Old 01-20-2016, 02:23 AM   #776
sqweaka
Re: How about some pics of bagged 47-59
no.. seen them on lots of AD's mine are a bite beat up
sqweaka is offline   Reply With Quote
Old 01-27-2016, 06:01 PM   #777
Coach529
Coach529's Avatar
Getting closer to a bagged truck......
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 01-27-2016, 11:16 PM   #778
youngrodder
youngrodder's Avatar
Coach..technically you need bags....JK
I agree you are getting close.
Looks good
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 01-29-2016, 09:14 AM   #779
Coach529
Coach529's Avatar
Looks good
Marc
As of last night I am 25% bagged.
1949 Chevy 3600
Old 01-29-2016, 10:37 PM   #780
youngrodder
I like it....some bagged is better than no bagged any day.
Marc
Old 01-29-2016, 10:41 PM   #781
Advanced Design
Advanced Design's Avatar
25% bagged...good one! Did I see you have bags on FB for sale?
Advanced Design is offline   Reply With Quote
Old 01-30-2016, 02:14 PM   #782
Coach529
Coach529's Avatar
I do......actually I need to delete the post. I was running into some issues with enough space.......so I thought if I could unload these I would buy some smaller ones.
I ended up just making the bigger ones work.....
1949 Chevy 3600
Old 01-31-2016, 03:25 PM   #783
Dan in Pasadena
Dan in Pasadena's Avatar
I hope no one minds if I ask a couple dumb questions about airbag suspension here. I don't want to derail the picture thread. Just figured I'd get most of the experienced air bag guy's answers here.
My truck is currently stripped to the frame and I'm installing a Fatman IFS system and flipping the rearend on top of the leaf springs with a mild C notch. I also removed the rear leaf mounts with the original intent of flipping them on top of the frame but the total amount of lowering may be too low for me - yeah I know, heresy to the airbag crowd ha ha!
I do not intend to "lay frame" and I don't want problems entering driveways, etc. but I would like to cruise a little lower than a status drop will let me and not have to deal with the driveways, speed bumps, etc.
Question #1: If I decided to later, could I just remove the coil springs and shocks and mounts airbags in their place? It SEEMS like that should be possible on the front end.
Question #2: Is it possible to use airbags on the rear with leaf springs? If so, would they only work as a load assist? Or would I need to switch my rear suspension to a four link or similar? I don't intend to use my truck as a truck except I MIGHT want to tow a couple jetski's infrequently. That isn't really important if it's not doable. But for those that have done it, what kit is recommended etc?
Questiin #3: what about Accuair type systems? Unnecessary? Good for what I'm talking about?
Thanks for any advice. -Dan
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 01-31-2016, 03:28 PM   #784
Boom
I am not experienced with air ride setups but you really have to have a set up similar to a coil spring suspension where the bag takes place of the spring.
Boom is offline   Reply With Quote
Old 01-31-2016, 03:51 PM   #785
heavy_chevy
heavy_chevy's Avatar
you will have to remove the center leafs and it will work.
heavy_chevy is offline   Reply With Quote
Old 01-31-2016, 08:13 PM   #786
59chev
59chev's Avatar
Dan,
Flipping the rear leaf spring shackle actually raises the truck back up a couple of inches. It is discussed in the No Limit Flip kit thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=442586
You can definitely use airbags with leaf springs. If you go through lowrodderchev's build thread that is what he used. You just remove a bunch of the leaves then add the airbags to add back the load handling capabilities. http://67-72chevytrucks.com/vboard/s...d.php?t=601554
For my truck I am planning on a mild c-notch with a 4 link and bags in the rear and just the stock springs in the camaro clip in the front for now.
My Build Thread: 59 Apache - Lifelong obsession
http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession
59chev is offline   Reply With Quote
Old 01-31-2016, 08:28 PM   #787
IndyBowtie
IndyBowtie's Avatar
Dan
I was in a similar dilemma (and have the same name). Ran my Fatman front MII for 4 years with springs, and stock rear springs in back, with a few stiff leaves removed. I tow vintage campers and the rear was awful soft so I installed air shocks, but still didn't like the ride. Decided to 4 link it, and bought a kit that included air bags for the rear (TCI). Probly could have just got by with Schrader valves, but then opted for a tank, valves, lines and compressor system from a local merchant ( not an AccuAir). I spent a ton on the parts as it was, but if you want to spend the extra for AccuAir that's your decision.
Well, before I even got it back on the road, decided to convert the front to bags as well. Fatman makes a neat conversion kit to do so. Of course more$$$.
Now...I am not laying the boards. No frame notch, or center cross member and cab notch. Aired out the boards are 4-5" off the ground. That's with urethane bump stops contacting the axle so the frame doesn't . At best bag pressure for ride the boards are 7 1/2" off the ground. I think am will happy with it. Can't answer the question of bags and springs, but a lot of dudes I talked to suggested against it.
Regards
Dan Sutton
IndyBowtie is offline   Reply With Quote
Old 01-31-2016, 09:37 PM   #788
47 Fasttoys
47 Fasttoys's Avatar
As Dan said, with the Fatmans air bags on the front are easy. For the rear I run helper bags for extra load, in my case I do not lower the rear but do load it heavy at times and tow on a regular basis. For the most part I run 5 psi in the rear. For the accu-air I'm sure it is a good set-up but it's over kill for most, and your compressor will be running a lot from what others have told me.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 01-31-2016, 11:16 PM   #789
99 to Life
99 to Life's Avatar
I have the accuair VU4, I like it but if you're on a budget go with little larry's manual valves. I think the day and age of valve blocks becoming the norm and affordable are right around the corner. just keeps things clean and easy, but expensive.
as for bags on leafs. I'v seen it done and to me is just a band aid. But I never had a set up using it, so who knows might work ok for your driving might not for others.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 02-01-2016, 07:44 PM   #790
lower50's
lower50's's Avatar
Coach 25% or 1/4 finished, what ever sounds closer to done
Dan With bag over spring I would be worried about axle wrap.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 02-01-2016, 09:30 PM   #791
Coach529
Coach529's Avatar
50% now. :-)
1949 Chevy 3600
Old 02-01-2016, 10:16 PM   #792
Dan in Pasadena
Ok so it sounds like the consensus is bags with leaf springs is a bad idea. Understood.
Old 02-01-2016, 11:27 PM   #793
Layedoutsonoma91
Layedoutsonoma91's Avatar
Sometimes its worth it in the long run to ante up and get the right things, the first time. You will be much happier with a link instead of leafs. I have had like 6 bagged trucks and have learned that the hard way first hand. It sucks redoing work that you thought you had finished.
1954 Chevy 3100 5 window, bagged on s10 frame,
6.0 ls swap/4l80e
Past build thread
http://67-72chevytrucks.com/vboard/s...=531261&page=3
1949 3100 s10 swap 5.3.
Instagram -@thejcates
Layedoutsonoma91 is offline   Reply With Quote
Old 02-01-2016, 11:31 PM   #794
Layedoutsonoma91
guess ill contribute to the thread topic since im here haha
6.0 ls swap/4l80e
Past build thread
Old 02-02-2016, 07:51 AM   #795
4DSEVEN
4DSEVEN's Avatar
4DSEVEN is offline   Reply With Quote
Old 02-02-2016, 12:21 PM   #796
FarmerSid
FarmerSid's Avatar
Nice 4DSEVEN! Where abouts in Ontario are ya?
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-02-2016, 05:08 PM   #797
4DSEVEN
4DSEVEN's Avatar
Tks man. I'm in Ottawa.
Old 02-02-2016, 06:52 PM   #798
Advanced Design
Beautiful!
Old 02-03-2016, 09:24 AM   #799
FarmerSid
FarmerSid's Avatar
Cool! Take a short trip west down the 401 sometime and show off your truck. Would love to see it in person.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-03-2016, 06:07 PM   #800
panelrodder81
Doin' it live!
panelrodder81's Avatar
My bagged 53 panel. M2 front with Speedway bag kit. RideTech triangulated rear with Shockwaves.
-Panelrodder
1953 GMC Panel truck - 'Curly'
1961 Chevy Suburban - 'Larry' - Sold
2005 Harley Sportster - 'Shemp'
panelrodder81 is offline   Reply With Quote
