05-28-2020, 03:24 PM | #776 |
Post Whore
Re: A '54 named Busty
and watched him measure once and cut twice to make it fit
with a trim here, and a trim there, and a hole for the sticklinator we were ready for the first trial fitmentation |
05-28-2020, 03:28 PM | #777 |
Post Whore
that's not bad for the first try at all
so we kept poking holes in it, until she was in flat as a lizard drinkin' |
05-28-2020, 03:31 PM | #778 |
Post Whore
nest decided to take advantage of the 100° F heat and give the bench seat a much needed baff
I really like this bench seat, it is such a simple yet efficient design, it pivots on two bolts, no more no less, brilliant, love it !!! |
05-28-2020, 03:34 PM | #779 |
Post Whore
decided to treat myself to some stainless steel hardware for the bench seat, the previous owner used some random 5/16s hardware not even grade 5 and not even worthy of taking pics so I tossed it in the trash upon uninstallation, so I decided to upgrade to 3/8ths in stainless
05-28-2020, 03:43 PM | #781 |
Post Whore
05-28-2020, 03:47 PM | #782 |
Traffic Master for a Thrift Master, who knew?
Carpet did fit pretty good on the first cut.
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
05-28-2020, 03:50 PM | #783 |
Post Whore
05-29-2020, 03:04 PM | #784 |
Post Whore
my boy got me the Volt gauge for my birthday, so I couldn't help but try it on for the first time after the Battle Ship Gray paint job, ha ha
only need one more gauge and Father's day is just around the corner |
05-29-2020, 03:06 PM | #785 |
Looking good Mister Greg.
05-29-2020, 04:12 PM | #786 |
those gauge pods almost need a bikini.
looking good!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-30-2020, 12:41 AM | #787 |
Post Whore
got the old bench seat in there with the brand new stainless hardware, I must say the previous owner did a good job of coming up with a smart simple mounting system aside from using cheap hardware
I know I teased you with the bucket seats, but those are for my '71 plus on the account of the virus and money (technically lack there of) I need to run the bench seat for a while |
05-30-2020, 01:29 AM | #788 |
Post Whore
also got all new Allen head stainless hardware for the dash, I got to tell you it makes re assembly so much more fun - the steering column goes back in tomorrow
just getting this stuff at my neighborhood Ace Hardware store, a handful at a time |
05-30-2020, 01:30 AM | #789 |
Post Whore
05-30-2020, 08:59 AM | #790 |
haha well you did name it busty. I guess I never noticed how the gauge pods looked like a pair of hangers, some GM engineer is having a chuckle right now.
05-31-2020, 12:20 AM | #791 |
Post Whore
got the joystick back on
05-31-2020, 12:23 AM | #792 |
Post Whore
so here's an update Good News / Bad News style
first the Good News she all back together, pardon the rubish throttle pedal, my LM7 5.3 will sport an electronic throttle pedal so no sense spiffing up this one, this is just for once around the block she starts, the procedure is pedal to the floor and crank it and she fires up in 2 to 3 seconds (another reason to do an LS Swap, the starts are magnificent) Last edited by Gregski; 05-31-2020 at 12:31 AM. |
05-31-2020, 12:30 AM | #793 |
Post Whore
now the Bad News aka "Cry Me a River"
I wanted to take her for my first maiden voyage but she was not having it, she would die in reverse. Couple observations: I think she is idling too low and I started trying to up the idle speed first by twisting the Idle Speed screw on the good ol' Holley carbie but after a few full turns I thought that was getting rediculous The other option for increasing idlebility is obviously more timing, well I tried to advance the timing some more but I'm giving her all she's got captain as the suction canister on the vacuum advance dizzy is now hitting the intake manifold Tried to actually see at what RPM she be idling and what her initial timing is set to but my fancy digital timing light leads won't reach the battery in it's stock location I can't hook up the timing light leads to the alternator cause I don't think it's charging at the moment since I yet have to wire in a lamp to the L terminal on the four pin connector to excite it. I have no idea why GM went away from the proven self exciting alternators of the square body era to these on the Vortec engines. Throttle pedal aint got the full range of pull on the cable, but I think this was already pointed out to me and a pedestal is in short order. I aint got a breather in my fuel sending unit nor in the fancy fuel cap, so I loosen the fuel cap when I run the truck, not my proudest moment. And I still have an oil leak from the front of the oil pan, but it wouldn't be a Chevy small block otherwise. Last edited by Gregski; 06-01-2020 at 12:36 AM. |
05-31-2020, 01:02 AM | #794 | |
He sounds exactly like the drafting instructor I had and why I also landed in IT. Smarter not harder is a motto he never heard of I guess. Posted via Mobile Device |
05-31-2020, 01:23 AM | #795 |
Post Whore
Oh no! however if we get a third, we can officially start a support group that says we meet at IHOP but somehow always ends up at a local brewery instead!
05-31-2020, 09:08 AM | #796 |
Curious about the idle issue. When you figure it out, let us know.
05-31-2020, 10:35 AM | #797 |
Post Whore
will do brother, and something tells me the solution, may be a little bit of this and that, for example my hypothesis is that:
1. we need to add 5 or 6° of initial timing (base timing with no vacuum advance, aka the starting point, engines ought to idle at the highest initial timing they can muster, despite of what the 1972 manual said) 2. we probably aint giving the HEI distributor full voltage as our alternator aint charging the battery, so fixing that ought to help. 3. we probably are low on transmission fluid and ought to add some. |
05-31-2020, 11:54 AM | #798 |
Post Whore
when's the last time you all rotated your sparkulator wires huh! highly recommended once every 3 front end swaps and or once every 2 frame swaps, ha ha
06-01-2020, 11:58 AM | #799 |
I'm really liking that carpet and dash. Interior is looking good.
06-01-2020, 12:03 PM | #800 | |
Post Whore
here's something crazy, I am still finding dead bees or wasps or what ever they are now on the newly installed carpet every time after I start her up, where the hewk are they falling out of, I mean I wire wheeled the bejezus out of the underneath of that dash? |
