re: 72 k20 project
so, i got the pump pulled. i cant stress how nice this stand is to work on. i didnt want it to pop off and land of the floor. Quick little spin of the handle and no more issue. no amount(as of yet) of my fiddling has mad it shake. i need to make some parking brakes, as it moves to easy, but that is a good thing.
these pumps are huge.
72 K20 12v build
Old 03-11-2014, 10:42 PM   #796
6BT 56
6BT 56's Avatar
Re: 72 k20 project
Why is the ruffest tuffest eng stand on the planet pink ? Lol....
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-11-2014, 10:53 PM   #797
ryanroo
ryanroo's Avatar
Re: 72 k20 project
exactly!
72 K20 12v build
Old 03-12-2014, 12:36 AM   #798
84chevyguyid
Re: 72 k20 project
Those pumps remind me of the old caterpillars, has a pony motor hanging off the side of the engine.
84chevyguyid is offline   Reply With Quote
Old 03-12-2014, 11:48 AM   #799
Dieselwrencher
Re: 72 k20 project
They definitely are big. Ryan, you could make some steel wheel chocks to put around the wheels.
Ryan
Old 03-12-2014, 11:14 PM   #800
6lcummins
Re: 72 k20 project
Yep I am alive, just been lurking and keeping busy.
If you can wait, I know of some billet o-ringed oil pan rails being made....
"STOCK"
ASSEMBLY THREAD
