09-27-2015, 10:52 PM | #801 |
Re: Tricked-out Chevy six cylinder engines
heads up anyone looking for parts for a straight six.. i am ordering parts on rock auto and seems to be a lot of cheap parts they are trying to get off the shelves. got 4 oil filters for 12 bucks.
09-28-2015, 09:28 PM | #802 |
I have an issue with my 292. I am swapping out a 250. I do have a 292 perch and now I have a problem with the bracket that bolts to the passenger side of the block. The holes in the bracket are too far apart by about 1/2" and there is a 1" gap between the bracket and the motor mount. Is the bracket that bolts to the block different on the 292. If it is is there a source for them and if so please let me know. Thanks - Terry
09-28-2015, 09:55 PM | #803 |
i believe they are different... here is a link to use the same motor mounts as a 250 but would need to use a electric fuel pump
http://12bolt.com/250292_products/in...ne_accessories |
09-28-2015, 10:03 PM | #804 | |
Post Whore
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-28-2015, 10:17 PM | #805 | |
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
09-29-2015, 12:00 AM | #806 | |
09-29-2015, 02:19 AM | #807 |
And for the 4X4s there's a special 292-Only K/ type crossmember.
09-29-2015, 03:43 PM | #808 |
Post Whore
Here's some pictures for reference of a 65 or earlier block on the mounts and perches. You can see the spacer between the block and engine perch. In 66 this design was changed so the engine perch mounted directly to the block.
10-01-2015, 02:01 PM | #809 |
Anybody ever used a supercharger manifold from Aussiespeed?? I need!
Aussiespeed Chevy inline supercharger kit |
10-01-2015, 02:20 PM | #810 |
Post Whore
They aren't cheap, but yes...alot of the european inliners use them.
10-01-2015, 07:48 PM | #811 |
Thanks for the info Sub and TJ. I just so happens I have an extra drivers side mount. Now it is off to the hardware store for a couple of longer bolts.
10-03-2015, 10:41 AM | #812 |
10-03-2015, 10:49 AM | #813 |
Post Whore
Hey! Almost looks like mine!
Good work!
10-17-2015, 08:57 PM | #814 |
So I just moved and moving my 65 and all its parts got me thinking about my engine build. While I am still a while away from starting the engine build I started to do some research on fuel injection. My plan had been to run triple side draught Webers but I see companies like Jenvey are making Weber replacements and I must admit the thought of individual throttle bodies on my little 230 sounds pretty appealing. Has anyone done this before?
1965 GMC 910 Short Fleetside. 230 CI 4-speed. |
10-18-2015, 11:21 AM | #815 | |
Post Whore
Lot of drag racers and street guys on there(I'm there to) who can help and guide you. Thanks for your interest in the 6 cylinder! Always nice to see something new. Good luck on the build. We'll be here to cheer you on.
10-18-2015, 05:25 PM | #816 |
Here's one. Not quite what you had in mind I bet but it could work on an inline six just as well. There is a more compelling case for using two throttle bodies on a flat-6 though.
I am thinking about this setup for my '61 Corvair Lakewood wagon. Here's the web page if anyone is interested. ...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N |
10-18-2015, 05:50 PM | #817 | |
The engine would have a total of 6 throttle bodies, 1 per cylinder. Not unlike a high performance BMW M3/M5 6-cylinder from the 90's. First thing I would need is is a triple side draught Weber manifold. I'm also reading up on a Meqasquirt ECU to control everything. I've built one before to control a fuel injected rotary engine in an RX-7 that I used to own. As I mentioned earlier in the thread my 230 is original to my truck but I do plan to be pretty aggressive with the build. I'm not opposed to the 250 crank but I have the 6 counterweight 64-66 crank which is a pretty stout choice.
10-18-2015, 07:41 PM | #818 | |
Post Whore
10-18-2015, 08:03 PM | #819 | |
Once I get the truck ready to accept an engine which means starting to spend money on the engine, I plan to call them.
10-19-2015, 10:22 AM | #820 |
Post Whore
Their 12 port heads are only around $2000. LOL.
12-01-2015, 02:04 PM | #821 |
Post Whore
TTT.
What's up guys? lol Been quiet on here. How's all the builds going?
12-01-2015, 05:42 PM | #822 |
I'm still waiting to install my Langdon headers
its been to cold !
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
12-01-2015, 06:49 PM | #823 |
I started a 261 build to replace my current 235. Going to do some very minor porting and cleanup on the head and will post some pictures soon. The head will get all new valves with the larger intake valves installed , new springs, new guides and new positive oil seals.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
12-02-2015, 12:39 AM | #824 | |
Post Whore
12-02-2015, 02:02 AM | #825 | |
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
