Old 01-29-2017, 06:34 PM   #776
mooseknuckles
mooseknuckles's Avatar
Re: Owen's C10
all finished.. got the headers test fit too, they look like they're going to work.
mooseknuckles is offline   Reply With Quote
Old 01-29-2017, 06:49 PM   #777
72 tigger
72 tigger's Avatar
Re: Owen's C10
Like the valve covers- good choice! If you could do it over, would you have modified the firewall?
72 tigger is offline   Reply With Quote
Old 01-29-2017, 07:02 PM   #778
Advanced Design
Advanced Design's Avatar
Re: Owen's C10
I like the look too. Great work. Where did the valve covers come from?
Advanced Design is offline   Reply With Quote
Old 01-29-2017, 07:40 PM   #779
mooseknuckles
Re: Owen's C10
Thanks! I don't think I would, even with the stock v/c the motor sits too far inside the firewall IMO.
thanks, they are Proform.
Old 01-29-2017, 08:03 PM   #780
jwilb88
jwilb88's Avatar
Re: Owen's C10
Where did you get the AN style coolant crossover fittings? The ones on that attach to the block
jwilb88 is offline   Reply With Quote
Old 01-29-2017, 10:54 PM   #781
mooseknuckles
Re: Owen's C10
they're from Trickflow summit # tfs-30600611
Old 01-30-2017, 09:38 AM   #782
Bennett68C10
Bennett68C10's Avatar
Re: Owen's C10
Love those valve covers Good to see you could modify your motor mounts a little instead of modifying that beautiful firewall. That would have sucked. I like the way the Trickflow coolant crossover lines look, think I'll have to get those for mine.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-30-2017, 09:50 AM   #783
boostedc10
boostedc10's Avatar
Re: Owen's C10
Looks great Moose. Used the Trickflow kit on my motor from Summit too. Price was right and looks really nice.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 01-30-2017, 06:36 PM   #784
mooseknuckles
Re: Owen's C10
I bought the Trickflow kit that does both front and rear lines, it was another $30 or so but it gives you more braided hose and more fittings...I have enough left for another motor... yeah there was no way in the world I was touching that firewall, I have way too many hours in that, the motor mount trick only took about an hour of my time, and also helped with the steering shaft clearing the #1 header tube... I love the valve covers too, thanks for helping me deside..
Old 01-30-2017, 06:37 PM   #785
mooseknuckles
Re: Owen's C10
man that thing is nice!!....that's the mid rise Holley?
Old 01-30-2017, 07:34 PM   #786
boostedc10
boostedc10's Avatar
Re: Owen's C10
Thanks Moose and ya it's the midrise. Had the highrise but wouldn't clear the stock hood and I didn't want a cowl.
Brandon
Instagram: DRVFSTR
Old 01-30-2017, 11:10 PM   #787
mooseknuckles
Re: Owen's C10
good call..not a fan of cowl hoods.
Old 01-31-2017, 12:43 PM   #788
knomadd
knomadd's Avatar
Re: Owen's C10
Glad you were able to move the engine and got your covers to fit. Your engine looks good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 01-31-2017, 06:15 PM   #789
mooseknuckles
Re: Owen's C10
Thanks knomadd! I'm pretty stoked with how it turned out! I have another piece coming that should put it over the top..
Old 01-31-2017, 08:56 PM   #790
Bennett68C10
Re: Owen's C10
I think I know what that might be, but I'll wait to see it
Keith
66 Suburban
IG: bennett68c10
Old 02-02-2017, 08:04 PM   #791
jwilb88
jwilb88's Avatar
Re: Owen's C10
Thanks! those look way better than the factory stuff
Old 02-05-2017, 08:28 PM   #792
mooseknuckles
Re: Owen's C10
got my new intake....Holley sniper.
Old 02-05-2017, 08:35 PM   #793
mooseknuckles
Re: Owen's C10
I drilled and tapped the valve covers so I could use -4 AN fittings instead of the slip on fitting and rubber hose. got the injectors in and fuel rails bolted down....
Old 02-05-2017, 08:50 PM   #794
nlped
nlped's Avatar
Re: Owen's C10
VERY COOL!!! Getting closer & closer.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 02-05-2017, 09:32 PM   #795
Advanced Design
Re: Owen's C10
Looking very good! Dumb question on my part, is the an fitting for pcv?
Old 02-06-2017, 08:35 AM   #796
boostedc10
boostedc10's Avatar
Re: Owen's C10
Looking really good moose.
Brandon
Instagram: DRVFSTR
Old 02-06-2017, 09:28 AM   #797
Bennett68C10
Re: Owen's C10
Very Nice!
Keith
66 Suburban
IG: bennett68c10
Old 02-06-2017, 06:31 PM   #798
mooseknuckles
Re: Owen's C10
thanks!
thanks! yes, one goes to the intake, the other to the throttle body.
thanks!
Very Nice!
thanks!
Old 02-07-2017, 01:45 PM   #799
knomadd
knomadd's Avatar
Re: Owen's C10
I like it! I read on IG you had to modify some stuff since it didn't work with your truck motor. What exactly did you have to change?
-Duane
Old 02-07-2017, 05:29 PM   #800
mooseknuckles
Re: Owen's C10
whenever I've swapped to an aftermarket intake the truck injectors never work because they're taller, and the plastic cups on the tips won't let the injector sit fully in the bosses so you gotta remove the caps, and then the stands that hold the fuel rails on are too tall so I had to shorten them and drill new holes...now you could spend $500- 600 and buy new car injectors and do it that way, but I don't know why the aftermarket can't make stuff more "truck friendly"?
