#776 |
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
Great job mike
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
#777 | ||
67cheby
![]() Join Date: Sep 2008
Thanks man...about the only option ! Quote:
thanks man ! |
#778 |
67cheby
i made a side profile pattern of the complete frame and then made a new pattern with all the right angles so i can lay out the 2x4 Tubing and get it all cut, i am also making fish plates that will be mounted on the inside of the tubing and be plug welded at every joint.
and did a little welding on the floor panel patches |
#779 |
Lookin good sir! I can't wait to see this frame take shape!
-Rus |
#780 |
looking at the template im wondering if you can have al the sides of the frame cut out in one length on a waterjet have them bend where needed and weld the edges together intoo the boxshape , it actually might save a bunch of grinding and should look a lot cleaner but it might be hard to control warping and keeping the box shape square
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
#781 |
Gonna look good, can't wait to see this frame done
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
#782 |
Nice work man!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#783 | ||
67cheby
me too...this whole frame thing has put me a little behind my schedule i need to make up some time !
thanks man |
#784 |
in. chassis fab is right up my alley. i kind of prefer the 4x4 stuff but i love fab no matter if there is a transfer case or not!
the frame table is really cool. i am wishing i had one now as i set up to link/bag the rear of my truck. a lot can be done without a table if you spend plenty of time measuring and tacking and bracing. Ryan |
#785 |
![]() Join Date: Dec 2006
Just caught up on the build Mike, looks great. I must have fell asleep at the wheel on this one as I don't know how I missed it
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#786 |
67cheby
Finally got started on the frame rails ! i have them tacked up for the moment they have to comepletely back apart so the inner fish plates can be installed and plug welded in place (that is the reason for all the holes)
#787 |
![]() Join Date: Mar 2011
Looking good so far Mike, doing a nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#788 |
![]() Join Date: Dec 2012
Excellent! Looks like just enough room over the axle for a bumpstop when it's aired out! Now for a bumpstop on TOP of the frame for the rear seat passenger...
jk
JK |
#789 |
Looking good Mike!
-Rus |
#790 |
I'm just glad to be here!
Looks good, keep it up...
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#791 |
That's gonna be sick! Are you getting the fish plates done on a burn table, water jet, laser.....? What's that piece with the bolt circle?
#792 |
Man of Mini-Talents
Help us non big time frame fabricators out here - what are fish plates and plug welds?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#793 |
67cheby
yes cut on a plasma table, that piece is to hold the rearend at exactly 15 inches off the ground so i can set it up to clear a 30 inch tire and wheel combo
#794 |
Fish plates on the inside of the tube...nice!
#795 | |
67cheby
It just strengenthens each joint where there is more then just the one welded seam holding each joint together |
#796 |
looks nice mike !!!!!!
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
#797 |
You may already be planning this, but you might groove the vertical seams so that your actually making a butt with backing weld instead of just a grooved butt weld. that will tie both pieces of tube to each other and the fish plate at the joint.
looks great though. |
#798 | |
You sure you are working on a Blazer, that frame looks like a suburban ![]() ![]() ![]() ![]()
67- 72 Parts collecter |
#799 |
Looking good!
Posted via Mobile Device |
#800 |
67cheby
Thanks guys and yes I am planning on v cutting all the seams, I want this thing to be rock solid !
