#776 |
Re: 1967 Chevy CST aka "the loud truck"
well i gave her a bth for the frist time since the incident. and shes looks good
#777 |
C/10 junkie
She sure does.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#778 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
She looks great, but you need to replace the air freshener with some red fuzzy dice
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#779 | |
not as good as yours though!
Posted via Mobile Device |
#780 |
Well it's been tough trying to track down the perfect 327.... And I know that when your not looking for something then that's when you'll find it. So with that being said I have decided to take the perfectly good and strong running 350 I have and take it apart freshen it up a bit and then give it a orange overhaul and put that in the truck instead. I've also found a guy with a 3:73 posi rear axle that I might be able to trade my carrier for his! So a possible posi coming up and the 350 will go in before the end of this year if I have my way.
#781 |
C/10 junkie
That would be a good deal on the posi. That's what I did with the 350 that I got, took it apart and detailed it.
#782 |
Junk Yartist
Hey rick you know a large journal 327 and 350 are the same block right?
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#783 | |
![]() Posted via Mobile Device
#784 | |||
#785 | |
![]() ![]() Posted via Mobile Device
#786 |
Well after I decided to just forget trying to find a 327... Guess what.. Found one! It's perfect candidate! Should get it somewhere in the next 2 weeks
#787 | |
#788 |
Alright got a question for you guys... This 327 has the fuelie heads.... And that's a BIG problem for me since I'm using 69-72 alt. brackets which mount to the front of the head... It is to my understanding that the fuelie heads or camel hump heads don't have threaded holes in the heads front an back correct? Could I take the heads to a shops and have them drill out the 2 holes I need am thread them? Or am I gonna have to find the 67-68 driver side exhaust manifold and lower alt. bracket since I already have the upper one?
#789 | |
#790 |
C/10 junkie
Check first. My heads are the later style fuelie heads and have the accessory holes. Early ones do not. I also have a large journal 327 out of a 68 Chevy truck that will one day go in my truck. I may start building it later this year.
#791 |
well this one is a large journal 327 and its from a 67... so its a pretty early fuelie heads. in the pictures the it shows the rear of the engine and the back of the heads dont have any holes in them, so that means the front doesnt either? and yeah those were my thoughts.. i was thinking that they have a different routing for everything and there might not be room in the cast for a threaded hole. but supposably these are the hot heads right?
#792 |
heres the pics from the ad
#793 | |
#794 |
hey thanks! I have the long bracket that curves and bolts to the top of the alt. just need the lower one and the driver exhaust manifold that has the threaded holes in it and I'm set for the conversion
#795 |
No problem, not sure I have one anymore but I'll look. The best heads back then are real rare, yours are the fuelly 1.94 intake. They also had 2.02 intake and angle plugs these are hard to find. I always ran the 1.94 and always had good luck with em.
#796 |
These heads are supposed to be racing heads right? Pretty good power and quick response is what this older gentlemen was telling me
#797 | |
#798 | |
#799 | ||
C/10 junkie
![]() Here is a couple pics of mine
#800 | |
